Welcome to the North American Subaru Impreza Owners Club Sunday April 19, 2015
Old 04-17-2002, 10:20 AM   #1
JeffY
Member#: 15260
Unhappy HELP!!! Black smoke pour out my car
There are lots of black smoke comes out of my car when i was at idel. When i move, i cover the car behind me with black smoke.... Smoke seems to be less at a higher rpm... but that might because of the wind blow it away and i cant see while the car is moving... I have the turbo installed... running reg. FPR. i have an adjustable one putting in very soon... Is it because of the FPR couldnt handle the high flow pump?? I believe im runniing WAY too rich... Also, i adjusted the oil return line yesterday.... Could that cause the black smoke??? Anyone know how to put the adjustable FPR in?? Can i put it right before the RRFPR?? One more question, how do i adjust the RRFPR without a fuel pressure guage?? Thx... I did some search but im so confused
JeffY is offline   Reply With Quote
Old 04-17-2002, 11:09 AM   #2
8Complex
Member#: 922
04 FXT
Red
Fuel burns black.
Coolant burns white.
Oil burns blue-ish white.
You're probably running WAY too rich.
Old 04-17-2002, 11:13 AM   #3
JeffY
Member#: 15260
I know im running way too rich... And also it should be because of the stock FPR right??? Coz I should be having a very high fuel pressure... Will the adjustable FPR fix this problem?? and also, the stock fpr location cannot fit the aftermarket one in... can i put the aftermarket one just before the RRFPR??
Old 04-17-2002, 01:44 PM   #4
Jewbaru
Member#: 1994
2013 Impreza WRX
How long has the turbo been in? My car was running stupid rich, but wasn't leaving that much fuel behind.
Jewbaru is offline   Reply With Quote
Old 04-17-2002, 01:52 PM   #5
JeffY
Member#: 15260
i had it in for like around two weeks... There was no smoke before... The smoke just came pouring out a day or two ago... Its driving me crazy... I see it on my back mirror that i cover the poor guy at the back with black smoke....
Also, are u running a stock FPR??? Im planning to change it tonight or tomorrow and see what happen after...
Old 04-17-2002, 02:02 PM   #6
Jewbaru
Member#: 1994
2013 Impreza WRX
I was running the stock FPR for a while with the pump, I recently changed it.
Do you have anything to monitor the fuel pressure, of if the car's rich/lean? What are you using for fuel? AFC, RRFPR, TEC II?
Old 04-17-2002, 02:28 PM   #7
JeffY
Member#: 15260
I have RRFPR and AFC for fuel....
I heard AFC is not useful for 2000 car.. so i didnt touch that... the RRFPR i didnt adjust it yet coz im still waiting for my fuel pressure guage to come coz i have no idea what it is running right now...
so before u put an adjustable FPR in, did u have black smoke comes out?? I mean the car is like those old bus that smoke pour out from the exhaust
Old 04-17-2002, 02:35 PM   #8
Jewbaru
Member#: 1994
2013 Impreza WRX
No, I was not kicking black smoke like you describe. The only times it's done it were once after the car was sitting for 3 weeks, and again when I blew out a crapload of unburnt fuel (I think I shot a flame too!)
I hope your not driving around on boost without the RRFPR adjusted. If it's a constant stream of black smoke, you may have something seriously wrong.
Old 04-17-2002, 03:24 PM   #9
JeffY
Member#: 15260
oh my RRFPR was adjusted to run at 9 psi boost from the previous owner... I hope he didnt touch it after... If it is good for running 9 psi, it should be good for running 5 psi for me then?? RIght?? I hope i am right...
Old 04-17-2002, 03:40 PM   #10
Jewbaru
Member#: 1994
2013 Impreza WRX
to my knowledge, the RRFPR doesn't get "adjusted" to run 9psi. It ups the fuel pressure a certain amount for every PSI.
You might be just running REALLY rich, cross your fingers.
Old 04-17-2002, 04:00 PM   #11
JeffY
Member#: 15260
Old 04-17-2002, 05:04 PM   #12
Andrew
Member#: 1170
2005 STi
get a fuel pressure gauge, now. stock FPR is fine. what RRFPR do you have? is it the vortech unit? you say the AFC is hooked up? what are the settings on it. do you have a voltage clamp?
Andrew is offline   Reply With Quote
Old 04-18-2002, 01:26 AM   #13
JeffY
Member#: 15260
I have everything install except the fuel pressure guage. The RRFPR im using is from Bell. I also putted the aftermarket FPR in today. But i didnt take the stock FPR out yet... Does anyone know how to make an adaptor to replace the stock FPR at that location?? Or anyone know where to buy it... The aftermarket FPR helps a bit, i believe coz the smell of gasoline from the exhaust gas is not that strong now.... But sometime the smoke still comes out now...
