Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 04-17-2009, 11:56 AM   #1
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
Default 1600cc injectors, what brand to choose!
So I have been steered away from my original DW1100's not being big enough for my stup and told to upgrade to 1600cc's. Originally, Phil from Element told me to go with Bosch but after testing on another vehicle, he stated they're not seating correctly and to try another brand.
So if you're running 1600cc injectors, top feed of course, what brand are you running?
Choice i've seen:
RC
Ultimate Racing
DW
Bosch
Please, I need help and need these asap! In case you need this info, im running jdm tgv's, top feed, and axis -6an rails.
D Money is offline   Reply With Quote
Old 04-17-2009, 12:07 PM   #2
berdugo
Member#: 163108
07 EuroDM STi 2.5L
Choice i've seen:
RC
Ultimate Racing
DW
Bosch
ask Howard of ArFab
check this out post # 70
http://www.iwsti.com/forums/gr-membe...ace-car-7.html
berdugo is offline   Reply With Quote
Old 04-17-2009, 02:17 PM   #3
5iveLug_EK
Member#: 122278
bosch are turning out to be a big pain in the a$$ for me. the hydra has a setting for 1-2.5-8-16 ohm injectors. the bosch are 4.5 ohm so not making this an easy conversion.
bosch 160# injectors
5iveLug_EK is offline   Reply With Quote
Old 04-17-2009, 02:34 PM   #4
06njsti
Member#: 150986
06 #001 LSB STi
damn D 1600cc injectors thats just ridiculous. i cant wait to see this monster
06njsti is offline   Reply With Quote
Old 04-17-2009, 03:16 PM   #5
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
You're not using the reistor packs, correct?
So who has a wrx with 1600's, someone post up!
haha I can't wait to just drive it lol.
Old 04-17-2009, 03:23 PM   #6
JSarv
Member#: 163445
l33t *******
[email protected]
Injector dynamic Bosch top feed 1000's...
You'll have to run around 120psi fuel pressure static but that will put you over 1600 and it will idle even better than with OE fuel pressure...
-Jerod
and btw they are high impedance - something like 13ohms
JSarv is offline   Reply With Quote
Old 04-17-2009, 04:13 PM   #7
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
I NEED low impedance injectors, 1600cc's ONLY.
I already had 1100's and they're not enough.
Old 04-17-2009, 04:31 PM   #8
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
I will be running 1600cc Ford Motorsports Injectors. Im not sure who manufactures them for Ford though. I bought a set of 8 from Summit Racing for about 400.00
wrx_driver_2002 is offline   Reply With Quote
Old 04-17-2009, 04:52 PM   #9
j.r
Member#: 201800
2007 STI
gt30r
Are you going to be running a double fuel pump setup with a fuel pressure regulator?
j.r is offline   Reply With Quote
Old 04-17-2009, 06:57 PM   #10
Tony1
Member#: 204092
2001 8 second Integr
Red
Choice i've seen:
RC
Ultimate Racing
DW
Bosch
When you say the Bosch were not seating correctly, you're referring to the Bosch 1600cc injectors, right?
Tony1 is offline   Reply With Quote
Old 04-17-2009, 08:57 PM   #11
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
No, one in tank walbro feeding txs surge, feeding external pump. I went with full fuel system...
I don't want to bump the pressure up just to make it work, I was told not to do that that's why I already sold my 1100's. lol
Yes.
Old 04-18-2009, 09:04 AM   #12
sidewayz
Member#: 5810
2001 S366 2.5RS
d- why don't you just run 8 800cc injectors? Have the 4 run to tool around town and when boost comes on have the other 4 start rocking.
-Ryan
sidewayz is offline   Reply With Quote
Old 04-19-2009, 09:58 AM   #13
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
-Ryan
Ryan,
I wish I thought of something like that PRIOR to spending all this money on my current fuel system. I can't switch now since I already got my tgv's powdercoated, all the fittings and braided lines for one set of rails, not to mention the chroming done on the fuel rails. I would be out alot of money if I decided to switch now.
