Old 04-17-2002, 11:24 AM   #1
DDMan
Member#: 11221
2002 2.5 RS
Black as Midnight!!!
Question Pulley's + Flywheel not good?
I'v heard that if you have either the lightweight flywheel or pulleys, to not get the other lightweight component because it can stall out your engine due to lack of rotational mass.
Is this true, and is there anyone out there who has both and is doing fine?
DDMan is offline   Reply With Quote
Old 04-17-2002, 11:59 AM   #2
RaceCarRiot
Member#: 6542
1997 Ver IV
you should be able to run lightened pulleys just fine with a slightly heavier lightweight flywheel, such as the JUN or exedy (~12lbs). however, something that's REALLY light like the fidanza (9lbs) will cause driveability problems.
-adam-
RaceCarRiot is offline   Reply With Quote
Old 04-17-2002, 02:33 PM   #3
biggreen96
Member#: 12535
vf39 06 5MT XT
92 Legacy Rally EG33'd
Just bump up the idle a tad and it wont stall out.
biggreen96 is offline   Reply With Quote
Old 04-17-2002, 03:18 PM   #4
2Point5RS
Member#: 3639
I thought the only problems occuring were with the underdrive pulleys and lightened flywheels.. Underdrive pulleys meaning they are smaller in diameter than the stock pulleys. You can get lightened pulleys, and still the same size diameter as stock and be problem free. This is just what I think, I don't know if it's true.
2Point5RS is offline   Reply With Quote
Old 04-17-2002, 03:37 PM   #5
RaceCarRiot
Member#: 6542
1997 Ver IV
in all honesty, i would just go with the lightest flywheel i possibly could, and just run the OEM pulleys...
my lightened ones have started causing problems since i've been running my a/c again:
http://www.i-club.com/forums/showthr...hreadid=173962
i don't know if 2.5L's will develop this problem over time, or if it's just due to my smaller displacement.
Old 04-17-2002, 08:47 PM   #6
DDMan
Member#: 11221
2002 2.5 RS
hmmm, hopefully there wont be the same problem. The only thing with getting a flywheel is that the process of installing is ALOT more involved.
Old 04-18-2002, 02:34 AM   #7
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
I am running a 13lb Exedy flywheel plus a 1.2lb N1 crank pulley with no problems, and I have a 1st gear 15% taller than stock...
Larry
www.SubaruPlanet.com
ImprezaRS dot com is offline   Reply With Quote
does anyone with a lightened flywheel not have noise? happasaiyan Transmission (AT/MT) & Driveline 48 06-09-2008 07:09 AM
The first gen Subaru Legacy platform, good? not good? esplainplz. scuzzy Off-Topic 30 12-28-2007 01:10 PM
Putting car in storage for a year. Good or not good? tankerWRX Newbies & FAQs 21 05-10-2006 04:13 PM
what a good/not-good idea! free BOV mod iloveturbos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 09-12-2002 06:26 PM
