Welcome to the North American Subaru Impreza Owners Club Tuesday October 6, 2015
Old 04-16-2009, 03:07 PM   #1
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Default Which Other Cars Have the Same Throttle Plate as an 05 RS
So I want a throttle plate to experiment with so that I don't ruin my only one. Turns out that Subaru doesn't sell the throttle plate, you have to buy the whole throttle body. That's a chunk of change for a flat piece of metal with two holes in it.
I'm hoping that I can get one from a junk yard. While I can obviously steal one from another 05 RS, that's a pretty small target to hit. What other years/models have the same throttle plate? Does it have to be a DBW throttle body, or did the older cable throttles use the same plate?
Old 04-16-2009, 04:05 PM   #2
Member#: 195354
Ebay has some throttles that, iirc, say they fit teh imreza, baja, maybe a couple others...
sa4baru is offline   Reply With Quote
Old 04-16-2009, 05:35 PM   #3
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
I would say 05+, I think.
Counterfit is online now   Reply With Quote
Old 04-16-2009, 05:38 PM   #4
Member#: 206371
2008 Impreza 2.5i
+1. While I don't have access to ebay at work, I'm guessing you could probably find a used throttle body on there for pretty cheap. I had to do that once or twice with my old Honda when the TPS went out, as you can't just get the sensor, you have to replace the whole throttle body.
twentytwomonk is offline   Reply With Quote
What other brand cars have the same wheel specs? chimchimm5 Tire & Wheel 3 09-22-2007 09:10 PM
Do Group n top hats have the same serial number as stock ones?? STI1981 Newbies & FAQs 4 09-06-2005 11:03 PM
Our Wrx's have the same c/d as the sleek Audis! SUPAREX General Community 14 06-12-2005 03:11 PM
What other cars have the same tranny? Rickyh Transmission (AT/MT) & Driveline 0 11-29-2003 11:41 AM
what cars share the same bolt pattern as the WRX?? 516_WRX Brakes, Steering & Suspension 2 12-11-2002 08:08 PM
