Old 03-06-2009, 08:53 PM   #1
07ImprezaMB
Member#: 153861
2008 WRX hatch
WR Blue
Arrow 07 2.5i header back exhaust install.
Ok guys march 20th im putting my full exhaust on my car (borla header, stromung high flow cat, apexi n1 catback, kartboy hangers) Im just waiting on my header gaskets and o2 extention. Im going to post numerous pics before and after and some random pics of me doing the work.
But i just want to make sure i have everything squared away. So if anyone would like to give me some pointers or tips on something i may have missed or something to make intall a little easier, im all ears. Even problems i may run into and how to resolve them. So plz give me your input and thanks alot!
07ImprezaMB is offline   Reply With Quote
Old 03-07-2009, 01:31 AM   #2
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
don't drop the stock exhaust manifold on your head, that SOB weighs like 500 pounds
olsen726 is offline   Reply With Quote
Old 03-07-2009, 02:31 AM   #3
SubiFTW
Member#: 138728
MY06 2.5i Impreza
Are you buying the 02 extension?
You can easily make one for like $5.
Also, where'd you get the gaskets from and how much, one of mine is sorta done for, not sure wtf happened.
SubiFTW is offline   Reply With Quote
Old 03-08-2009, 09:15 PM   #4
07ImprezaMB
Member#: 153861
2008 WRX hatch
WR Blue
Post
already purchased the extension, didnt even think about making one to save money. but i paid 13.99 for my header gaskets plus 5 for shipping from www.boxer4racing.com
Old 03-08-2009, 09:27 PM   #5
07ImprezaMB
Member#: 153861
2008 WRX hatch
WR Blue
^ nice pointer ill try not to drop them lol
Old 03-08-2009, 09:40 PM   #6
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
i had trouble with the header to catpipe gasket and the catpipie to midpipe gasket (the "donut", as its commonly referred to) just make sure you have absolutely no leaks upstream from the O2 sensors or it will effect the O2 readings which will in turn effect your CL fueling.
GrundleJuice is online now   Reply With Quote
Old 03-08-2009, 09:44 PM   #7
07ImprezaMB
Member#: 153861
2008 WRX hatch
WR Blue
ok ill be sure to do that, thanks alot.
Old 03-11-2009, 03:00 AM   #8
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
Bolt your headers to your motor first. Tighten them.
Next, cat pipe. Keep to bolts loose between the header/cat. Tighten the one bolt to the tranny mount first!
Then tighten the header/cat bolts.
I have changed mine so many times haha
bue car is offline   Reply With Quote
Old 03-20-2009, 09:39 AM   #9
07ImprezaMB
Member#: 153861
2008 WRX hatch
WR Blue
Ok guys tonight is the night. I am putting on my header back exhaust. either late tonight or tomorrow i will have pics posted on here. I cant wait. But any last minute suggestions or comments let them fly!!!! Thanks
Old 03-20-2009, 10:21 AM   #10
kero
Member#: 94299
2000 2.5 RS Sedan
SRP
^^ Yes, make sure the 02 extension doesn't hang near the exhaust anywhere.
kero is offline   Reply With Quote
Old 03-20-2009, 11:56 AM   #11
fastenova
Member#: 38829
Not your usual 1997
Legacy GT
This may be totally obvious but just tossing it out there:
Make sure not to connect your o2 sensors until after they are reinstalled. Also disconnect them before you put a wrench on the sensor.
Use a flare-end wrench on the o2 sensors if you can, much lower chance of rounding off the flats.
You will likely require a o2 spacer (spark plug non-fouler x2 or an actual machined spacer) to remove your rear o2 sensor from the exhaust stream in order to avoid CEL codes related to cat efficiency, unless you plan to use opensource to turn off that CEL flag (not sure how to do this, just know it's possible on newer ECUs).
Use windex as a lubricant on the KB hangers, they're kind of a PITA to get on, but then again I did it with the car just barely jacked up (not a good idea, would be 20x easier on a lift). The windex won't leave a residue and will not damage the urethane.
Check for clearance between the headers and your power steering rack/lines, crossmember, and front swaybar after installation. Mine was too close the first time I installed it and rattled. I actually installed a "custom compound gasket" comprised of two OE header gaskets on each side with hi-temp red RTV silicone in between. You probably won't have to do that but it's just an idea if you run into clearance issues. If you do that make sure to apply just a little extra torque to the nuts on the exhaust studs since you're compressing more material. Also, make sure the silicone cures for a least a few hours before you start the car up... Otherwise you're guaranteed leaks.
Best of luck!
Aaron
fastenova is offline   Reply With Quote
Old 03-20-2009, 12:35 PM   #12
Mittelstadt
Member#: 184301
What about the torque specifications on the headers? 37 ft/lbs or something like that isn't it?
