Old 04-16-2009, 01:04 AM   #1
big67
Member#: 81234
Default How do I check if my rings have seated?
Hello all,
I just installed a new shortblock with pistons and rings, and was wondering how to check if the long and boring break in period worked. Want to know if the 1000 miles of slow driving and 3 oil changes paid off.
Thanks
big67 is offline   Reply With Quote
Old 04-16-2009, 01:09 AM   #2
q_dubz
Member#: 168482
compression and leakdown test. also you'd notice smoking and oil consumption.
q_dubz is offline   Reply With Quote
Old 04-16-2009, 10:53 AM   #3
scprs
Member#: 172359
2005 STi
i would like to know as well...... Good oil consuption as if they were seated or bad oil consumption?
scprs is offline   Reply With Quote
Old 04-16-2009, 10:58 AM   #4
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Check oil consumption
Compare compression and leakdown tests with the tests you performed at first startup (cough)
Check for gas-contaminated oil
jblaine is offline   Reply With Quote
Old 04-16-2009, 11:07 AM   #5
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
which should come after any internals are broken in (cough) cams (cough)
so check compression after that first 20 minutes or so.
Old 04-16-2009, 11:50 AM   #6
berdugo
Member#: 163108
07 EuroDM STi 2.5L
is it normal for built engine to be smoking? what about when you remove the oil filler cap, is it normal for built engine to have some smoke?
my built engine don't have those smoke at the tailpipe nor from the oil filler cap. I hope my PW clearance is not that thight that would lead to premature failure but so far my engine runs very smooth
berdugo is offline   Reply With Quote
Old 04-16-2009, 11:00 PM   #7
cooleys04
Member#: 145027
2004 WRX FP Green
MFactory/2Tone/built 205
Break in periods are highly debatable (not going there though). Imo, if you've driven 1,000 miles, your rings are broken in. Oil consumption is not a good indicator of engine health. Turbos eat oil, valve seals can leak, lots of stuff that has nothing to do with base engine condition. Smoke can be normal on startup depending on what material your pistons are made of and what your piston/wall clearance is. 2618 material requires more p/w clearance than 4320 due to thermal expansion, this can cause normal cold start smoke. Should go away when the motor warms up.
cooleys04 is offline   Reply With Quote
How do i check if my shock/struts are going bad? Hyelude Newbies & FAQs 1 07-23-2009 05:14 PM
How do you check if a turbo is good? o2sys Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-05-2006 03:59 PM
How can I tell if my 02/03 Seats have Heaters? XyKo Newbies & FAQs 6 08-07-2006 10:55 PM
How do you check if you need to align bore your block? Starkiller Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 12-17-2005 10:53 AM
how do i check if i have any warning points? rich728 Newbies & FAQs 5 09-17-2003 09:55 PM
