Old 04-17-2002, 11:50 AM   #1
Cjchaps
Member#: 3181
07 Rav4
Unhappy Dealer/SOA responses to WRX 1st gear grinding problem.
I know this topic has been beat to death, but I would like to know what responses everyone has got from their dealership or Subaru of America in concerns with the downshifting into 1st great grinding problems on the WRX.
I will start. I took my WRX in with 7000 miles on it late last year, and told the dealer the problem. Basically, the only way I can shift into first is if the car is at a standstill. I cannot downshift into first from 2nd gear going even 5mph. It also sometimes crunches/grinds when I cam completely stopped going into first gear. So I left it at the dealer, and they said it was normal, and there were no problems. I plan on following up on this sometime this year, but I have not had the time yet.
**For all of those people who are going to say:
-blip the throttle
-rev match
-double clutch
-any other way to get into first while moving
I didn't pay 24 grand for a car that I have to screw around trying to get into first gear with. I paid for a car with a fully synchronized transmission, so that when I am traveling at 5mph in order to go into 1st gear, I CAN! I didn't pay 24 grand for a car so that I could try to rev match and hope the transmission doesn't grind at every stop sign I come up to.
Cjchaps is online now   Reply With Quote
Old 04-17-2002, 12:03 PM   #2
ChrisW
Member#: 4181
2003 Lancer Evo 8
It's Blue, ok?
sorry dude,
don't know what to tell that hasn't already been said...
come to a full stop and put it in gear.
FWIW, I can't downshift to first from any gear while moving fast enough for the speedo to register.
Doesnt' bother me a bit.
ChrisW is offline   Reply With Quote
Old 04-17-2002, 12:44 PM   #3
mbartel
Member#: 6059
2002 WRX wagon
World Rally Blue
Have all kinds of tranny issues.
clutch studder, noise, difficulty getting into reverse etc.
I have always had troulbe getting into 1st, but in every stick car I have owned. All imports. Always thought this is the way it is. As if you specifically can't get into 1st for an engineering reason.
I know that I don't drive as hard as the rest. That could be part of it.
Mike
mbartel is offline   Reply With Quote
Old 04-17-2002, 03:54 PM   #4
JSiwek
Member#: 14909
Locking you out of first at any speed (unless you double-clutch to match revs) is pretty normal. The first gear ratio is so high that if you were to put it into gear while coasting at like 8 mph and let out the clutch a little too quick you'll lock the wheels and stall your car. Even if you let it out slow, it really, really, really engine brakes hard.... that's why our Subaru's will lock us out of first unless we're going super slow or we rev match (so the car knows we wont rape it if we accidently pop the clutch ).
Grinding into first, however, may be indicative of a bad pressure plate that isn't releasing all the way and therefore isn't allowing the gears to slow down enough. It was for me. If you shift much slower into first, rather than just sticking it in quick (ask wife about this) it wont grind. Unfortunately there's no easy way to see if your pressure plate is defective w/ out taking it out and looking at it..... if it starts grinding going into third under normal conditions w/ the pedal fully depressed and whatnot, or locking you out of second, you probably need a new clutch.
Jeremy
JSiwek is offline   Reply With Quote
Old 04-17-2002, 04:27 PM   #5
mbartel
Member#: 6059
2002 WRX wagon
World Rally Blue
Yes, on all the above.
For fun I went out this lunch our, and tried several tests of going into 1st at different speeds. Everything behaved as I would have expected. It needs to lock you out in certain situations. Like stated above. Under the right speeds or rev match I got into 1st no problem. Under the knowingly incorrect situations it did not allow me. I could have ground it in there with some force, but didn't.
This by the way is my experience with any manual car I have owned. All imports.
Mike
Old 04-17-2002, 04:39 PM   #6
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
The 5MT i put in my car from a 91 Sports Sedan is basically the same transmission as yours, and it does this exact same thing.
Is it annoying? Yeah.
Should you complain about it? Not really.
Should SOA fix it? They probably have fixed it in the 6MT.
Does synthetic fix it? A friend with the same tranny has Redline, it shifts into 1st at 10MPH+.
Another friend with a 98RS can shift into 1st at 10-15MPH if he rev matches perfectly. It's taken him a while to get the hang of it, but i can say from first hand experience that it can happen.
Dave
DLC is offline   Reply With Quote
Old 04-18-2002, 12:14 PM   #7
Narcisse91
Member#: 3931
WRX, Ninja, RX-7
Legacy, Fiat 850
Someone should write a "how to drive a manual" FAQ and stick it somewhere.