BTW, did my buddy hit you up for the install next week?
Old 04-19-2009, 09:46 PM   #14
ownnij
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
Tony fill out your profile. i'm just guessing your Tony Palo. do you tune subarus?
ownnij is offline   Reply With Quote
Old 04-20-2009, 09:59 AM   #15
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
bump, someones got to have 1600's....
Old 04-20-2009, 10:32 AM   #16
squashman
Member#: 71718
07 STI LTD
Who's tuning your car? Can't they recommend the proper injector that they're comfortable tuning with? I'd be leery if that person couldn't recommend the right injector. That would pretty much tell me they've never tuned a high HP car before.
edit: I see Phil is tuning your car. He's tuned a ton of balls out setups, so he doesn't have any other recommendations besides Bosch?
squashman is offline   Reply With Quote
Old 04-20-2009, 12:28 PM   #17
Tony1
Member#: 204092
Red
That's me. I'll update the profile.
I don't do much Subaru tuning because i don't have an AWD dyno and there are none that are close to me and convenient to use. None the less, I know what it takes to tune one and how to setup a turbo motor.
Old 04-20-2009, 05:49 PM   #18
ownnij
Member#: 70459
yeah i only guessed because tony1 was a give away but those injectors are suppose to be sweet. my friends at triwerks are using them on a wrx with a rotated precision turbo setup. it's getting tuned this weekend so i'm hoping to see great results.
Old 04-26-2009, 11:48 AM   #19
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
look guys, I really need help. I do not want to buy injectors for a third time.
What brand is good? RC's do not look like they come with resistor packs, don't think that matters since the hydra has low impedance injector capabilities with no resistor packs. Other than that, there is Ultimate racing and Bosch.
No one knows anyone with 1600's?
Old 04-26-2009, 11:54 AM   #20
Speedelements
Member#: 121054
2007 Sti 30r
Swp
Hey D
Have you tried giving these guys a call?
http://www.deatschwerks.com/catalog/
Speedelements is offline   Reply With Quote
Old 04-26-2009, 12:50 PM   #21
g-pimpin
Member#: 95510
02 WRX
15 STI
Are you switching to E85 or shooting for 2000HP?
g-pimpin is offline   Reply With Quote
Old 04-26-2009, 01:25 PM   #22
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
hey D
i'd go with UR, there stuff is top notch! i ran there 800cc for a year and had no problems at all! they come with the resistor packs and are ready to go!
waynoSTI is offline   Reply With Quote
Old 04-26-2009, 01:40 PM   #23
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
Originally Posted by Speedelements View Post
Hey D
I had their 1100's and recently sold them. I don't think they make 1600's, if so i'd bet they were just modded and not true low impedance.
LOL no! But i'd like to crazy 650+ on q16.
Originally Posted by waynoSTI View Post
hey D
Thanks wayno! This is info I can use!
Old 04-26-2009, 02:36 PM   #24
bertune
Member#: 107290
I am running UR 1600cc injectors, problem free! You don't have to buy the resistor pack either.
bertune is offline   Reply With Quote
Old 04-26-2009, 04:07 PM   #25
JSarv
Member#: 163445
l33t *******
[email protected]
650 on Q16? 12-1300 should be more than enough...
Q only requires about 5% more fuel than straight gasoline...
What parts to choose? AScooby4U Off-Topic 9 07-29-2005 09:51 PM
Links for those considering Wingless, Scoopless (FMIC), or what color to choose. Nivek-CA STi Forum Archive 3 09-03-2003 03:16 AM
What car to choose Lando L Jackson Newbies & FAQs 9 07-25-2003 01:28 AM
what tires to choose??? Aaron Hoag Tire & Wheel 1 06-28-2003 09:53 PM
Need help on what struts to choose....with H & R springs. ChristophWRX Southern California Impreza Club Forum -- SCIC 1 01-14-2003 01:52 PM
