Old 04-16-2009, 02:42 PM   #1
Messier77
Member#: 200215
2010 WRX Limited 5DR
SSM
Default Swaybar Squeaking Problems Always Return -- How can I stop them for good?
I've got a stock 05 WRX sedan and I've been having problems with the front Sway Bar squeaking like crazy over every bump I hit with my passenger front side.
I've had the sway bar bushings greased multiple times and the squeaking always comes back after a month or so.
Is there anything I can do to stop this squeaking for good?
If aftermarkets are the only solution, what parts should I buy and are there any that have a reputation for being exceptionally quiet?
Thanks
Messier77 is offline   Reply With Quote
Old 04-16-2009, 02:49 PM   #2
hcsi99
Member#: 115175
2004 Impreza WRX
2012 Outback 3.6R
I would get a creaking over bumps from my front sway bar bushings over dips in the road. I used a silicone lube and it seems to last around a year. I can't remember what it's called but it seems a lot like the same silicone grease that is used for caliber slides. It repels the water and doesn't wash out. Looks a lot like Vaseline.
hcsi99 is offline   Reply With Quote
Old 04-16-2009, 02:56 PM   #3
teiva-boy
Member#: 22825
Wrap with teflon tape used for plumbing. Light grease on that, and done.
Generally though, rubber bushings dont squeak as bad as urethane. I'm intrigued with your issue.
teiva-boy is offline   Reply With Quote
Old 04-16-2009, 03:17 PM   #4
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Actually, with a stock swaybar, and stock rubber bushings do not lube them. Get in there, remove the brackets and remove all grease from the bushings. See how that works for you.
Arnie is offline   Reply With Quote
Pillow Ball rear end links - how do you stop them from clunking on the rear sway bar? seps_wrx Brakes, Steering & Suspension 10 09-14-2006 08:42 AM
how can I stop biting my damn fingernails? pityr Off-Topic 27 08-02-2006 01:29 PM
Blew 2 KYB AGX simultaneously; how can I get them replaced? powerlabs Brakes, Steering & Suspension 5 05-24-2006 07:22 PM
How can i stop the SQUEAKINESS?! em prez uh Brakes, Steering & Suspension 7 10-04-2004 12:01 AM
Japan region DVD's - how can I play them? maaw Bay Area Impreza Club Forum -- BAIC 7 12-29-2003 09:31 PM
