Mid Atlantic Impreza Club
Go Back   NASIOC > NASIOC Chapters > Mid Atlantic Impreza Club -- MAIC > MAIC Private Classifieds
Old 04-15-2009, 10:33 AM   #1
MasterKwan
Member Sales Rating: (14)
Member#: 98961
2003 WRX
Default FS Nova 6 Speed swap. $3500
50K miles on all the parts from an 05 STI you get:
1) 6MT Transmission with shifter.
2) R180 rear diff with stock LSD.
3) 4 STI axles
4) STI Driveshaft.
5) All mounts needed to bolt this right in.
The 05 STI 6MT comes with a torsen helical LSD in the front diff and a clutch type LSD in the rear diff. So, for much less than the price of a PPG setup, you get stronger gears AND front and rear LSD's.
The price is firm. It's priced to move so, I can buy some more parts for my car. If it doesn't sell, well, it just means I have spares. I can deliver to Sterling/Leesburg/Frederick MD area. Or meet and transfer in those areas.
I also have a "Spiider" DCCD controller, It's not the latest but, it does have the STI thumbwheel. It gives you DCCD operation and has only 5-6 wires to hook up. Has a G sensor built in.
1 Power
2 Group
3-4 DCCD
5 TPS signal.
If you buy the swap, you can have it.
Just added today to sweeten the deal:
1) Nearly new WRX ACT HD clutch and PP. Was on my car 2-3 months and never drag raced.
2) Complete slave cylinder setup off a WRX. That's a Master Cylinder, Slave cylinder, hose and brackets.
3) If you have an automatic tranny, I'll even throw in a complete manual pedal assembly, brake, clutch AND gas pedal with gas cable.
So, if you have a push type clutch, Like Knighter, all you need to source is a throw out bearing and WRX flywheel
Old 04-15-2009, 10:39 AM   #2
jus10
Member Sales Rating: (8)
Member#: 111711
Pearl White
wish I had 3500. great deal!! im sure itll be gone soon
jus10 is offline   Reply With Quote
Old 04-15-2009, 10:56 AM   #3
Chino1
Member Sales Rating: (5)
Member#: 128985
2002 bugeye STi-ish
MBP
pm me a price for the spider dccd.
Chino1 is offline   Reply With Quote
Old 04-15-2009, 11:08 AM   #4
MasterKwan
Member#: 98961
2003 WRX
If the swap doesn't sell, I'll sell it to you. As it is, it's included with the swap.
Old 04-15-2009, 11:09 AM   #5
Chino1
Member#: 128985
2002 bugeye STi-ish
MBP
fair enough.
Old 04-15-2009, 11:12 AM   #6
wrxspeed1
Member Sales Rating: (19)
Member#: 157619
2008 sentra
white
Bump for a great guy and good price!!
wrxspeed1 is offline   Reply With Quote
Old 04-15-2009, 01:57 PM   #7
knighter
Member Sales Rating: (13)
Member#: 161913
2006 WRX TR
Steel Gray Metallic
ok i might get this i need to check on the fitment and see about a few things first though. does it shift smooth? heres my number 757-768-5395 give me a call when you get a chance my name is kevin
knighter is offline   Reply With Quote
Old 04-15-2009, 05:52 PM   #8
MasterKwan
Member#: 98961
2003 WRX
Shifted smoother than my current 6 speed. It was just too much hassle to pull my current 6 speed and install this one.
Knighter, You have a push type clutch in the 06. That means you'll need a clutch and flywheel to make this happen. It also means that you're limited in the WRX transmissions you can use too. Most WRX's and all STI's use a pull type clutch. You can use either an STI or WRX pull type clutch with the swap.
I'll PM you my email.
Right now I have two interested party's nobody's finalized the deal yet though.
Old 04-15-2009, 06:00 PM   #9
nhat
Member Sales Rating: (42)
Member#: 140163
03 STi
hellaflunctional
06+ wrx uses a push-type?
so 02-05 use pull type as well as the sti?
Old 04-15-2009, 07:11 PM   #10
MasterKwan
Member#: 98961
2003 WRX
Yes, basically the 06-07 WRX gets the same clutch type as the NA's.