From the day I learned to drive (first time was in a '92 Legacy, MT), I've driven nothing but standards, and NONE were designed to shift into 1st while moving. Yeah, you can rev match to get it in, but a lot of cars lock you out of first till you stop. I'm curious how many cars are designed poorly enough to let you shift into 1st whenever you want.
Narcisse91 is offline   Reply With Quote
Old 04-18-2002, 12:23 PM   #8
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Sedan, White WRX Wagon
I concur - I have driven my dad's 97 Outback, and my 92 Impreza will NOT shift into first unless you're practically at a standstill
CirrusWRX is offline   Reply With Quote
Old 04-19-2002, 01:59 AM   #9
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
My old tranny did this at 10+ mph, unless I used ATF instead of gear oil which then I could stick it into 1st at 25 mph with clutch in and no rev match, but ATF is only GL-4 rated.
With new Chalak gearset just in on Tuesday I can now shift into 1st at 30+ mph with ease, using plain GM brand 80-90 GL-5 gear oil from a 20 gallon drum at SubySports.
I still prefer to double clutch to save the synchros. FWIW, my 84 CRX will shift into 1st at 30 mph with 10w-30 motor oil in the tranny, my old 1987 and 1988 Integras would, as well as my 93 SHO. Suby is the first car I owned that hates downshifts to 1st without double clutching...
ImprezaRS dot com is offline   Reply With Quote
Old 04-19-2002, 05:04 AM   #10
Shinji N
Member#: 3987
1999 Miata
hahaha and how many of those lock you out of first when you're standing still?
Shinji N is offline   Reply With Quote
Old 04-19-2002, 12:36 PM   #11
sperry
Member#: 8636
OBXT NA8-Miata F250
no more SVX or WRX :(
That's a "safety" feature added by Ford engineers to our cars so their Mustangs don't get burned at every stoplight.
--Scott
sperry is offline   Reply With Quote
Old 04-19-2002, 01:50 PM   #12
SAF
Member#: 15129
2002 Impreza WRX
metalic
There was a thread in either "Maitanance" or "Warranty" forums couple months ago on exact same issue. It seems to me that it was established conclusively that WRX transmission was designed to shift into 1-st gear while moving at speeds less than 12 mph. If it does not then it's a problem with synchros and they should fix it.
I don't understand the argument "it's supposed to do that". What do you do when you are in traffic and the car is rolling at about 5mph and you need to start accelerating? The speed is too slow to shift into 2-d and coming to complete stop in heavy traffic is plain dangerous. I drove 3 manual transmission cars (imports and domestic), none of them had that kind of problem. My WRX goes to 1-st even at 20 mph.
SAF is offline   Reply With Quote
Old 04-19-2002, 05:24 PM   #13
jmott
Member#: 6713
2007 Prius
brown
Default Re: Dealer/SOA responses to WRX 1st gear grinding problem.
yes, you did.
jmott is offline   Reply With Quote
Old 04-19-2002, 05:36 PM   #14
russellh68
Member#: 7197
2002 WRX Wagon
Thumbs up
11k on the ODO, 3 auto-x runs last Sunday, 2 downshifts per run into 1st at 15-20 mph, no grinding. My opinion is that my WRX 5MT shifts just as smoothly as my '93 Integra did. I must have a tranny that was built on a Wednesday!
How many of you that are having trouble have changed the fluid? I am still on the stock stuff that came in the car.
russellh68 is offline   Reply With Quote
Old 04-19-2002, 06:47 PM   #15
mbartel
Member#: 6059
2002 WRX wagon
World Rally Blue
no 1st gear issue, but everything else, and I never changed the fluid. ONly 6k miles
mike
Old 04-19-2002, 08:17 PM   #16
Austin
Member#: 7089
2016 STi
Default Re: Re: Dealer/SOA responses to WRX 1st gear grinding problem.
Originally posted by jmott
yes, you did.
Austin is offline   Reply With Quote
Old 04-19-2002, 11:30 PM   #17
subymamma
Member#: 2575
2008 Forester 2.5X
Dark Gray Metallic
We drove Volvos for 20 years before buying Subaru. I can't remember the early ones we had but the last Volvo we bought in 1990 and drove for 10 years never would let you shift into 1st unless at a standstill.
subymamma is offline   Reply With Quote
Old 04-20-2002, 02:31 AM   #18
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
My buddy Supermarkus here took me for a ride (as I'm without turbo) and he showed me that indeed it's easy as pie to get the tranny in first at about 10-15mph, IF you rev-match.
Here's a free hint: Revmatching a synchronized transmission doesn't have to be an exact science. Get it to the approximate rpm, and let the synchros do their job.
