Old 04-16-2009, 11:51 PM   #1
PirateSanchez
Member#: 106020
Default Just curious, what oil do you run in your built motor?
Post break in, what oil do you run in your block?
I'm trying to figure out the best oil for a block with CP pistons 100mm and eagle rods, oem heads, and would love to hear what brand/viscosity oils you guys have had success/problems with.
Cheers!
PirateSanchez is offline   Reply With Quote
Old 04-16-2009, 11:53 PM   #2
AKSubieDubie
Member#: 190003
2007 STI EFR 8374
It kind of depends what your bearing clearances are / oil pump. I'm using 5w40 rotella... going to use some napa 10w40 for 2nd break in
AKSubieDubie is offline   Reply With Quote
Old 04-17-2009, 12:33 AM   #3
stu
Member#: 25768
35R OFCDV3 Bugeye
Slowbaru
valvoline synthetic 5 w30
stu is offline   Reply With Quote
Old 04-17-2009, 12:36 AM   #4
Tony1
Member#: 204092
2001 8 second Integr
Red
We run Brad Penn Racing Oil in all our engines. Amazing stuff and reasonably priced.
Tony1 is offline   Reply With Quote
Old 04-17-2009, 01:16 AM   #5
texas05sti
Member#: 126242
2005 STi/2012 GTR
TXIC's most loved
I also run the Brad Penn. They make a specific oil for break in and then 20w-50 post after that.
texas05sti is offline   Reply With Quote
Old 04-17-2009, 03:35 AM   #6
berdugo
Member#: 163108
07 EuroDM STi 2.5L
Mobil 20W-50 during break in, Amsoil SAE 60 after break in
berdugo is offline   Reply With Quote
Old 04-17-2009, 04:03 AM   #7
jays05
Member#: 78165
05 STI 35r + e85
Rotella 15w40. I am gonna try the Brad Penn 20w50 when it warms up a bit more.
jays05 is offline   Reply With Quote
Old 04-17-2009, 07:56 AM   #8
cribbie
Member#: 184505
2003 WRX
Sonic yellow
why so thick of an oil?
cribbie is offline   Reply With Quote
Old 04-17-2009, 08:05 AM   #9
berdugo
Member#: 163108
07 EuroDM STi 2.5L
because it's very very hot here in the Philippines, and I don't have an oil cooler. my oil temp is 220F and my oil temp sensor is placed in an oil sandwich adapter, I bet it's much hotter up there in the cylinder head area. 220F and not yet stuck in traffic, max oil temp I had was 240F
Old 04-17-2009, 08:55 AM   #10
Mr_Snips
Member#: 152117
2012 Ford F150 ECO
Also because its been proven the subies like a thicker oil...as in NOT MOBIL 1 5w/30
Mr_Snips is offline   Reply With Quote
Old 04-17-2009, 10:07 AM   #11
cribbie
Member#: 184505
2003 WRX
Sonic yellow
Wouldn't thicker oil retain more heat? Thinner oil will flow better witch means it is moving more oil across those high temp areas removing more heat. its like more coolant traveling quicker thru your rad.
Maybe I am thinking like a dinosaur and not grasping this entirely.
Old 04-17-2009, 10:22 AM   #12
q_dubz
Member#: 168482
thicker/denser oil has more molecules to take away more heat. think about how a intercooler work. the more fins there are internally the more heat it takes away.
q_dubz is offline   Reply With Quote
Old 04-17-2009, 10:29 AM   #13
trbowrx
Member#: 50770
08 STi
04 536whp STi Sold!
i run the Motul 300V 15-50 oil in my built block car and am having great luck with it!!
trbowrx is offline   Reply With Quote
Old 04-17-2009, 02:39 PM   #14
doza
Member#: 171420
2004 WRX Wagon
Mobil 1 15w-50 is what my tuner recomends but I cant wait for my car to warm up 10 mins before driving. This is in Texas where the super hot summers make cars very hot and the 15w-50 gives better protection at extreme temps...
doza is offline   Reply With Quote
Old 04-17-2009, 03:34 PM   #15
06njsti
Member#: 150986
06 #001 LSB STi
nobody runs any motul on the street?
06njsti is offline   Reply With Quote
Old 04-17-2009, 06:25 PM   #16
slowmike
Member#: 24890
2002 Jackwagon
WRB GG
My engine likes Rotella 15-40 now that's it's broken in
slowmike is offline   Reply With Quote
Old 04-17-2009, 09:40 PM   #17
Rickyh
Member#: 40453
plain valvoline 20w50
Rickyh is offline   Reply With Quote
Old 04-17-2009, 09:46 PM   #18
White out
Member#: 46277
** LP640
Viper GTS
+1
Nick
White out is offline   Reply With Quote
Old 04-17-2009, 10:23 PM   #19
Hayaboosted
Member#: 60042
2004 WRX STI
Rotated T67 ALLABOUTSPEED
Rotella 15w 40 for myself
Hayaboosted is offline   Reply With Quote
Old 04-18-2009, 12:01 AM   #20
trbowrx
Member#: 50770
08 STi
04 536whp STi Sold!
i do every day! look a few posts up
Old 04-18-2009, 12:17 PM   #21
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
I run castrol synthetic 5W50
wrx_driver_2002 is offline   Reply With Quote
Old 04-18-2009, 01:21 PM   #22
slava from goshen
Member#: 152176
2001 2xImpreza 2.5RS
BRP/SRP
so heavier is good for build (bored) engines? what about stock 07 sti engine that will see lots of abuse?
slava from goshen is offline   Reply With Quote
Old 04-18-2009, 01:27 PM   #23
RealStreet
Member#: 205916
2003 Subaru WRX
in the 10's and the bends
I run 10w40 of whatever I can find... Synthetic or not. Hell, I've even put Car Quest oil in my car. It all goes to the same place and does the same ****.
RealStreet is offline   Reply With Quote
Old 04-18-2009, 03:32 PM   #24
flycaster
Member#: 60142
2011 WRX
Grey
Originally Posted by doza View Post
Mobil 1 15w-50 is what my tuner recomends but I cant wait for my car to warm up 10 mins before driving...
Viscosity doesn't affect warm-up whatsoever, just oil pressure. I drive my car immediately after cold start, in below 0f temps, but I have to wait for the oil pressure to stabilize before I hop on it...I really don't understand your problem here.
flycaster is offline   Reply With Quote
Old 04-19-2009, 05:36 PM   #25
tekfoc
Member#: 21392
2014 45 AMG MB
WHITE /MB C300 4MATIC
IM running silkolene 10w 50 synthetic for a while . love this oil .
tekfoc is offline   Reply With Quote
Which Oil do you run in your Subie?? timemasheen General Community 2 06-22-2008 12:00 PM
What psi do you run in your tires? gtbensley General Community 61 06-01-2008 08:35 PM
Question: What brand/weight motor oil are you running in your Subaru? Black-STi North West Impreza Club Forum -- NWIC 43 08-02-2006 11:17 AM
what kind of oil do you put in your wrx? scoobypuff Southern California Impreza Club Forum -- SCIC 10 04-27-2002 01:59 PM
What octane fuel do you run in your 'preza? erice1984 Normally Aspirated Powertrain 0 03-23-2002 10:30 PM