The setting on the AFC is all zero now... I heard that the AFC does not help much on a 2000 RS coz the ECU relearns itself?? Correct me if im wrong... Also the AFC does not work once the voltage clamp comes in right??
Old 04-18-2002, 02:29 PM   #14
boysetsfire
Member#: 6218
2001 2.5rs-t
silverthorn metallic
i dont know if our smoke colors are the same but i had a problem with my oil return line not being steep enough and oil was backing into my turbo and coming out the exhaust.
boysetsfire is offline   Reply With Quote
Old 04-18-2002, 02:43 PM   #15
Jewbaru
Member#: 1994
2013 Impreza WRX
Oil burns bluish, not black.
JeffY:
Take out the aftermarket FPR untill you can remove, or gut, the stock FPR! You're fuel pressure is going to go thru the roof, and you may destroy a fuel injector/piston. I removed my FPR, and drilled out the core. You can get an adapter from Weapon R I think, don't know if they still sell them.
Old 04-18-2002, 03:05 PM   #16
JeffY
Member#: 15260
So i can take out the stock FPR and drill a hole into the core and put it back in?? Does this mod acts like a adaptor??
Boysetsfire: HOw do u fix that problem?? DO u just reroute the oil reutrn line?? Or u rebuild your turbo
Old 04-18-2002, 03:11 PM   #17
Jewbaru
Member#: 1994
2013 Impreza WRX
What you want is for the stock FPR to NOT resist the flow of the fuel. So by drilling the core, it allows gas to flow freely. You DO NOT want to drill a hole in it, and have gas all over your motor. You can also cut the FPR adapter off of your fuel rail, and attach some hose to that, run it to the new FPR, the RRFPR, and to the tank.
If you're not sure what to do, drop the $$ for an adapter.
Old 04-18-2002, 03:45 PM   #18
Andrew
Member#: 1170
2005 STi
the only way to get that adapter from Weapon R is to purchase their FPR as well.
Old 04-18-2002, 03:54 PM   #19
boysetsfire
Member#: 6218
2001 2.5rs-t
the guy that fixed my car just made the angle steeper on the retune line...now no more smoke.
Old 04-18-2002, 04:42 PM   #20
JeffY
Member#: 15260
Jawbaru: Which size drill bit did u use??
Old 04-18-2002, 06:33 PM   #21
Jewbaru
Member#: 1994
2013 Impreza WRX
Jesus, I don't remember. It was just barely large enough to fit in the side nozzle of the FPR. BE CAREFUL!!!! The FPR is tough and can break a drill bit.
Old 04-18-2002, 11:54 PM   #22
JeffY
Member#: 15260
Now, when we double check the car, it is actually a bulish white smoke... Which means is an oil burn... We can't figure out where it is leaking... We check all the spark plug, there is nothing wrong with it except it is cover with carbon (rich). Car sounds fine when idle and running.... There is no oil in the intake pipe or intercooler... We changed the oil and there is no coolent mix with it... Overall we believe is not engine damage.... Heavy smoke comes out when the car is under boost, light smoke when the car is off boost.... From those info, it seems like the seal in the turbo is broken and oil leaks from turbo... Is it right??? Correct me if im wrong...
Old 04-19-2002, 12:04 AM   #23
boysetsfire
Member#: 6218
2001 2.5rs-t
i dont know about yours but on my turbo the seal doesnt break it just opens when it gets too much back up. just make the oil return line steeper and it should go away after the excess oil burns out of your exhaust.
Old 04-19-2002, 12:36 AM   #24
JeffY
Member#: 15260
I did make it steeper but still no help... I think the seal is broken already... What type of turbo is yours?? Mine is a turbonetic T3/T4 turbo
Old 04-19-2002, 12:38 AM   #25
boysetsfire
Member#: 6218
2001 2.5rs-t
i have t3/t4 too but i dont know hwo makes it...i think it might be garret unless im an idiot and turbonetics is the only one who makes a t3/t4
Gas is just pouring out of my car ramoh Newbies & FAQs 25 08-04-2009 11:23 AM
Black smoke coming out of turbo/downpipe gi2005 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-08-2007 11:47 PM
OT DOCTORS: Sand is pouring out of my.... Turk Off-Topic 5 10-13-2006 02:19 PM
Help, What fell out of my car? SyD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-18-2002 12:23 AM
Uhh... smoke coming out of my hood vent.. Clutch? Siper2 New England Impreza Club Forum -- NESIC 14 06-10-2002 10:39 AM
