Old 04-16-2009, 10:59 AM   #1
sonic03dz
Member#: 144056
03 wrx
sonic yellow stage 2
Exclamation vf 43 or vf 48 install on 03 wrx
I am looking to upgrade my 03 WRX turbo. I have been told that the vf43 and vf48 are the new versions of the vf 34 and vf 39. I also researched that the vf 39 or vf34 tend to crack and have wastegate issues.
My tuner said he would rather see me go with IHI turbo than a blouch. He thinks the IHI are more reliable.
I am looking to make 300whp and am trying to decide between these turbos? The car is catless w/sti TMIC and will be doing an open stock ecu reflash tune on dyno dynamics.
thanks for your input!!!!!!!!
sonic03dz is offline   Reply With Quote
Old 04-16-2009, 11:07 AM   #2
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
2.5 hybrid 367whp/363wtq
On a IHI turbo, you will more likely make around 285whp (seems to be what most people make on the 2.0's) but as far as reliable, Blouch makes very reliable parts. If you went with a blouch evoIII 16g, you will def reach your 300whp goal. This Friday I am about to install my vf34 (haven't really heard of these turbo's cracking around the waste gates like the 39's) and I am expecting to make around 280whp, give or take. However the numbers don't mean much to me since most dyno's all read differently. To me, it's how it compares to other cars and how it does at the track. If you do go IHI, or anything else for that matter, you will need larger injectors (06-07 wrx (565cc) injectors or sti pinks will work fine) and a walbro 255fp.
shadowmd is offline   Reply With Quote
Old 04-16-2009, 11:09 AM   #3
06-wrx-tr
Member#: 185106
2006 Subaru WRX WRB
Mazda protege'
between the 43 and 48 the 48 is a better turbo. Ive had the TDO4, VF39 and now the vf48. The 48 has a better mid/top than the 39. i have the vf48 on my 06 and i like it alot . But it would also be great for the 2.0l.
You can get to your goals on a dynojet depending on altitude and a couple other factors. But your toque #s will be lower on the 2.0l
06-wrx-tr is offline   Reply With Quote
Old 04-16-2009, 11:11 AM   #4
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
yea, my guess would be about 285awhp and 265-270awtq
Old 04-16-2009, 11:33 AM   #5
06-wrx-tr
Member#: 185106
2006 Subaru WRX WRB
Mazda protege'
Yea but it all depends on the dyno. Here in utah at 5000ft above sea level my 48 made 250 whp 280wtq on cobbs mustang "Heart Breaker" and on a dynojet at 2300ft asl it made 307whp and 329 wtq. Just goes to show it all depends on the dyno.
Old 04-16-2009, 11:34 AM   #6
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
Very true. I usually just rely on how it compares to other cars.
Old 04-16-2009, 12:28 PM   #7
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
You can't really go wrong with either one. Pretty much the same turbo. I have a 43 on my 02 WRX and the car is a blast to drive.
Just for estimates, tuned on E85 running about 18-19 psi, the road dyno says about 280 whp on mine...
thefoos is offline   Reply With Quote
Old 04-16-2009, 01:51 PM   #8
IMPORTIMAGE
NASIOC Storefront Vendor
Member#: 79304
CALL 941-257-9618
www.ImportImageRacing.com
i believe the 48 will spool faster then the 43 and make similar power
IMPORTIMAGE is offline   Reply With Quote
Old 04-16-2009, 02:16 PM   #9
sonic03dz
Member#: 144056
03 wrx
Default import image
will sti pinks be enough for a vf48?
Old 04-16-2009, 03:14 PM   #10
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
yes of course...if you get hungry for more power later and you have a couple more bucks you can always do 650's some meth etc..
Old 05-07-2009, 09:50 AM   #11
4thgenx42
Member#: 146312
Is the VF48 a direct bolt on for 2.0L?
4thgenx42 is offline   Reply With Quote
Old 05-07-2009, 10:46 AM   #12
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Yes it is.
VF-39 is identical to the VF-43 for all purposes.
VF-48 no one is 100% sure of, it is definitely the same as a 39, but may have more top end depending on which rumor you believe.
There are many flavors of 16g and they should all spool a touch faster than any 39/43/48 and will match or beat top end depending on which flavor you get.
While IHI turbos are reliable, Mitsubishi turbos are just as reliable and you can rebuild them if they go bad. IHI turbos are throwaway units.
If you are thinking of a Blouch, send me a PM and I'll get you a discount on a new unit through my ninja sources.
vf 43 or vf 48 ? eatus ravenous Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 03-06-2008 07:47 PM
VF 43 or VF 34 for 07 wrx tr eatus ravenous Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 01-27-2008 08:35 PM
Work Emotions with +43 or +47 offset for my 03 WRX 03twrx Tire & Wheel 4 06-08-2005 08:15 PM
factory wing install on 03 WRX (help) 2003forcefed Interior & Exterior Modification 5 02-13-2003 02:57 AM
dms 50 install on 03 WRX? dave_the_driver Brakes, Steering & Suspension 12 12-16-2002 10:13 AM
