Southern California Impreza Club
Go Back   NASIOC > NASIOC Chapters > Southern California Impreza Club Forum -- SCIC
Old 04-17-2009, 10:07 PM   #1
2007st3
Member#: 175842
2010 WRX notch
Question CARB approved downpipe?
I own a 2008 WRX and will probably be moving to a state with CARB emission requirements. I was wondering if anybody knew if only the AVO dp is CARB approved or if there are others? I was also curious if any one in the CARB states has had any trouble getting inspected with any other dp's (Cobb or Perrin for example)? As I dont feel like removing the dp to replace it with the stock one every year.
2007st3 is offline   Reply With Quote
Old 04-17-2009, 10:11 PM   #2
PSEYE
Member#: 181186
2007 STi OBP
GERM
I think ALL aftermarket DP's are illegal, even catted...so if you're going to mod...get no cat.
PSEYE is offline   Reply With Quote
Old 04-17-2009, 10:13 PM   #3
berny227
Member#: 134709
2012 NUDEMOBILE
REAL MAN KREW #1
^^speaks troof. Slap your stock dp when you get your emissions done..once it passes put any DP you want on.
berny227 is offline   Reply With Quote
Old 04-17-2009, 10:15 PM   #4
TK421
Member#: 146200
alot of the high flows will still pass smog...Titek, helix, cobb all pass smog with stage 2 + tune...Just paint it black and mod the stock heat shield and noone will notice the DP is aftermarket
i had headers, intake, agressive tune, full TBE (titek high flow catted DP) and i passed smog great
TK421 is offline   Reply With Quote
Old 04-17-2009, 10:16 PM   #5
PSEYE
Member#: 181186
2007 STi OBP
GERM
Visual inspection too?
Old 04-17-2009, 10:17 PM   #6
PSEYE
Member#: 181186
2007 STi OBP
GERM
They're still "illegal" even if it passes smog...OP wants CARB legal.
Old 04-17-2009, 10:18 PM   #7
PSEYE
Member#: 181186
2007 STi OBP
GERM
You can always make friends with shop owners and they'll pass you fo free
Old 04-18-2009, 12:47 AM   #8
si12j12
Member#: 99697
04 wrx [wrb]
ni stage-ah san!
i have never seen a carb aproved aftermarket dp
i might just be slow .... i duno
si12j12 is offline   Reply With Quote
Old 04-18-2009, 03:47 AM   #9
CaricuaoUD7
Member#: 127798
There is a dark-horse rumor that Cobb is working close with CARB to certify one of their DP....but this will still be many moons away from becoming reality...as far as i know...all DP's are illegal as everyone has mentioned b4 me....juss hold on to your stock DP juss in case
good luck wit that,
H
CaricuaoUD7 is offline   Reply With Quote
Old 04-18-2009, 02:00 PM   #10
jimmythagreek
Member#: 2797
MY01 RSTI
Silverthorn
CARB approved = STOCK
jimmythagreek is offline   Reply With Quote
Old 04-18-2009, 05:21 PM   #11
epine
Member#: 88054
09 STI RIP 08AWSTI
good luck wit that,
H
pipe dream
truth is cobb's broke
epine is offline   Reply With Quote
Old 04-18-2009, 06:30 PM   #12
Tahoe SC
Member#: 131996
2006 CGM WRX Wagon
Yimi Tuned 296AWP/322TQ
there isn't one other than stock.
Tahoe SC is offline   Reply With Quote
Old 04-18-2009, 06:35 PM   #13
SG02WRX
Member#: 151814
02 WRX
WRB w/ moar stopping powa
I heard Cobb is going to dedicate themselfs to AP's
SG02WRX is offline   Reply With Quote
Old 04-18-2009, 06:46 PM   #14
2007st3
Member#: 175842
2010 WRX notch
So it is possible install a catless dp without throwing codes?
Old 04-18-2009, 07:42 PM   #15
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
you have like 8 years before you first smog...
bue car is offline   Reply With Quote
Old 04-18-2009, 08:12 PM   #16
littlewhitewagon
Member#: 103068
11 STI sedan
When did it change from 4 years to 8 years?
littlewhitewagon is offline   Reply With Quote
Old 04-18-2009, 08:47 PM   #17
underscore
Member#: 160858
2008 LGT
it is 6 years but it will have to be smogged if you are registering it for the first time in CA
http://dmv.ca.gov/vr/smogfaq.htm
underscore is offline   Reply With Quote
Old 04-18-2009, 09:06 PM   #18
[D.I.]WRX
Member#: 116314
I remember MadDad trying to make a CARB legal dp. I don't think it ever made it though....surprising
[D.I.]WRX is offline   Reply With Quote
Old 04-18-2009, 10:42 PM   #19
teiva-boy
Member#: 22825
No they wanted to make one with a hi-flow cat and a provision for attaching a factory heatshield to make it look stock. This was to fool the visual only.
As others have said, there are and never will be any CARB approved downpipe. Messing with your catalytic unless damaged or over xx,xxx mileage(dont recall exact number but it's up there) only then can you install an aftermarket CARB approved catalytic that will replace your malfunctioning factory one.
teiva-boy is offline   Reply With Quote
Old 04-19-2009, 12:57 AM   #20
2007st3
Member#: 175842
2010 WRX notch
Does that make the avo street dp legal? It does have a carb approved cat on it.
Old 07-27-2009, 07:09 PM   #21
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
I was told by a vendor that the next Helix catted DP will be 50-state legal but can't find anything to back that up. Has anyone else heard similar?
It's a shame that this is such an issue. If the air coming out of the tailpipe is clean enough, who cares what kind of pipe it went through to get there?!?!
2point0 is offline   Reply With Quote
Old 07-27-2009, 07:47 PM   #22
bbun
Member#: 184554
02 ghettoFABness
bugeye rolling.
just gutt the stock one = pass visual inspection
bbun is offline   Reply With Quote
Old 07-27-2009, 08:00 PM   #23
casper1jr
Member#: 208012
07 WRB STi
Tuned @ 21psi
The only real legal one is stock as mentioned, this is a fact!
casper1jr is offline   Reply With Quote
Old 07-27-2009, 08:09 PM   #24
turb04
Member#: 61386
04 PSM WRX R.I.P.
05 Snow White Camry
+1....
turb04 is offline   Reply With Quote
Old 07-28-2009, 01:43 AM   #25
teiva-boy
Member#: 22825
Federal Law = no messing with ANY factory catalytic. are you that gullible that a chinese knock off company says they'll meet federal (and state) regulations?
CARB approved downpipe? 2007st3 South West Impreza Club Forum -- SWIC 10 04-18-2009 07:09 PM
CARB approved downpipe? 2007st3 Factory 2.5L Turbo Powertrain 4 04-17-2009 04:06 PM
CARB approved packages? Space wrx Factory 2.0L Turbo Powertrain 4 03-08-2002 04:15 PM
Message Board Statistics All times are GMT -4. The time now is 12:06 PM.
