Old 04-17-2009, 12:46 PM   #1
STI_KLR
Member#: 189660
'02 WRX
Element Tuning Race Team
Cool Quick Hybrid Valve Lash Question
I dropped my heads off this morning at the machine shop so they can be shaved, cleaned, and have the valve lash checked/adjusted.
My question is, what should the valve lash be? The machine shop does not know what the tolerances should be for a hybrid build.
I'm running STI cams in 2004 WRX heads mated to a brand new EJ257 SB from Subaru with OEM STI headgaskets. The buckets are shimless.
TIA,
-Andrew
STI_KLR is offline   Reply With Quote
Old 04-17-2009, 12:54 PM   #2
benw
Member#: 103320
1998 swapped
Forester L
factory spec I believe is .008 intake and .013 exhaust. I run .008 in/.010 ex on my upgraded valvetrain/cams.
the fact that it is a hybrid should not have a large effect on valve lash I wouldn't think. the heads are the same regardless of what you bolt them to.
be careful that you don't remove too much material off the cylinder head. if you're just taking off a couple thousandths it shouldn't be a problem.
benw is offline   Reply With Quote
Old 04-17-2009, 01:12 PM   #3
STI_KLR
Member#: 189660
'02 WRX
thank you! i just want sure with the sti cams if it effected anything or not.
Valve lash question waym Built Motor Discussion 2 09-14-2009 01:53 PM
Stage 3 cam valve lash question Twiztidunreal Built Motor Discussion 2 02-25-2009 03:22 PM
valve lash question nkx Normally Aspirated Powertrain 10 08-04-2008 09:18 PM
Valve lash question. LiquidForce Built Motor Discussion 5 07-30-2007 08:58 PM
Valve lash questions Acostafan Built Motor Discussion 12 07-01-2007 02:16 PM
