Old 04-15-2009, 05:08 PM   #1
mbelitsk
Member#: 208690
Default '02 JDM sti 6 speed into '07 wrx auto
I have a 2007 WRX auto and want to swap in an '02 JDM sti 6 speed and full running gear. Mechanically everything should fit but I am wondering what ECU and DBW problems I may encounter. Can anyone help? Is this swap possible?
mbelitsk is offline   Reply With Quote
Old 04-16-2009, 01:55 PM   #2
mbelitsk
Member#: 208690
Bump! Any help please?
Old 04-16-2009, 11:02 PM   #3
GTScoob
Member#: 68602
02 STi Wagon
Sell your car, buy a bugeye and do the 6spd swap. Your 07 is so new you'll lose a bunch on resale with a car that will confuse/ upset DMV , emissions, and insurance agents nationwide.
Ask me how I know, and search my SN in here or the transmission section and you'll find everything you need to know.
GTScoob is offline   Reply With Quote
Old 04-17-2009, 11:59 PM   #4
Lamont
Member#: 125190
AT to 6MT swap is possible and is the same as a 5MT to 6MT swap with the addition of some pedals, center console and a little wiring. No ECU issues after a flash and no DBW issues.
It's your car, do what you want. Just be prepared for it.
Lamont is offline   Reply With Quote
Old 04-18-2009, 07:35 AM   #5
mbelitsk
Member#: 208690
Thanks for the advice but I don't plan on getting rid of the car anytime soon if at all. Eventually it will probabley just become a track only car or if sold, I imagine it would be to someone in the community who knew the time and money that went into it. Also the transmission may be older in years but it has less miles anyways. Plus I am in Canada so no emmisions agents here as for insurance agents, they are already always confused by the VIN because it is a USDM car which I imported.
Old 04-22-2009, 10:26 PM   #6
RX729
Member#: 193389
document your swap and share it with everyone...
RX729 is offline   Reply With Quote
Old 05-07-2009, 04:00 AM   #7
mbelitsk
Member#: 208690
Will do. Just picked up the transmission, drive shaft, diffs, axels, rear hubs, and brembos two days ago. Once I have my other project done (so I have somthing to drive if problems arise with swap) then I will begin the swap.
Old 05-07-2009, 07:02 AM   #8
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
I don't think you should have any problems with the right parts.
Sounds like you also need clutch, flywheel, slave cylinder, shifter linkage
You should be able to swap in your transmission harness from your 07 without a problem. If it has dccd, you can just get the wires and leave it in open or get a manual dccd controller.
Bad Noodle is offline   Reply With Quote
Old 05-07-2009, 04:42 PM   #9
Lamont
Member#: 125190
The wiring is cake. You can do it one of two ways:
- Use the existing wires that go from the engine bulkhead to the TCU (have a multimeter on hand.
- Or run new wires.
I put a vote on using the existing wires from the engine bulkhead. Use GOOD wiring to shrink-wrap.
Go to Scoobymods.com to see what I wrote on the wiring.
04 STI 6 speed into 03 WRX and vice versa I'm Slow Transmission (AT/MT) & Driveline 14 08-10-2009 07:52 PM
jdm sti 5 speed vs. usdm/jdm sti 6 speed mannyOlicious Transmission (AT/MT) & Driveline 3 06-24-2008 04:18 PM
2 questions about an STI 6 speed into an '02 wagon Cyclops Brakes, Steering & Suspension 17 04-04-2008 04:03 PM
JDM Sti 5 speed VS JDM Sti 6 speed Ace009 Transmission (AT/MT) & Driveline 89 06-09-2007 03:26 AM
USDM STI 6-speed into USDM WRX? hobbzz Transmission (AT/MT) & Driveline 12 01-12-2003 03:26 AM
