Old 04-16-2009, 12:40 AM   #1
Daftboy
Member#: 205319
Exclamation EJ22 help...
Hey I'm new to this whole turboing scene so I was wondering if you can help me out and tell me need what I need/should get...this is what I will have shortly..only trying to run 5psi or so right now
td04 turbo from 06 wrx no shaft play
heat wrapped custom uppipe with spacer to clear sohc head
catless wrx downpipe
moddified fuel rail
svx fuel pressure regulator
wrx 5qt oil pan
earls braided stainless return line that threads onto fitting on oil pan
braided stainless oil feed line
jdm wrx manifold
custom intake with cone filter
oil catch can
and a TMIC
Thanks in advance.
Daftboy is offline   Reply With Quote
Old 04-16-2009, 12:44 AM   #2
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
What ECU?
Need PP6 or Emanage, something to pull/add fuel/timing
Old 04-16-2009, 08:14 AM   #3
Daftboy
Member#: 205319
Yea i was not sure which to get...can i run with a safc? or do i need something else ..keep in mine like i said only 5 psi.....what is the max boost i can run a ej22...(98 impreza),,with stock internals
Old 04-16-2009, 10:42 AM   #4
gto7419
Member#: 44256
05 outback xt
02 wrx wagon - crushed :(
i wouldnt run a safc at all - youre asking for trouble with that thing... you need a pp6 piggyback, an emanage blue, or ultimate - something that is able to control fuel and timing... and, even being able to control both fuel and timing, your compression ratio is really too high to push too much boost... theres no "max" boost you can run, but you better be REALLY careful, because those motors dont respond well to lots of boost..
gto7419 is offline   Reply With Quote
Old 04-16-2009, 12:13 PM   #5
Daftboy
Member#: 205319
how hard is it to use the emange..never really messed with it to much...
Old 04-16-2009, 03:15 PM   #6
hustleshark206
Member#: 182227
2000 MPS Built RS
1991 Leggy Turbo EJ22t
I have heard good things about emanage ultimate personally. I was going to use it on my hybrid until I decided to go stand alone. What car is this going on? You should try the "N/A Engine with bolt on Forced induction" forum. Probably get a lot more useful info over there. Try looking on www.rs25.com as well.
Good luck
hustleshark206 is offline   Reply With Quote
EJ22 help..... silverscooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 59 10-15-2015 12:28 AM
help!!! flashing cel and no one can help tommy 02wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 06-05-2010 07:26 PM
EJ18 -> EJ25 -> eJ22 help tooocool49723 Subaru Conversions 4 10-02-2007 12:07 AM
EJ22 Help! - adamrs merged threads adamsrs Normally Aspirated with bolt-on Forced Induction Powertrain 40 05-19-2002 11:06 PM
Need help identifying EJ22 Soob_pwr Normally Aspirated Powertrain 4 01-13-2002 11:28 PM
