Old 04-16-2009, 02:11 PM   #1
Deserted1
Member#: 110902
2010 Toyota Tacoma
Super White
Default Can a boost leak cause a knock?
Can a boost leak cause a knock, im talking post turbo. If the car is tapering boost by 2psi ish too much will that cause a knock. I had a boost leak for a bit and just found it. Just wondering cause if it can then maybe I have more room for tuning. If no then I guess my car is just running at its best and I should be pleased. Its fast now but maybe theres a bit more there you know.
Deserted1 is offline   Reply With Quote
Old 04-17-2009, 01:53 PM   #2
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Assuming you're running the MAF sensor in the stock location (upstream of the leak), then leaking air post-turbo will cause the car to run rich, which will cost you some power.
Unless you were tuned with the leak, in which case fixing the leak will cause the can to run leaner than it was tuned for. That could be bad.
You'd need a WBO2 to know for sure what's going on. Got one?
Old 04-18-2009, 02:02 PM   #3
Deserted1
Member#: 110902
2010 Toyota Tacoma
Super White
yes my lc-1 and logging it the wideband looks fine. not running any leaner after fixing the issue. im sure it was affecting the tune at some point but doesnt seem to be affecting it after fixing it. strange.
Great Catch cans and boost leak testers Chrisgst99 Car Part Reviews 1 07-02-2009 04:07 PM
boost leak cause high egts? WRXout Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-16-2004 12:03 PM
boost leak causing lag? HubbieScooby Normally Aspirated with bolt-on Forced Induction Powertrain 2 04-15-2004 04:23 PM
can an uppipe leak cause my car to feal sluggish? vapore0n Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-18-2003 11:17 AM
can a boost leak cause high egts? WRxednEffect Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-06-2002 12:22 PM
