Old 04-16-2009, 09:03 PM   #1
rsuba
Member#: 116129
2002 sti Prodrive
black
Default Jdm Ecu
Hi
I try to put a jdm V7 ecu in my 2002 wrx (EDM) but i dont have any signal of the ecu .
I put again my car ecu and itīs ok.
I put the jdm ecu and i found the two conectors of the power supply the reading is 0V and when the factory ecu is connected the two wires have 12V.
Itīs the immo or another problem.
Rui S.
rsuba is offline   Reply With Quote
Old 04-17-2009, 10:30 AM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
evn if it were wired the same the mapping would be differnt (boom)
put your stock ecu back in and get it tuned -for a better result
Old 04-17-2009, 11:12 AM   #3
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
V7 ECU doesn't have immobilizer
won't work
Hyper is online now   Reply With Quote
Old 04-19-2009, 12:18 AM   #4
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
neither does the 02 wrx ?
Are you sure the V7 ecu isn't fried ?
Oh wait EDm is different, I had the same problem
sense of nature is offline   Reply With Quote
Old 04-19-2009, 04:42 AM   #5
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Your WRX doesn't have AVCS, the V7 STI does. Won't work.
Marnix is offline   Reply With Quote
2002 wrx ecu, jdm ecu hybridpatient95 Engine/Power/Exhaust 2 04-22-2008 04:53 PM
2002 wrx ecu, jdm ecu hybridpatient95 Engine/Power/Exhaust 0 04-20-2008 12:56 PM
JDM ECU paired with US ECU - pro & cons cjfike Engine Management & Tuning 12 01-28-2006 12:12 AM
how do I pull ECU codes from '97 JDM ecu?? Pacobeagle Engine Management & Tuning 5 05-31-2005 01:10 PM
JDM ECU for EJ20 (Yes I have done a search) markus Normally Aspirated Powertrain 9 02-25-2001 12:48 AM