Old 04-15-2009, 10:43 PM   #11
knighter
Member#: 161913
2006 WRX TR
Steel Gray Metallic
yeah with me running it ill need a sti flywheel new clutch r180 to r160 conversion rear axles and it would put the final price about 6000
Old 04-15-2009, 11:00 PM   #12
Tut4u2
Member Sales Rating: (65)
Member#: 40424
05 STi
PM a13n0rma1. He has an STi box in his 06 WRX
Tut4u2 is offline   Reply With Quote
Old 04-15-2009, 11:07 PM   #13
knighter
Member#: 161913
2006 WRX TR
Steel Gray Metallic
ok thanks i will
Old 04-16-2009, 12:48 AM   #14
MasterKwan
Member#: 98961
2003 WRX
1) Axles are $1200, if you go that route
2) You could change the diff ratio in your R160 to match the R180
3) You could also simply get a set of new or used rear 04 STI hubs/brakes which are still 5x100 and bolt to your existing suspension.
You can use a WRX OR STI clutch and flywheel. When you switch to the 6MT, either one will work. Say, one of your boys has a used clutch and flywheel, that would work.
I'm not actually expecting to sell it to you at this point, I think the distance and cost is a problem for you. A PPG setup isn't going to be much cheaper though and you won't get the diffs or DCCD. Maybe you should go with a stock rebuild?
Old 04-16-2009, 12:53 AM   #15
kaneda3
Member#: 8057
99 rs-t & 02 sti
95 s14.5
do you have the knuckles and hubs?
kaneda3 is offline   Reply With Quote
Old 04-16-2009, 08:37 AM   #16
MasterKwan
Member#: 98961
2003 WRX
Sorry, no.
Old 04-16-2009, 09:38 AM   #17
matt06wrxwgn
Member Sales Rating: (3)
Member#: 172027
2006 CGM Wagon
322WHP 355 WTQ
payment plan?
edit: just kidding
matt06wrxwgn is offline   Reply With Quote
Old 04-16-2009, 10:05 AM   #18
jconaty07
Member#: 139124
awesome deal. good luck
jconaty07 is offline   Reply With Quote
Old 04-16-2009, 04:25 PM   #19
Abnormal
Lil Curious
Member Sales Rating: (45)
Member#: 149626
2005 CGM FXT
Rocket Box! :D
I've seen this setup (And I want his diff controller). I currently have Driveshaft Shop conversion axles on all 4 corners of my car. VERY tough axles... I recommend them.
If i DO find a set of rear 5x100 STI Hubs I'd probably sell my DSS axles... Or I'd love to just get a 5x114.3 hub swap over with by now
Abnormal is offline   Reply With Quote
Old 04-16-2009, 09:50 PM   #20
MasterKwan
Member#: 98961
2003 WRX
I'll sweeten this deal too.
So, for $3500 you'll get the swap listed above, the Spiider controller and:
So, if you have a push type clutch, Like Knighter, all you need to source is a throw out bearing and WRX flywheel.
Old 04-17-2009, 01:38 AM   #21
txl146
Member Sales Rating: (145)
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
this is a great deal... good luck with the sale.
Old 04-17-2009, 10:55 AM   #22
Abnormal
Lil Curious
Member#: 149626
2005 CGM FXT
Rocket Box! :D
This is beyond sweet now!
Old 04-17-2009, 03:17 PM   #23
gto7419
Member Sales Rating: (54)
Member#: 44256
05 outback xt
02 wrx wagon - crushed :(
this is an unbelievable deal...
gto7419 is offline   Reply With Quote
Old 04-17-2009, 11:13 PM   #24
HSBabyFace
Member Sales Rating: (6)
Member#: 130204
14 JKUR
Very interested. What else would be needed to get this into an 06 wrx? Will the 04 sti axles work with the stock 06 brakes?
HSBabyFace is offline   Reply With Quote
Old 04-17-2009, 11:53 PM   #25
MasterKwan
Member#: 98961
2003 WRX
You'll need one of the three things I listed above. I'm pretty sure the front WRX axles will work though. The rears are always the sticking point.
You're just like Knighter though, you'll need to replace the clutch. Either with the parts I'm including or you own new clutch.
FS NOVA 6 Speed Knobs Abnormal MAIC Private Classifieds 17 02-02-2010 04:41 PM
FS (NY) - 2007 CGM WRX Limited Sport Wagon w/ JDM 6 Speed Swap RR BuGGz Private Vehicle 'For Sale' Classifieds 20 02-15-2009 01:38 PM
FS 05 sti 6 speed swap takeshi999 Drivetrain 27 05-12-2008 12:36 AM
FS STI 6 speed tranny complete swap! shadymilkman129 MWSOC Private Classifieds 9 03-31-2008 12:10 AM
FS/Trade JDM Sti 6 speed swap midnight2.5rs-t Drivetrain 40 07-17-2007 10:01 PM
