Old 04-15-2009, 06:46 PM   #1
Pirce39
Member#: 182870
2009 WRX - Stage 2!
Default CAI install!! '07 2.5i
i am mid-install of the cosmo racing cold air intake...i successfully removed the stock intake, and have began to piece together the cosmo cold air in the engine bay. from the engine it makes sense, but, where does the second small pipe come in (the one that connects the maf sensor to the cone)??? does this install require removal of the fender?? i cant see how the cone filter fits down in the wheel well (where its supposed to go) without going from the bottom.
who has exp. with this install please help!!!
thanks, anthony
Pirce39 is offline   Reply With Quote
Old 04-15-2009, 07:16 PM   #2
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
just remove the wheel and the splash guard . fender stays put . plenty of crap you'll need to pull out of the wheel well.
you have to pull the stock air box out too if you didnt know.
watchunglava is offline   Reply With Quote
Old 04-15-2009, 09:55 PM   #3
Jerry Xu
Member#: 36629
07 2.5i
Regularly Being Modified
Yap. You may also want to experiment the SRI setup as well as the CAI setup. The SRI is even easier as you know.
Jerry Xu is offline   Reply With Quote
Old 04-15-2009, 11:25 PM   #4
thethaddeus
Member#: 155805
2006 impreza 2.5i
indeed,.. just pull the splash guard out of the way
thethaddeus is offline   Reply With Quote
Old 04-15-2009, 11:37 PM   #5
Pirce39
Member#: 182870
2009 WRX - Stage 2!
here's where im at now:
i fit the whole intake together in its respective position, however, i turned the smaller pipe upside down (because the other way would not fit at all) and ran it through the other hole (the one closer to the front of the car). i seemed to have some success but im not sure the filter is going to fit on (not sure theres enough room in the fender). i did manage to remove part of the wheel well in order to reach the part of the pipe where the filter attaches..any more input or suggestions???
Old 04-15-2009, 11:49 PM   #6
jt0thevizzle
Member#: 174979
Don't do it. Have you read the thread about how CAI/SRI are bad for N/A? It's a sticky by Willitay.
jt0thevizzle is offline   Reply With Quote
Old 04-15-2009, 11:56 PM   #7
Pirce39
Member#: 182870
2009 WRX - Stage 2!
jt0tothevizzle: i have read the many threads but would rather test out the data for myself...i know willaty's info/data is very accurate, however, im hard-headed. there is some info/data that cai are not bad for our cars. wutever the case may be im putting this cai in one way or another haha. ill let u guys kno MY data/input...thanks for looking out!
Old 04-16-2009, 12:33 AM   #8
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
No, there's not. Literally everyone who has claimed not to have the problem has proven to be wrong when they manned up and showed the data.
Old 04-16-2009, 12:38 AM   #9
watchunglava
Member#: 168862
i would just do it , i mean seriously wility is into doing mods that give him less power accross the entire band
Old 04-16-2009, 12:44 AM   #10
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
yeah, I got screwed on that one. Tomorrow I start the process of getting my torque back.
Old 04-16-2009, 01:08 AM   #11
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
points for admitting it. Good luck to you, whatever you decide.
XanRules is offline   Reply With Quote
Old 04-16-2009, 01:26 AM   #12
Jerry Xu
Member#: 36629
07 2.5i
Ya. He knows what he wants!
You know I love my SRI. Its response is for sure better. Will report back the car's longevity. This may take a little while though.
Old 04-16-2009, 12:16 PM   #13
Pirce39
Member#: 182870
2009 WRX - Stage 2!
thanks for the replies people...like i said, i'll let you all know how it works out, maybe my car is the exception....
Old 04-16-2009, 01:13 PM   #14
Syph3r_
Member#: 150804
2015 STi
CWP
It's not.
But it is YOUR car, so have fun!
IMO I would just use the CAI bits and fab up the hybrid, but of course what does NASIOC know.
Syph3r_ is offline   Reply With Quote
Old 04-16-2009, 01:45 PM   #15
SUBYAWD85
Member#: 208228
2007 Impreza 2.5i
Newport Blue
Here is the install instructions just in case you didnt have em.
http://www.injen.com/galleries/produ...directions.pdf
But then again, you got a cosmo.. soooo
Im getting my Injen soon.
The directions say its for an 05 RS but Im pretty sure its the same set up for our cars.