Mittelstadt is offline   Reply With Quote
Old 03-20-2009, 12:38 PM   #13
fastenova
Member#: 38829
Not your usual 1997
Legacy GT
I honestly don't know on the 06 models. I think that may be listed in one of the header install threads.
Old 03-20-2009, 06:26 PM   #14
07ImprezaMB
Member#: 153861
2008 WRX hatch
WR Blue
Thanks for the info guys, i take my car down to my friends garage at 7 so hopefully everything goes smoothly. ill post pics later on tonight if all goes as planned.
Old 03-21-2009, 04:31 AM   #15
07ImprezaMB
Member#: 153861
2008 WRX hatch
WR Blue
Talking Happy!!!
Hey guys so my headerback exhaust was a complete success and fairly easy to do. I did not need the o2 spacer, with the just the extension it worked fine. No problems what so ever, no cel's, nothing. A very clean, very nice install. And omg is the sound sexy. I drove out almost a full tank of gas tonight after i got it done. Anyone with a 2.5i wanting something to give them that boxer wrx rumble and increased torque and power this is a must!!!
I have some pics on my camera, some before and after, pics of the install and pics of my old parts from the car. I will post them tomorrow or monday when ever i get the card adaptor from my friend to upload them.
Old 03-21-2009, 05:53 AM   #16
SubiFTW
Member#: 138728
MY06 2.5i Impreza
You may still need an O2 spacer, I thought I was good to go too but then after about 500 KM's the CEL popped up.
Old 03-21-2009, 09:35 PM   #17
07ImprezaMB
Member#: 153861
2008 WRX hatch
WR Blue
ok ill keep that in mind, thanks.
Old 03-21-2009, 09:37 PM   #18
n/a boxer
Member#: 160645
2013 Brz
Nice I'd love to hear it man
Also where did you get an o2 extension from?
n/a boxer is offline   Reply With Quote
Old 03-22-2009, 11:08 AM   #19
07ImprezaMB
Member#: 153861
2008 WRX hatch
WR Blue
i got the o2 extension from www.casperselectronics.com
Old 03-22-2009, 11:16 AM   #20
Un0RiGiNaL
Member#: 189748
Take a video for us i wanna hear!
Un0RiGiNaL is offline   Reply With Quote
Old 03-22-2009, 12:38 PM   #21
07ImprezaMB
Member#: 153861
2008 WRX hatch
WR Blue
ok ill see what i can do
Old 03-22-2009, 04:51 PM   #22
deezy1987
Member#: 128345
2006 subie 2.5i
I have an 06 impreza 2.5i and I was looking for a borla header...I called borla and even they told me they dont make one for the 06-07 NA impreza...howd you get yours?
deezy1987 is offline   Reply With Quote
Old 03-22-2009, 05:02 PM   #23
07ImprezaMB
Member#: 153861
2008 WRX hatch
WR Blue
Talking
So here are some pics of the install..........
Stock manifold off.
Open block, old exhaust completly removed preparing for the header install.
Bolting up the borla header.
Have to reroute the o2 sensor wires the oposite way down toward the header. I just securley tied them down to other wiring harness's with zip ties.
Stromung high flow cat pipe put on and the o2 sensors hanging down before connecting them.
Mid pipe installed and a random pic of the guy helping me son lol........
Pic of my axle back, last piece of the install.
Everything is bolted up and fired her up to check for leaks.
The finished product.
Now after driving it around that night and the next day i had to go and retighten all the bolts bc once the gaskets setled and shrunk a lil from the heat it has a minor exhaust leak right after the cat. But it was a very simple, but time consuming install. Ended up very nice, no cel's, and a noticable increase in power and the sound is super sexy.
Old 03-22-2009, 05:05 PM   #24
07ImprezaMB
Member#: 153861
2008 WRX hatch
WR Blue
www.boxer4racing.com for the borla header.
Old 03-22-2009, 05:33 PM   #25
bcware
Member#: 190724
2008 2.5i Sedan
Lightning Red
would this header and high flow cat fit an 08? it looks very similar.
bcware is offline   Reply With Quote
07 2.5i. switching back n forth open/closed loop. subadub07 Normally Aspirated Powertrain 4 11-27-2009 09:52 AM
Need 07 2.5i Headers, Please Help djrasta Impreza Forum 5 11-10-2009 01:17 PM
F/S 07 2.5i axle back...less than 6k miles Jonny07subie Engine/Power/Exhaust 0 02-17-2008 12:39 PM
WTB: 2.5i Midpipe / 06/07 2.5i CAI Setup / Exhaust Shield deviantek NWIC Private Classifieds 3 08-17-2007 02:21 PM
07 2.5I Axle back exhaust db14dcs02wrx Engine/Power/Exhaust 1 05-02-2007 07:25 PM
