Old 10-14-2009, 04:19 PM   #1251
Merp
Member#: 199106
PMme 4 Speed Density
Patches on OEM ECU
I'm running a GS crosspipe with manifold's I ported myself. Essentially the same setup without coating, but I'm using heatshields.
One of my injector o-rings was on its way out with a slight leak, and totally obliterated itself this morning, so tuning is on hold for the moment. While it's under the knife I'm going to change the plugs to OE heat range copper v-grooves, I was getting a little blowout at high rpm with the E85.
Merp is offline   Reply With Quote
Old 11-06-2009, 09:18 PM   #1252
maperformance
Member#: 141043
2004 FXT
My Thread: Click Here For Mods and Other Info
My Numbers:
maperformance is offline   Reply With Quote
Old 11-07-2009, 12:02 AM   #1253
rexblake
Member#: 178426
2010 Evo X MRt
Hot damn Adam! Way to break the 400whp mark with this sucker! And holy boost! You still on the 850's?
rexblake is offline   Reply With Quote
Old 11-07-2009, 12:05 AM   #1254
Gixxer1K
Member#: 81631
stage 11
Where are all the naysayers? *crickets*
Gixxer1K is offline   Reply With Quote
Old 11-07-2009, 12:08 AM   #1255
logic
Member#: 47613
2005 WRX Wagon
Obsidian Black Pearl
Very nice. That graph would seem to suggest that there's more to be had from 4000-5500 RPM as well.
logic is offline   Reply With Quote
Old 11-07-2009, 01:00 AM   #1256
maperformance
Member#: 141043
2004 FXT
Went out running tonight with some 30r sti built guys. I think they were impressed. Seeing as i'm still completely stock block and we turned it down to 390whp
800cc and the IDC you don't even want to know.
Old 11-11-2009, 02:03 PM   #1257
ronzogonzo
Member#: 136671
WRX HTA GT3076R
9cm2 eWG'd It's ALIVE!!
I figure I'll post my build. Just wondering what numbers you guys think I'll be able to hit with my setup. I still have to figure out who tuning it?
07 WRX:
Built 2.5 EJ257
CP 99.5 8.2-1 CR pistons
Eagle rods
ACL race series bearings
Pistons have been side skirt coated as well as domes coated
05 STI heads
STI cams
Invidia tbe non-resonated
Tial 38mm vband grimmspeed ewg setup
HTA68
TGV deletes
DW750's
Perrin 2.4 inlet and afta maf
k&n typhoon SRI
STI top mount IC
running a killer b oil pickup tube, should be dropping the motor in soon, I have done a complete transformation of my WRX it now has 04 sti speed and r180 and this would be the third motor.
ronzogonzo is offline   Reply With Quote
Old 11-11-2009, 02:56 PM   #1258
06-wrx-tr
Member#: 185106
2006 Subaru WRX WRB
Mazda protege'
how do you go through motors so fast. did you blow them? and at what power level? 3 motors on a 07? wow... im still on the stocker with 40k and stage 2/3 since 18k. just curious.
07 WRX:
Built 2.5 EJ257
Eagle rods
05 STI heads
STI cams
HTA68
TGV deletes
DW750's
k&n typhoon SRI
STI top mount IC
06-wrx-tr is offline   Reply With Quote
Old 11-11-2009, 03:17 PM   #1259
ronzogonzo
Member#: 136671
WRX HTA GT3076R
^^first motor popped from the tune (too much boost and timing)
Second motor spun a crank bearing due to either over revving it or wristpin clip popping out of its hole.
Old 11-11-2009, 03:20 PM   #1260
06-wrx-tr
Member#: 185106
2006 Subaru WRX WRB
Mazda protege'
well that sux man.... good luck with this build. how much boost/timing were u running to pop the 1st motor?
Old 11-11-2009, 05:27 PM   #1261
ronzogonzo
Member#: 136671
WRX HTA GT3076R
Im not sure the exact numbers, my buddy was open source tuning it at the time and had flashed a updated XPT map on to my ecu. a few WOT pulls later and I pop the ringlands on two pistons. cylinders 2,4 to be exact. live and learn
Old 11-11-2009, 05:36 PM   #1262
06-wrx-tr
Member#: 185106
2006 Subaru WRX WRB
Mazda protege'
did you know instantly something was wrong? just trying to understand if its noticeable or if it just starts smokin and burning tonz of oil.
Old 11-11-2009, 06:55 PM   #1263
ronzogonzo
Member#: 136671
WRX HTA GT3076R
ohh yeah! you could feel it pull timing, and then it smelled like oil was burning and then it popped a CEL. we pulled it when we got off the HWY and p0304 misfire on 4. I'm averaging 25k per motor. I currently have 50K on the odometer. so not too bad, considering I beat the piss out of my car. My tranny held up the whole time, but this last motor I decided to pull that and go to a 6 speed.
