Old 04-16-2009, 10:51 AM   #1
dboostjuice
Member#: 206216
Default ej22t maf delete?
is there a way to run a factory legacy ss turbo without the "maf"
A "map" only conversion?
dboostjuice is offline   Reply With Quote
Old 04-16-2009, 11:36 AM   #2
piddster
Member#: 144285
1993 UHEV Legacy
piddster is offline   Reply With Quote
Old 04-21-2009, 03:27 PM   #3
dboostjuice
Member#: 206216
so i can buy a maft-pro and use it with a map then wire it into my factory ecu? is anyone doing this?
Old 04-22-2009, 06:04 PM   #4
sigma pi ver. 14.0
Member#: 164838
you can tune it off MAP and TPS
sigma pi ver. 14.0 is offline   Reply With Quote
Old 04-23-2009, 08:37 AM   #5
dboostjuice
Member#: 206216
hows it work out? is it effective?
my situation is; i have an legacy ss (2.2t) i have swapped in a ported td04, and just picked up a f.xt tmic, I have an safc2 installed and a vortech rrfpr. i want to run a bar of boost, sounds respectable? i know the stock maf maxes out at 13psi. so i am thinking of ways to make it happen. a maf delete would also "kill to birds with one stone" because my td04 has the straight inlet and i want to run it open compressor with my b.o.v. atmospheric. (map loves atmospheric bov!,maf=stall city) ~who uses a "maft" to delete the maf/run off map only
Old 05-06-2009, 02:44 PM   #6
piddster
Member#: 144285
1993 UHEV Legacy
A friend of mine ran his SS with it quite successfully. Garrett GT3076R at 21psi maxing his 650cc injectors.
If you want to use it's full capability you need a wideband.
Ej22t stock maf? 94EJ22TImpreza Pre-2002 Factory Turbo Powertrain 16 05-07-2010 05:14 PM
91 EJ22T engine EJ20 heads and intake MAF EJ22t Kid Legacy Specific Parts 3 04-23-2010 02:20 AM
AWIC, TGV delets, manifold, heads, EJ22T fateo66 Engine/Power/Exhaust 8 02-20-2010 04:26 PM
FS: New Fulmer drift helmet, Perrin AFTA MAF hose, Intake silencer delete elbow.... TK421 SCIC Private Classifieds 8 02-25-2008 12:02 PM
APS TGV deletes, Samco MAF hose, STi injectors, port/polish throttle body phlegmon Engine/Power/Exhaust 6 07-16-2006 04:08 AM
Message Board Statistics All times are GMT -4. The time now is 08:51 AM.
