Old 04-17-2009, 02:20 PM   #1
The Satch
Member#: 149174
that 's cool. i
have a goldfish.
Default check my list.....
building the motor next month, please check my list to ensure i have all the parts i need.
1. Sleeves - LA Sleeves, closing the deck
2. ACL Race Bearings
3. Pauter Rods
4. JE Custom Pistons- tool steel wrist pins, double pin oilers
5. 11mm Oil Pump
6. Water Pump
7. Aluminum Radiator
8. Stock Crank
9. Keeping stock heads for now, just port and polish
missing any crucial parts?
The Satch is offline   Reply With Quote
Old 04-17-2009, 02:35 PM   #2
06njsti
Member#: 150986
06 #001 LSB STi
i dont understand why you are sleeving the block and staying with stock heads. it just doesnt make sense to me.
06njsti is offline   Reply With Quote
Old 04-17-2009, 03:36 PM   #3
The Satch
Member#: 149174
that 's cool. i
have a goldfish.
doing work now to prepare for later, it still has to be a DD for a little while.
Old 04-17-2009, 04:07 PM   #4
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
you can daily drive with ported heads pretty easily no??? why dont you just save the sleeves for later to then??
no cams or anything up there either??
head studs??
should have gone with a 12mm pump im sure its the same price.
looks good to go though. i would think you have head studs but forget to mention, also gaskets? might look into a thicker head gasket
Chris
godforbid67 is offline   Reply With Quote
Old 04-17-2009, 04:13 PM   #5
The Satch
Member#: 149174
that 's cool. i
have a goldfish.
head studs??
Chris
havent bought parts yet, i like to check first, i can still get the 12mm pump. i am probably going to go with cometic head gaskets, havent thought about head studs for some reason, not sure why. reccomendations and why?
the reason im keeping stock heads right now is i will be stuck on the vf39 for a while and i still need a 6 speed swap. i going to do the short block, the tranny, and then either the top end or the turbo, not sure on that yet. i know it doesnt make sense to everybody, its just how i want to do it. when i do the top end, i might drop some 100mm or 101mm pistons in at the same time, i will see when i get there.
Old 04-17-2009, 05:43 PM   #6
godforbid67
Member#: 137168
06 Built SGM WRX
true, i would go for the 12mm just because.
cosmetic head gasket for sure, prob a stock full gasket set also.
arp head studs, i dont even think there are any other companies who make them, def get them.
i would also do some cams to go with those heads and oil pump, and youll be able to rev her out pretty high, 8k+......what size turbo are you going to be running when its all done?
good luck,
Chris
Old 04-17-2009, 05:59 PM   #7
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
I got the 11mm 08 pump instead. It has a better design and I think it flows more than the 12mm.
Gasket kit will include stock head gaskets. I'd use those...
ARP head studs for sure.
alcoolaid is offline   Reply With Quote
Old 04-17-2009, 07:24 PM   #8
godforbid67
Member#: 137168
06 Built SGM WRX
how does a 11mm flow more? that doesnt make sense to me.
Old 04-17-2009, 07:39 PM   #9
The Satch
Member#: 149174
that 's cool. i
have a goldfish.
good luck,
Chris
when its all done i will be looking at a 30R or 35R on meth, got the new HFS-6 kit on the way from awuamist, spec-C tank sitting in my living room. forgot the gasket set of course.
Im not going with the 08 P&L pump because i have been strongly reccomended against it. not saying it doesnt work, just not what im going with.
any reccomendations on an aftermarket water pump or is a factory replacement fine?
Old 04-17-2009, 09:54 PM   #10
godforbid67
Member#: 137168
06 Built SGM WRX
if your going to a 35r or even a 30r maybe look into cams.
yeah i figured you had the gasket kit.
im not sure but i think stock water pumps are fine, my builder got a oem one for my build.
Old 04-17-2009, 10:35 PM   #11
cooleys04
Member#: 145027
2004 WRX FP Green
MFactory/2Tone/built 205
Don't forget the timing belt. I wouldn't bother with the sleeves, spend that on cams. If you insist on sleeves, wait and save money for the headwork. Much cheaper in the long run. You'll kick yourself later if you don't.
cooleys04 is offline   Reply With Quote
Old 04-18-2009, 01:02 AM   #12
The Satch
Member#: 149174
that 's cool. i
have a goldfish.
timign belt is already sitting at my house, along with 8mm phenolic spacers.
cams will come later, before the big turbo for sure. i am pulling the engine myself, and the heads, its not like it will cost me anything extra to do it later, its going to have to wait right now, my budget wont support an entire engine build, drive train, and rotated turbo setup. i didnt just hit the lottery. i understand it would be beneficial to do a lot of this stuff now, but its not going to happen.
Old 04-18-2009, 08:03 PM   #13
cubuff
Member#: 38345
2004 WRB WRX
What is the power goal for the car? 35r and never anything bigger? If so dont bother sleeving, it would be a waste. Having sleeves on a daily driven car is just plain overkill. Look at all of the 35r cars that are maxing that turbo out on stock sleeves.
If your going to be building a sleeved block you might as well get some bigger head studs like 13 or 14mm.
cubuff is offline   Reply With Quote
please double check my shopping list krzemienr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-20-2008 09:11 PM
check my list.... The Satch Car Audio, Video & Security 5 03-08-2008 04:10 AM
Conversion Gurus, Double-Check my List? EJ205 -> 98 RS jamesfacts Subaru Conversions 15 04-22-2005 02:54 PM
Alright Gurus, check my shopping list chopaholix Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 03-28-2005 01:17 PM
Soon to be RS+T check my list milkman Normally Aspirated with bolt-on Forced Induction Powertrain 18 01-06-2002 05:38 PM
