Old 04-15-2009, 05:31 PM   #1
love02wrx
Member#: 203189
02 wrx
Default Hks Evc
i bought the HKS EVC for a year already , but i still don't know how to setup , can guys help me up. i wanna full setup. thxx
love02wrx is offline   Reply With Quote
Old 04-15-2009, 06:12 PM   #2
sorrowfulkiller
Member#: 170439
I <3 Lamp
what kind of evc did you get I have an evc 5 myself so if its like that then I could help
do you have pics?
sorrowfulkiller is offline   Reply With Quote
Old 04-15-2009, 07:49 PM   #3
love02wrx
Member#: 203189
02 wrx
yes it is 5
u drive 02 WRX too??
i really don't know how to setup the EVC
thxx
Old 04-15-2009, 08:10 PM   #4
sorrowfulkiller
Member#: 170439
I <3 Lamp
yup I do drive an 02.
Do you have the display also?
Let me look for an instruction manual for it around here... hold on a sec
Old 04-15-2009, 08:40 PM   #5
sorrowfulkiller
Member#: 170439
I <3 Lamp
Setting up
Look at the evc solenoid from the side where the hks logo is pointing up
the port on the left goes to the wastegate
the center port goes to the turbocharger pressure port
the one on the right goes to a manifold pressure source
make sure the evc is off, switch the switch to the back to SW for swingarm wastegates (internal)
hook up everything and be sure you put some sort of fuse in line with the power wire eventually after you get it working.
Setting up boost pressures
to set your low boost pressure on setting "A" (assuming you have a display) hit the SEL/^ button til it shows "A" on the screen, then adjust the dial on the control box and take it for a spin, adjust it slowly til you get the boost you want.
repeat for setting "B"
Scramble boost and Boost cut/warning
-To adjust scramble boost press the mod button, adjust the amount of "boost" you want to add (the numbers don't make sense just set it til you get the correct amount of boost)
-To adjust how long the scramble boost is on for hit mod again and adjust with the SEL and scramble button below SEL.
-To adjust your boost cut/warning feature hit mod once again and select the PSI you want (set it about a lb to a lb and a half higher than you want to hit)
Visual Bar adjustment, Display brightness and Password
-To adjust the visual bars and how far they go til they hit the edge of the screen hold mod til it beeps once, adjust that to however much PSI you want
-To adjust the visual display hit mod one more time, this should show numbers between 0-100, change to however you want.
-Press mod again, at this point you can change the password which will lock it from being changed from internal and external wastegate and will only allow you to use boost pressure A or wastegate pressure and not adjust them.
Gain Values
If you hold mod once, then hold it again after it beeps the first time you will be able to adjust the gain value for boost setting A and boost setting B
Lower values on these will allow you to run more boost but at the sacrifice of precision, higher the number you will have less boost but more precision.
Also, the display will fit perfectly in the upper vents on the center of the dash without using any sort of tape or anything to secure it. I velcro'd my control box to the side of the center console myself so that it doesn't get in the way and is easily accessable.
Ignore my crappy looking dash, I'm wrapping it with carbon fiber sometime this month or next
Old 04-15-2009, 09:43 PM   #6
love02wrx
Member#: 203189
02 wrx
i have the one is different from yours
mine is the black, the new one.
Old 04-16-2009, 03:57 PM   #7
sorrowfulkiller
Member#: 170439
I <3 Lamp
In that case hksusa.com has instructions for it on their site
Old 04-17-2009, 12:03 PM   #8
scrappydoo
Member#: 23630
97 v4 STi RA
Feather White, 02 WRX MBP
Umm... This is the PRE-2002 forum.
scrappydoo is offline   Reply With Quote
FS HKS UP, HKS DP, HKS EVC V, Greddy, TurboXS, + gby2k6 Engine/Power/Exhaust 3 02-08-2007 12:24 AM
Md: Hks Evc V, Hks Evc Ii, Safc Timdog1650 Private 'For Sale' Classifieds 6 11-21-2005 03:51 PM
FS: HKS EVC 2 boost controller, HKS FMIC, 04 STi foglight covers, TurboXS BOV RedSuns Private 'For Sale' Classifieds 29 03-30-2004 01:11 PM
HKS EVC EVC boost controller with LCD screen Diabl0X Private 'For Sale' Classifieds 35 02-04-2004 08:06 PM
