Old 04-16-2009, 12:34 PM   #1
Cool_Whhhip
Member#: 204664
Default Hybrid Help
Long story short i bought a bugeye with a fresh rebuild. After 1500 miles i took it to get tuned. It lost oil pressure and started knocking while on the dyno supposedly due to a bearing.
So i took it to the shop that did the rebuild and they at first did not want to warranty anything but finally they agreed if i bought the parts they would do the labor at no cost. So i said **** it and bought a 2.5l block along with all necessary gaskets, parts etc.
Well its been a month and a half and ive had to buy several additional parts here and there. No problem i just want my car done right and running properly.
So they called last week from the shop and said the timing belt was too long and the sti belt was the wrong belt. I assured them that it was indeed the correct belt to use. Then they called back the next day and said i needed a new tensioner. So i bought one and delivered it to them.
Well 4 days go by and no word so i decided to call them and they tell me that on the drivers side its leaking lots of oil from the head gasket and that the head doesnt match the block and the block is too big.
--Any suggestions?
They also say that the passenger side is fine and everything looks correct. There telling me that the STi 2.5l block is not compatible with my 2.0l heads.
How is that so?
Before i have it towed to a subaru specialist and pay out my ass for more work and diagnosis. Does anyone have any suggestions or ideas to how the drivers side head would not match the block but the passenger side would?
Thanks in advance.
Cool_Whhhip is offline   Reply With Quote
Old 04-16-2009, 12:49 PM   #2
AWDWRXLOVER
Member#: 50267
02 built hybrid
sr55/meth/sick speed
was the head checked/decked before sb install? this is a very common motor build that works fine even though the heads and block are different sizes.
AWDWRXLOVER is offline   Reply With Quote
Old 04-16-2009, 12:53 PM   #3
Cool_Whhhip
Member#: 204664
It was done on the original rebuild but i doubt the did it for the 2.5l swap.
Old 04-16-2009, 01:07 PM   #4
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
sounds like you should bring it to someone that knows how to build a subaru unfortunatly... the 2 liter heads fit on the 2.5 block fine, some people mention the machine work to fix the sizing differece in the heads but something is not right. Brand new block + Heads should not equal any leaks at all. Unless they forgot something when putting the valve covers on... there are those 2 half moons but i highly doubt they would miss something like that.
Bamofo is offline   Reply With Quote
Old 04-16-2009, 01:11 PM   #5
Cool_Whhhip
Member#: 204664
Well i plan on going to the shop today once i get off work so i can take a look for myself. Then ill prolly have it towed to my tuner who charges an arm and a leg for anything and everything.
Old 04-16-2009, 01:28 PM   #6
Cool_Whhhip
Member#: 204664
appreciate the help...
if anyone else has any advice or suggestions before i go and take a look please let me know.
Old 04-16-2009, 01:32 PM   #7
MrSlowbaru
Member#: 129231
2005 wrx
cgm
it could be possible that if they did not torque the heads down in the proper sequence that they have warped and are now leaking.
MrSlowbaru is offline   Reply With Quote
Old 04-16-2009, 01:37 PM   #8
Cool_Whhhip
Member#: 204664
Well one of the guys at the shop owns a STi and i hope he would know what hes doing especially when coming to proper torque measurements.
What about re-using the head studs?
I wonder if they re-used them.
Old 04-16-2009, 01:52 PM   #9
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
Reuse is usually ok, torque sequencing is a big issues though
Fongers is offline   Reply With Quote
Old 04-16-2009, 02:19 PM   #10
05ForesterXT
Member#: 199474
Get it towed to a shop that knows Subarus. Cheap labor is always comes out to be more expensive. I would never take my car to a placed that did a motor build that failed after 1500 miles. You made a deal with the DEVIL!!!!
05ForesterXT is offline   Reply With Quote
Old 04-16-2009, 02:46 PM   #11
hxcjohnny
Member#: 152380
2004 Wrx Sport Wagon
San Remo Red
+1
Find a subaru tuner/builder somewhere and see them. those other kinds of shops always scare me. the boxer motor isn't your grandpa's 350.
hxcjohnny is offline   Reply With Quote
Old 04-16-2009, 03:51 PM   #12
Cool_Whhhip
Member#: 204664
Originally Posted by hxcjohnny View Post
+1
Yeah im going to take it to my tuner and tell him to be gentle. All they work with is Subaru.
Old 04-16-2009, 10:09 PM   #13
Cool_Whhhip
Member#: 204664
I wont be able to have the car towed until saturday but it looks like the head needs to be machined and re-surfaced.
The mechanic said it it had 150 compression across the board except one cylinder had only 20.
Enguinty or OPENECU Map for Hybrid - HELP? Fongers Built Motor Discussion 13 08-11-2007 06:09 PM
hybrid help... ted dibiase Mid West Subaru Owners Club Forum -- MWSOC 7 05-24-2007 01:23 PM
2.0/2.5 hybrid help subymanny04 Built Motor Discussion 9 05-14-2007 01:09 PM
2.5 hybrid help red92xblue Built Motor Discussion 48 03-23-2007 02:07 PM
Turbo sizing for EJ22T hybrid help seven881 Normally Aspirated with bolt-on Forced Induction Powertrain 4 06-04-2003 03:12 PM
