Old 04-15-2009, 12:56 PM   #1
NT Imp 25
Member#: 181285
2005 Impreza RS
Silver Metallic
Default CEL Diagnosis
Hey everyone, I was hoping some of you might be able to point me in the right direction. The CEL came on along with a blinking cruise light about a week ago on my MY 2005 impreza RS. I had the codes pulled and they read:
P0031 Front oxygen (A/F) sensor heater circuit low input
P0037 Rear oxygen sensor heater circuit malfunction.
Any suggestion on where to start? Wiring maybe? Are they in series?
Thanks for any help you can provide.
NT Imp 25 is offline   Reply With Quote
Old 04-15-2009, 03:03 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
you can always clean up all your grounds to see if it helps.
Old 04-15-2009, 03:30 PM   #3
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
I would try and check the wiring all the way to the ECU plugs, and then if there is no problem there, clean the grounds.
formula91 is offline   Reply With Quote
Old 04-15-2009, 03:36 PM   #4
NT Imp 25
Member#: 181285
2005 Impreza RS
Silver Metallic
Ok, thanks i'll start with that this weekend. The car was sitting for awhile... almost 3 months. Would this cause anything the CEL? Corrosion on the O2 sensor(s)?
Old 04-15-2009, 03:50 PM   #5
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
I bet it's possible but unlikely. (The Rusting) That only really happens if the O2 sensor is in the exhaust from a 6 o'clock position in which condensation can collect in the sensor.
Maybe some rats or something chewed on the wiring?
I've had stranger stories relating to car storage and rodents. lol.
The car sitting around could cause problems for various reasons. I'm just not sure how.
Old 04-15-2009, 11:32 PM   #6
NT Imp 25
Member#: 181285
2005 Impreza RS
Silver Metallic
Any other suggestions? I'd like to get a bunch of possibilities together to try and solve this in one weekend.
Thanks again.
Old 05-11-2009, 10:31 PM   #7
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
I am also throwing P0037... curious to see a solution.
Sideshowbob is offline   Reply With Quote
Old 05-12-2009, 12:11 AM   #8
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I'm going to guess either your front or rear O2 sensor has died and the ECU can't decide which one it is and is therefore complaining about both.
I've seen a couple of 05s already go through 2-4 front O2s, so I'd start there.
help!!! flashing cel and no one can help tommy 02wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 06-05-2010 07:26 PM
HELP!! flashing cel tommy 02wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-04-2010 01:38 PM
Brake System Self Diagnosis arejay SVX Forum Archive 4 02-17-2001 09:28 AM
Transmission Code Self Diagnosis arejay SVX Forum Archive 0 08-10-2000 09:56 PM
Check Engine Diagnosis arejay SVX Forum Archive 0 08-10-2000 05:19 PM
