#1 |
Member#: 136919
W. Canada
Vehicle:2005 Legacy GT Wagon ABP |
looking at doing this build myself in the near future. Can use any EJ25 bottom end? is there a better one? Also about the EJ22 heads? what year is the best? I also heard you can use a EJ25 ECU to raise the revlimit another 500RPM? This engine will be going into my 98 legacy which currently has a EJ22. Will using a phase 2 EJ25 ECU remove my need to have a MAF sensor?
#2 |
Member#: 130489
Vehicle:02 WRX Wagon (WRB) 98 OBS-T, 91 Legacy SS |
Compression could be around 10.6:1 depending on which pistons you use. If you used a thin enough Cometic head gasket you could get as high as 11.9:1 or so.
I don't know enough about head gasket particulars to offer any pro vs con advice with respect to thickness. I think the biggest problem you'd run into is the fact that the EJ22 SOHC heads may not flow enough air to really be able to accomodate the increase in compression in NA form. I have no data on this so it is something you'd have to explore further. For all those wondering, I have a compression ratio calculator spreadsheet made up by Matt Jones (of NASIOC) but I am uncertain of just how accurate they are. I have run the math to check his calculations on various set-ups based upon information I found published and my numbers were often very close to his. Also... You can raise the rev limit in your 98 EJ22 ECU by soldering in a larger crystal that controls the rev limit. It's very easy to do and cheap too. |
#3 | |
Member#: 136919
W. Canada
#4 |
Member#: 130489
I edited for the rev limit raising so please re-read the bottom of my first post.
| Thread Tools | |
| Display Modes | |
| Questions about EJ25 Block. | alieus | Factory 2.5L Turbo Powertrain | 3 | 12-03-2009 12:05 AM |
| Question about EJ25 shortblocks | JdmBugI | Built Motor Discussion | 9 | 12-13-2007 08:32 AM |
| Quick n00b question about ej25... | shadymilkman129 | Normally Aspirated Powertrain | 3 | 05-12-2007 08:18 AM |
| What will be better for an n/a ej25/ej22 hybrid? ej22 or ej22t HLA heads? | lotus2843 | Subaru Conversions | 4 | 08-09-2005 03:13 PM |
| questions about EJ25 bottom end swap | silver03T | Subaru Conversions | 6 | 06-09-2005 04:17 PM |