And I also read Williaty's thread and its some good stuff, it really made me debate on doing a hybrid or not. I think Im gonna go with the Injen CAI and see the response, maybe most people are having issues when buying poorly manufactured CAI's. Unless williaty has tested his theory with the Injen Intake.
Keep it up either way, Good Luck!
SUBYAWD85 is offline   Reply With Quote
Old 04-17-2009, 09:29 AM   #16
Syph3r_
Member#: 150804
2015 STi
CWP
I can really start to see now why williaty doesn't even bother anymore sometimes. It pains me to no end to see stuff like ^ . I mean did you even read the thread? it doesn't matter what CAI/SRI you use and quality has absolutely nothing to do with it! They all cause the same thing when you remove the resonator...
In an effort to make this not a personal attack...
Yes you can use the 05 RS Injen intake on a 06/07 2.5i. All you need is a T connector for the 3 vacuum lines and your done. If you are not tuning for this setup then the sad part is you will likely never notice the problem you are creating by removing the resonator.
Old 04-17-2009, 10:21 AM   #17
Jerry Xu
Member#: 36629
07 2.5i
He has read that, so have you.
Old 04-17-2009, 11:19 AM   #18
nobrainer440
Member#: 208614
2006 2.5i
I'll buy your stock intake from you if you want to get rid of it. I just picked up an '06 2.5i with a short ram intake on it that I want to return to stock. I've been trolling ebay, but all I've found is WRX intakes. PM me if you're interested.
nobrainer440 is offline   Reply With Quote
Old 04-17-2009, 12:36 PM   #19
SUBYAWD85
Member#: 208228
2007 Impreza 2.5i
Newport Blue
Hey dont get your panties in a twist
All Im saying is, if I was gonna make a bold statement by saying that ALL CAI's cause the same thing, then I would test my theory on more than one. Im not saying I dont believe him (the guy OBVIOUSLY has more experience in this field than me), Im just giving my unexperienced opinion. And when he does do it and proves me wrong I will be humble, shut my mouth, and say.. Damn, your the man.
Old 04-17-2009, 01:32 PM   #20
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Send me a free Injen if you want it tested. No way in hell I'm wasting my money on one.
Old 04-17-2009, 01:44 PM   #21
SUBYAWD85
Member#: 208228
2007 Impreza 2.5i
Newport Blue
I really would man, like I said I dont doubt that you are right. Im a service technician in the low voltage industry so I have to troubleshoot issues on a daily basis. There have been times where there were contributing factors to a problem that I didnt know about and found out later through intense troubleshooting, so it is in my nature to ask questions to learn more about what causes these issues.
On another note, when driving the vehicle with a hybrid vs. the CAI was there a noticeable drop in hp or throttle response?
Old 04-17-2009, 01:47 PM   #22
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Honestly, the intake itself has NOTHING to do with the problem. That's why both CAIs and SRIs react the same and why the brand/model of the intake doesn't matter. The entire problem revolves around the Helmholtz resonator in the fender.
If the intake air passes through the Helmholtz resonator, the intake is going to work. If the intake air does not pass through the Helmholtz resonator, the intake is not going to work. Period.
And the hybrid feels exactly like, and I'm willing to bet would dyno exactly like, any CAI or SRI.
Old 04-17-2009, 01:58 PM   #23
SUBYAWD85
Member#: 208228
2007 Impreza 2.5i
Newport Blue
Man, thanks so much for the reply. Im slowly learning all this stuff but I'm glad you cleared it up. Now I know what to go with. I guess the issue now is searching the web to find the "ebay setup" that I need.
Old 04-17-2009, 09:45 PM   #24
Jerry Xu
Member#: 36629
07 2.5i
I will sell you my stock intake with the air box, pipes, panel filter, filter box all that. It has only 9500 miles on it when I got these out. I am not on a hybrid. got no use of this stuff. It maybe hard to find cause everyone seems to be on hybrid.
Cosmo Racing CAI ['07 2.5i] Pirce39 Car Part Reviews 2 04-21-2009 07:59 PM
CAI install!!! '07 2.5i Pirce39 Newbies & FAQs 9 04-16-2009 01:09 PM
Super-budget '07 2.5i brake upgrade plans Mus35th Brakes, Steering & Suspension 7 01-22-2007 02:29 PM
Differences between '07 2.5i and WRX baj General Community 10 01-07-2007 12:57 PM
