04-16-2009, 06:54 PM | #1 |
Member#: 160991
Vehicle:05 Corn Burner Dirt Silver? |
Stock Header VS. Borla UEL
I am wondering which one flows better? I know the diameter of the borla is bigger, but since the stock is almost EL, would it flow better? it just kinda popped into my head on my way home from work today. It seems like I have lost some down low power on my RS, but I can't think of why?
I have Torque grind cams from Delta Borla UEL headers STi Mid-pipe Devil Axle-back Any thoughts?
04-16-2009, 07:06 PM | #2 |
Member#: 153861
Vehicle:2008 WRX hatch WR Blue |
I also have borla uel's on my 07 2.5i. They do indeed flow better than the stock el's. But all past arguments say that the aftermarket el's flow better than the aftermarket uel's........ but you dont get that sexy boxer rumble from the el's like you do with our borla's.
04-16-2009, 09:59 PM | #3 | |
Member#: 1748
NESIC
Vehicle:'09 Outback Sport OBP over DGM |
It seems like when the piping gets too big for the 2.5i, it costs you on the low end. I think that most folks say 2.25" to 2.5" is about the size you want. Anything bigger and it starts to cost you in the low end. |
04-17-2009, 02:34 AM | #4 |
Member#: 153861
MY borla header and catpipe are 2.25 and i think my catback is some weird number like 2.36??? lol i dont know but its made for the 2.5i/2.5rs.
04-17-2009, 02:37 AM | #5 |
Member#: 137398
E. Canada
Vehicle:2004 Impreza |
Maybe the OP can benefit from some open source tuning.
04-17-2009, 09:32 AM | #6 |
Member#: 208881
Do you all have a 2 small pipes coming from the engine on either side (4 all in all) then further on it joins to two and then 1? I got custom headers made but in only gets to 2.5" when in gets to the main zorst. the 4 to 2 and the 2 to 1 pipes are alot thinner then the main zorst. Is this right?
Sorry for the hi jack. |
04-17-2009, 09:36 AM | #7 |
Member#: 160991
So.. Which do you think will flow better? The UEL is a lot longer and is a bigger diameter, but the stock is more direct to the cat?
OEM vs Borla UEL header - acoustics | Bluefoton | Normally Aspirated Powertrain | 60 | 02-11-2010 06:12 PM |
P+P Stock Headers Vs Aftermarket | Rokkit | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 295 | 04-09-2007 03:16 PM |
wrap on stock headers vs aftermarket w/ wrap? | OvrClkdPmp | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 12-31-2005 12:52 PM |
Techworks Header vs Borla | Kevin Thomas | Normally Aspirated Powertrain | 105 | 06-12-2005 11:56 PM |
Gruppe-S header vs Borla | spankaveli | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 08-31-2004 10:41 PM |