Trying to shift into first gear while traveling at 10mph and 600rpm is just plain old stupid. Bring the revs up to three grand (or whatever range they should be at) and slowly push into first. Then let out the clutch. It's easy and simple.
Now... I've gotta swap the tranny fluid back to some thicker stuff. That Mobil 1 is killing me. I'm shifting 3 to 4 faster than the synchros can work and grinding every time.
CosmoTheCat is offline   Reply With Quote
Old 04-20-2002, 02:48 AM   #19
Austin
Member#: 7089
2016 STi
You're correct Nick, but some cars (mine included, before it was repaired by the dealer) simply don't seem to have synchros. The *only* way to get the car into first while moving is to double clutch. You can't just rev-match.
Old 04-20-2002, 12:42 PM   #20
Heavy Fuji
Member#: 5536
'11 Tundra
Austin, I hear you. For the first 25,000 miles or so my tranny easily accomodated my usual habit of blipping the throttle (with the clutch in) and shifting from second into first for a rolling stop. This is no longer possible and double-clutching has become a necessity, and is perhaps the proper method anyway. If I do forget, the transmission lets me know and "grabs" first while grinding in protest.
Really irritaing in traffic; thank God my commute is rarely stop-and-go. Here comes the apples-and-oranges comparison: My 1994 SE-R was reluctant to go into first if not rev-matched but a few revs and the lever would snick right home. 125,000 miles and still shifts like new, after much abuse...
Heavy Fuji is offline   Reply With Quote
Old 04-20-2002, 01:55 PM   #21
CosmoTheCat
Member#: 3409
98 My FMIC
OK so I've got a question...
My RS is a lot more reluctant to go into first (without grinding) since I put that Mobil 1 crap in it. How many of your with problems hitting first gear have non-stock transmission fluid?
Old 04-20-2002, 11:41 PM   #22
Scuby Snacks
Member#: 17730
This problem of getting into 1st almost killed me tonight when trying to do a u-turn and I slowed down to 5mph to get it into 1st but it wouldnt go so I shifted into 2nd and slipped the clutch while cars are flying past me. Later on, I could not get it into 2nd gear and when I did, it grinded like mad. I have heard of others having problems getting into 2nd as well and this was not my first time encountering this problem. I now only have 3000 miles with stock trans fluid.
Scuby Snacks is offline   Reply With Quote
Old 04-21-2002, 12:16 AM   #23
Austin
Member#: 7089
2016 STi
The wrx had Redline 75w90 for around 10k miles before I had the first/second gear sychros replaced. It's had Redline 75w90 for 15k miles since with no problems. I was fairly quick to dump all the fluids that came in the car.
The RS has also had redline 75w90 since day one with no tranny problems ever. I'd tell you the number of miles, but that data was sort of lost since the guage cluster was switched to an sti cluster... About 16000 km since the switch, though.
Old 04-21-2002, 09:45 PM   #24
cmaj7
Member#: 12677
2002 Subaru WRX
WR Blue
Default Suggestions to minimise the problem
I've got STI Short Shifter, Karboy Bushings, STI Grp N Tranny mount, Redline 75w90ns in Tranny.
Shifts like butter, still is stiff going into first, but when I feel a lot of resistance I release the clutch slowly while gentle pushing the shifter forward, it will usually pop right in.
I read a couple of posts that indicated air in the clutch line might also cause this problem. So bleeding the clutch line might help.
I intend replacing the clutch line with a SS version and flushing the system next.
Allan
cmaj7 is offline   Reply With Quote
Old 04-21-2002, 10:12 PM   #25
mbartel
Member#: 6059
2002 WRX wagon
World Rally Blue
Please forgive the ignorance, but I'll ask cause I want to understand.
STI Short Shifter, understand that and want it
Karboy Bushings, for what and why?
STI Grp N Tranny mount, why?
Redline 75w90ns in Tranny, why? performance? is the stock stuff water?
btw cmaj7, nice handle, are you a musician?
I am/was www.bostonconservatory.edu/michael
Mike
1st gear grinding 2002 wrx filipin0y Newbies & FAQs 32 06-20-2013 03:30 AM
WRX 1st Gear Synchro Problems Cjchaps Warranty Issues & SOA Problems 91 11-23-2011 01:09 PM
2004 wrx 1st gear grinding? awdguy Transmission (AT/MT) & Driveline 11 08-26-2005 04:22 PM
UPDATE: 1st Gear Grind Problems SPeeDSiN South East Region Forum 14 07-23-2002 12:13 PM
1st Gear Grind Problem IT SUCKS SPeeDSiN South East Region Forum 27 07-18-2002 07:41 AM
