Old 04-17-2009, 08:00 AM   #1
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
Default How is the rotating assembly balanced?
I was looking for a good read that would explain the process of balancing the rotating assembly
I know the benefits, but I am really curious of what's involved
Is it worth to only do the crank if I am keeping stock STI rods and getting custom pistons?
Hyper is offline   Reply With Quote
Old 04-17-2009, 10:24 AM   #2
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
This is a good place to start.
http://www.fordmuscle.com/archives/2...mbly/index.php
If your using stock rods you will greatly benefit from balancing those alone. The pistons are normally within a gram if you use weisco but if you have a good scale you can get them to .1 gram. Since Subaru puts no effort into the 2.5 liter crank you might want to get that balanced too if your planning on doing over 8000rpm. But if your just looking to balance it for the heck of it rods and pistons is a really big improvement over not balanced.
Bamofo is offline   Reply With Quote
Old 04-17-2009, 10:39 AM   #3
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
ah damm, I have to register there to view the other 2 pages
The pistons I am getting are Diamond, so they will be balanced for sure
So I can balance each segment on it's own, or it has to be made all together? ie, have crank machined at one shop while having the rods at another (because parts are in different countries )
Old 04-17-2009, 06:28 PM   #4
Team Scream
Member#: 121532
2006 FXT/STi 6MT
01 Aerosim GC8 Coupe
Balancing the rods is simply making the big ends and the small ends all (each) weigh the same within a specified tolerance.
Your shop will take the lightest rod and make the rest weight the same at both ends.
Same with the pistons.....make them weigh the same amount.
Actually the crank, clutch and flywheel should be done at the same time because they are really the only things that get spun on a balancing system.
Rods and pistons you can do yourself with a scale and the proper jig for the rods as long as you know where it is safe to remove material and where you want to stay away from.
Team Scream is offline   Reply With Quote
Old 04-18-2009, 03:16 AM   #5
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
understand now, thanks
Old 04-18-2009, 01:24 PM   #6
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
You take your crank, flywheel, clutch, rods and pistons to the machine shop. They way each piston and rod, then bolt the equivilent weight to the crank for each rod and piston on each location.
Old 07-14-2009, 02:54 AM   #7
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
I'd like to bump this for a little more input
as Tilton clutch assemblies come balanced, would I have to include the flywheel to crank/rods/pistons if I wanted to have the crank balanced?
Old 07-14-2009, 06:55 AM   #8
col5555
Member#: 142017
Where do they commonly remove material from a piston??
col5555 is offline   Reply With Quote
Old 07-16-2009, 01:46 PM   #9
bertune
Member#: 107290
Pulley
bertune is offline   Reply With Quote
Old 07-16-2009, 09:01 PM   #10
madmax718
Member#: 172501
crank pulley is pretty well balanced rotationally- a few grams here and there, but a stock one is hard to balance since its made with rubber- and as it degrades, it shifts around like a loose goose.
Scrap the pulley, go with a fluid filled..
madmax718 is offline   Reply With Quote
Old 07-17-2009, 12:56 PM   #11
modaddict
Member#: 95840
sold to a good bud
awaiting next car
modaddict is offline   Reply With Quote
Where is the WRX assembled? paN1k Newbies & FAQs 7 01-15-2010 10:20 AM
how is the passenger window switch assembled? Der_Dude Electrical & Lighting 3 06-18-2006 01:38 AM
How much power increase with Greddy EVO2 and a downpipe? How is the Turboxs? 05STI!!! Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 01-11-2005 01:51 AM
How is the RX8 the COUPE of the year for MT when it has 4 doors? 03WRXMA Off-Topic 9 12-30-2004 11:19 PM
How is the quality of the Erebuni Kit? mattmounce Interior & Exterior Modification 0 04-11-2003 05:41 AM
