Old 04-17-2009, 07:39 PM   #1
04psmgt35sti
Member#: 203623
2004 STI
464whp
Default .020 over on an sti anyone?
Just thinkin about goin .020 over when i get the block to the machine shop? Anyone have any problems cracking cylinder walls at .020?
04psmgt35sti is offline   Reply With Quote
Old 04-17-2009, 08:25 PM   #2
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
That what you SHOULD do with new pistons to ensure an accurate fit, just not everybody does as its "usually" not needed. People split cylinder walls at stock levels anyway....
Old 04-19-2009, 11:45 PM   #3
04psmgt35sti
Member#: 203623
2004 STI
464whp
bump, i need to find out if want to go .020 over this by tuesday!
Old 04-20-2009, 12:05 AM   #4
cribbie
Member#: 184505
2003 WRX
Sonic yellow
If your cylinder run out is within specs then leave them alone. .020 is just a clean up job you wont get anything out of it.
cribbie is offline   Reply With Quote
Old 04-20-2009, 12:31 AM   #5
alcoolaid
Member#: 134949
'07 SWP STi
Twinscroll ViPec Anti-lag
Measure the bores first then decide. You might be able to get away with 99.5mm or 99.75mm pistons.
alcoolaid is offline   Reply With Quote
Old 04-20-2009, 01:11 AM   #6
AWDWRXLOVER
Member#: 50267
02 built hybrid
sr55/meth/sick speed
100 mils are fine but if i could do it again i would have done 99.75 so i would have room for a future rebuild.
AWDWRXLOVER is offline   Reply With Quote
Old 04-20-2009, 01:27 AM   #7
Team Scream
Member#: 121532
2006 FXT/STi 6MT
01 Aerosim GC8 Coupe
I am sitting here with a set of case halves from an 05 STi engine tear down i just did.
I am thinking I will probably go with the 99.75 if I have to do anything at all.
The engine only had 17K on it when the guy that owned it crashed it.....(I bought the whole car for parts).
As you can imagine everything looked near new when I disassembled the engine, and I would like to leave room for a future clean up as well.
99.75 will ensure that you get the piston to wall clearance you want/need and is more of an aggressive hone than a bore job so it may even cost you less. ?
If you do not already have pistons, you have no reason to be dropping that block off at the machine shop for any bore work my friend.
Team Scream is offline   Reply With Quote
Old 04-20-2009, 07:05 AM   #8
cribbie
Member#: 184505
2003 WRX
Sonic yellow
By the sounds of it some people like to throw away there money for no reason...have your block measured out if isn't within spec then go .020 over and if it is within spec then move on to the next question...
Old 04-20-2009, 01:37 PM   #9
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
100mm should be fine and its just extra insurance to give you more some for the bore and piston match.
Fongers is offline   Reply With Quote
Old 04-20-2009, 09:06 PM   #10
04psmgt35sti
Member#: 203623
2004 STI
464whp
I dropped the two casings off today and had him measure the walls. As expected number 4 was slightly out at the top so he honed it to see how far off we were. He said he honed it to .009 and it tested perfect so i just ordered my pistons through wiseco (apparentley you have to order 99.75's custom because they don't offer it). 4 weeks and i'll recieve the new pistons for the shop to hone out to spec
Old 04-21-2009, 03:34 AM   #11
alcoolaid
Member#: 134949
'07 SWP STi
CP makes a 99.75mm. I got them in 3 days with a crown and skirt coating.
TD06-18G on an STI. Anyone done it? Davenow Factory 2.5L Turbo Powertrain 73 06-15-2006 03:33 PM
Anyone around Austin done an inlet hose on an STI? Davenow Texas Impreza Club Forum -- TXIC 25 09-19-2005 09:53 AM
Anyone dyno or 1/4 mile an 18g on an sti yet? odin1 Factory 2.5L Turbo Powertrain 38 10-24-2004 02:02 AM
Anyone Use jack stands on an STi? rich728 Service & Maintenance 8 04-17-2004 10:16 PM
Anyone got pics of a mines (or replica) trunk spoiler on an STI? jsavage Interior & Exterior Modification 0 03-08-2004 01:13 AM
Message Board Statistics All times are GMT -4. The time now is 03:49 PM.
