Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 04-17-2009, 11:20 PM   #1
Pursuit
Member#: 38370
Default Knocking between 2k-3k RPM?
Looking at a steal of a buy on an '05 Saabaru (2.5 N/A) that has a strange knock between 2k & 3k RPM. No noise below, no noise above, runs smooth and pulls fine. Unknown maintenance (trade in). They say it happened suddenly during a test drive, no noise before.
From my searches, I'm optimistically thinking possibly a broken timing belt tensioner?
Anyone run into a RPM range specific knock before?
Pursuit is offline   Reply With Quote
Old 04-18-2009, 12:44 AM   #2
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
sounds like maybe the previous owner flashed a bad map on your rom.
i would stay away .
watchunglava is offline   Reply With Quote
Old 04-18-2009, 02:22 AM   #3
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
They all knock in that range, but you shouldn't be able to hear it.
williaty is online now   Reply With Quote
Old 04-18-2009, 12:57 PM   #4
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
I've run into an RPM dependent knock before. #4 rod bearing was dying. Yours may be completely different, but that's where mine started.
Old 04-18-2009, 03:44 PM   #5
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
If an engine has a knocking noise on light throttle at 2500 rpm it's probably a bad con rod bearing.
Marnix is offline   Reply With Quote
Old 04-19-2009, 02:31 PM   #6
GrundleJuice
Member#: 165749
k, first lets clarify... is this audible knock to the driver or knock being heard by the ECU?
If its audible and heard by the driver, something is broken/worn and should be fixed before you buy it. If it's just detected by the ECU, then many other things should be considered... from gas octane and ignition timing, etc etc.
Old 04-19-2009, 03:54 PM   #7
Back Road Runner
Member#: 60082
2004 Forester STI
05? Under warranty?
Old 04-20-2009, 02:11 PM   #8
Pursuit
Member#: 38370
Not under warranty, ~130k miles.
Can hear it, clearly something is broken. They're not interested in fixing it, they're selling it for less than the car's value minus the cost of doing an engine swap. I'm hoping to not have to go that far with it, but for the price am considering it.
Thanks for all the input!
Old 04-20-2009, 05:50 PM   #9
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
search youtube for knock sounds, it may help.
Old 04-20-2009, 07:13 PM   #10
Pursuit
Member#: 38370
Yeah I did the youtube search, the thing that's puzzling me is how it's only knocking in that certain rev range. Everything I've heard is consistent.
Old 04-20-2009, 07:36 PM   #11
GrundleJuice
Member#: 165749
they wont pull the timing cover and check the tensioner at the least? if the tensioner is worn/broken it could lead to a blown engine at anytime. They must not want to sell this car very bad.
Old 04-21-2009, 12:59 AM   #12
Audi20Tdriver
Member#: 206040
2009 Audi A4 2.0T
APR Stage 1
dude.. forget that car.. 130K on an 05?! I just sold my 05 RS for my audi in Feb.. it had 37,500 miles on it. which is about right for 'normal' usage. this sounds like you're looking to buy trouble.
Audi20Tdriver is offline   Reply With Quote
Old 04-21-2009, 01:29 AM   #13
Jerry Xu
Member#: 36629
07 2.5i
Regularly Being Modified
He says it is a steal, ok?
How do you know it is knock? Are you able to hook up a computer to log for a few minutes to test run it in that range?
Jerry Xu is offline   Reply With Quote
Old 04-21-2009, 08:35 AM   #14
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
It's audible so you won't need to hook it up to define if something is broken. If the price is right (ie. you can invest in a new shortblock) why not...
Weird noise @ 2k and 3k RPMs Sean2.5Black Pre-2002 Factory Turbo Powertrain 2 02-07-2010 04:44 AM
Clicking sound between 2k and 3k rpm jmodica Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-29-2007 07:41 PM
AP response from 2k - 3k rpm ? HAL1 Engine Management & Tuning 10 12-07-2005 04:22 PM
hesitation during cruising at 2k-3k rpm cray_ze Newbies & FAQs 2 06-02-2004 11:51 PM
