Welcome to the North American Subaru Impreza Owners Club Monday April 21, 2014
Old 04-15-2009, 06:03 PM   #1
wrxej205
Member#: 188454
04 turbo turd
sil80 sold :(
Default valve clearance on stock heads with 280bc cams
i was surfin around on here when i came across a thread about a guy saying something about valve clearance. which got me kinda mortified for a minute or two thinkin if i even bothered to check let alone take it into consideration when i was doing my build. heres the specs on my build
new sti 2.5 all stock sb
cometic head gasket.
arp studs
stock old 2.0 heads unpolished and unbored
280 bc cams springs, retainers etc.
all new exhaust valves, shims, buckets, seals and etc on the heads.
now with upgrading to that bigger lift and duration do any of you think ill have a problem of it hitting the piston?
thanks jordan
wrxej205 is offline   Reply With Quote
Old 04-15-2009, 10:18 PM   #2
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
on e85@ 30psi--spinning
no you should be ok you just have to check valve clearance between the bucket and the cam lobe because if the cams are new after they did the heads the clearances will probably be off.
john 1badSTI is offline   Reply With Quote
Old 04-15-2009, 10:47 PM   #3
Team Scream
Member#: 121532
2006 FXT/STi 6MT
01 Aerosim GC8 Coupe
thanks jordan
Why not be 100% certain and check with clay before you commit the heads to the short block permanently ?
Sure be a bummer to get it all back together and then find out the hard way no?
Team Scream is offline   Reply With Quote
Old 04-16-2009, 12:28 AM   #4
wrxej205
Member#: 188454
04 turbo turd
sil80 sold :(
dude thats my point my motor is all together ready to go, im waitin on my tranny i was hoping just to find someone on here who ran 280s in a simular setup with no problems.
Old 04-16-2009, 10:21 AM   #5
wrxej205
Member#: 188454
04 turbo turd
sil80 sold :(
anybody?
Old 04-16-2009, 10:30 AM   #6
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
What's the lift? The duration of the cam does not extend the valve any further into the cylinder the lift does.
What size head gasket?
What did you set the valve lash to?
mick_the_ginge is offline   Reply With Quote
Old 04-16-2009, 10:38 AM   #7
wrxej205
Member#: 188454
04 turbo turd
sil80 sold :(
Race Specification
Longer duration profile, added rpm potential. Intended for fully built engine. Tuning and ECU mods recommended. Requires kit BC0600. BC0602
114 280/280 234/234 .425"/.425" 10.80/10.80 BC0600
USDM EJ205 (’02-’04 WRX) Stock 256/256 205/205 .365"/.361" 9.27/9.17
Old 04-16-2009, 10:40 AM   #8
wrxej205
Member#: 188454
04 turbo turd
sil80 sold :(
100mm standard thickness cometic gasket.
as far as valve lash, i had a subie tech build my head, he knows nothing of aftermarket so i imagine whatever they would normally be.
Old 04-16-2009, 10:50 AM   #9
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
10.8mm lift. You will be fine IMO. You should be able to run upto 11mm with or without AVCS. More lift without AVCS
Old 04-16-2009, 11:02 AM   #10
wrxej205
Member#: 188454
04 turbo turd
sil80 sold :(
without issue with AVCS and more without AVCS????
you mean i should be fine cuz im not running avcs, i got more room
Old 04-16-2009, 11:14 AM   #11
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Updated post above to be clearer (Is clearer even a real word?)
Old 04-16-2009, 11:16 AM   #12
wrxej205
Member#: 188454
04 turbo turd
sil80 sold :(
i think its clearerer
Old 04-16-2009, 01:00 PM   #13
Hayaboosted
Member#: 60042
2004 WRX STI
Rotated T67 ALLABOUTSPEED
That is incorrect. BC Stage 3's dont use the factory clearances.
When you buy them new they come with a spec sheet. Mine currently is at the machine shop otherwise I could give you the correct valve lash.
Hayaboosted is offline   Reply With Quote
Old 04-16-2009, 01:13 PM   #14
kevinh211
Member#: 56297
2004 STi HTA Green
28psi, MSPT Tuned
BC asks for .008" intake and .010" exhaust lash.
and i THINK the factory specs are .008" intake and .012" exhaust.
kevinh211 is offline   Reply With Quote
Old 04-16-2009, 01:16 PM   #15
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
It's really the valves that drive the lash requirement, not the cam. The valves grow more with heat than the cams do.
Most aftermarket setups call for 8 thou intake lash and 10 thou exhaust lash. Stock calls for 8 thou intake and 13 thou exhaust. If you did stock lash then you are fine, it's what i did as part of my last refresh.
Old 04-16-2009, 05:12 PM   #16
wrxej205
Member#: 188454
04 turbo turd
sil80 sold :(
i just tried callin the guy who built my heads waiting on his call back about the specs he built em on.
[2008 STI, 35R] Cosworth Stage 2 cams on stock heads/valve train? user1029 Built Motor Discussion 0 01-04-2010 12:51 AM
STi heads vs WRX heads with big cams japslapr Built Motor Discussion 1 06-09-2009 12:05 AM
valve clearance on hybrid setup wrxej205 Factory 2.5L Turbo Powertrain 3 04-28-2009 07:18 PM
valve clearance on aftermarket cams WrXtaCy2003 Built Motor Discussion 5 04-19-2007 10:26 PM
porting stock heads or new cams? cubuff Factory 2.0L Turbo Powertrain 3 03-04-2005 10:39 AM