Old 11-28-2009, 03:42 AM   #1264
Fierysun
Member#: 82745
2005 Subaru STI
2003 WRX Wagon
Naysayers are on this thread...
http://forums.nasioc.com/forums/show...9#post28956479
Fierysun is offline   Reply With Quote
Old 11-28-2009, 10:15 AM   #1265
robertrinaustin
Member#: 51964
2008 STi, OB, EVO
Blk Sti and EVO, Navy OB
Originally Posted by Fierysun View Post
Someone needs to get control of the mod in that thread, banning those that disagree with him isn't right.
robertrinaustin is offline   Reply With Quote
Old 11-28-2009, 02:32 PM   #1266
AkumaMotorsports
Member#: 214570
Awesome numbers! We are seeing very very promising results with this turbo!
- Alex
AkumaMotorsports is offline   Reply With Quote
Old 11-29-2009, 04:42 PM   #1267
Gixxer1K
Member#: 81631
stage 11
Agreed, that's a shoddy way of ending an argument.
Old 11-29-2009, 06:11 PM   #1268
Fierysun
Member#: 82745
2005 Subaru STI
2003 WRX Wagon
+ a billion
Old 12-01-2009, 03:29 PM   #1269
BenGSX
Member#: 210061
Yeah, I knew this turbo would be a little monster when cranked with good fuel..
For what it is, a tweaked 16g, it flat out rocks. For a street daily driver, that is a very nice fat area under the curve.. I like.. Which is why I ordered one up.. Should do nicely in my e85 burning wagon..
BenGSX is offline   Reply With Quote
Old 12-12-2009, 10:54 AM   #1270
Guru
Member#: 142023
I just tuned one of these on a Forrester XT 2.5L and wow was this thing quick. Only running 18 PSI at the moment as he is on stock fuel system/Stock IC but car is wicked quick and spool up is like stock. Definately making 300 WHP based on AF ratios and inj duty cycles.
Guru is offline   Reply With Quote
Old 01-11-2010, 08:36 AM   #1271
mapleleaf
Member#: 103399
2009 Stripped STI
Dirty White
+ a billion
You were spewing misinformation that many people may have taken as truth.
7cm Hotsides on 2.5's creep. Creep sucks.........
mapleleaf is offline   Reply With Quote
Old 01-11-2010, 01:44 PM   #1272
Fierysun
Member#: 82745
2005 Subaru STI
2003 WRX Wagon
So everyone that run the HTA68 on the 2.5L is making a mistake? Whatever you say...
Not everyone is looking for same thing out a turbo.
Old 01-11-2010, 02:05 PM   #1273
LittleBlueGT
Member#: 96204
2005 Legacy GT
Atlantic Blue
No, but he is correct. In the cold every single 7 cm housing I have played with creeped.
My hta68 which has about a 10psi spring in it (or something close to that) will creep to a little over 16 psi in the cold. Now, seeing as that is lower then my boost target, it doesn't really matter.
LittleBlueGT is offline   Reply With Quote
Old 01-11-2010, 02:17 PM   #1274
STi Mikey
Member#: 114631
2007 11.5 @ 118
Stock Turbo Record Holder
Still not quite understanding why people think it is not a good choice for the 2.5ltr. It spools like a 39 and makes 20g power. Creep is minimal. Its a great turbo.
If you can drive, high 11's/low 12's are more than doable with supporting mods (at sea level).
Goint Green on the 2.5ltr with just 93 pump, IMHO, sucks. It will make 10-15 more peak, but you will loose the insta-boost of the 68.
STi Mikey is offline   Reply With Quote
Old 01-11-2010, 02:17 PM   #1275
Merp
Member#: 199106
Patches on OEM ECU
My Hta68 (10psi spring) ran 10psi solid, cold or not. Seeing how you mention boost targets, were you running a bcs at the time?
Absolutely wrong, creep isn't exclusive to a small housing, it's the combo of a small housing with a small wastegate port that really does it. From my experience tuning this turbo, this is not the case. Talk about spewing misinformation.
Can any power curve compete?? GTR content AkumaMotorsports Proven Power Bragging 255 08-28-2009 10:39 PM
Any extremely competent OpenECU tuners in NoVA or C-ville? Capt Crunch Mid Atlantic Impreza Club -- MAIC 5 01-17-2007 05:46 PM
Spec C STI can do sub 8 min at NURBURGING Can any stock EVOs do that? hauvis Brakes, Steering & Suspension 36 09-16-2005 02:38 PM
I need the Morette Twin Head lamp wiring diagram! Can any one Help? STiShawn Interior & Exterior Modification 9 05-04-2001 02:01 PM
Can any tire live up to my standards? MGXsport North West Impreza Club Forum -- NWIC 7 02-14-2001 06:00 PM
Message Board Statistics All times are GMT -4. The time now is 07:57 AM.
