Old 04-15-2009, 05:33 PM   #1
ogboot
Member#: 170906
psm
Default Coolant temp up but oil temp is the same?
I'm at work guys, haven't had a chance to look around but...
I was headed to lunch and looked down to see my engine temp was quite high (prob 2/3). I was like wtf? So i turned on the heater and that brought it down to something manageable, and took it easy until i got to lunch. never peaked out, never overheated. oil temp stayed steady at just over 70c (lamco) the whole time and climbed the usual amount once i got into town and traffic.
Turning off the heater would raise the temp some.
Driving harder would obviously raise the temp.
Taking it easy would almost keep it at it's usual temp.
Oil temp stayed at it's normal temps the whole time.
So what gives? I'm going out of town this weekend so I need to knock this out tomorrow hopefully. No new modifications, stageII for a while now. I'm hoping it's simple like the thermostat or a minor coolant leak from a hose or something.
ogboot is offline   Reply With Quote
Old 04-15-2009, 06:13 PM   #2
pro934
Member#: 169234
2005 STI WRB Reffing
the Kumite from the South
Possible thermostat, more likely head gasket issue. Check and see if any coolant is in your oil (change oil) or oil in your coolant (radiator).
pro934 is offline   Reply With Quote
Old 04-15-2009, 07:58 PM   #3
ogboot
Member#: 170906
psm
it's the radiator, took a look at it when i got home. NOBODY in town has one
Old 04-15-2009, 10:04 PM   #4
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
^ leaking? or clogged?
Old 04-15-2009, 10:47 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
just junk
Old 04-15-2009, 10:57 PM   #6
ogboot
Member#: 170906
psm
Originally Posted by Uncle Scotty View Post
just junk
agreed. looks like it's the seal from the bottom of the core. got a new one en route, had to overnite it because im leaving town for the weekend (in a wedding, perfect timing eh?).
Is a 2000 RS oil filter sandwich the same as 06-07 2.5WRX??? Rallly2000 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 11-10-2008 03:47 PM
FS: Autometer gauge set up (boost, oil temp, volt) jimtweet Private 'For Sale' Classifieds 35 12-21-2005 12:57 PM
What is the probability of FedEx screwing up 2 different packages at the same time? vapore0n Off-Topic 18 11-23-2005 04:10 PM
hwere can i get both coolant and a larger oil line for the pe1820 housing??? scooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-14-2002 11:59 PM
Does anyone know whether or not the brakes from the '99RS is the same as the '00's? GTBGUY Technical Forum Archive 2 08-23-2000 09:00 AM
