Old 04-17-2009, 10:35 PM   #1
04psmgt35sti
Member#: 203623
2004 STI
464whp
Default Oil Cooler
Alright anyone know of a good oil cooler for a decent price for an 04 sti??
04psmgt35sti is offline   Reply With Quote
Old 04-18-2009, 03:22 AM   #2
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
I made my own.
https://www.racerpartswholesale.com/...Mocal_Products
19 row core, sandwich plate w/thermostat, -10AN lines, fittings, custom bracket, done.
alcoolaid is offline   Reply With Quote
Old 04-18-2009, 08:20 AM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
That's exactly the setup I have on my Moostang.
Mocal, Setrab, Earl's, and Fluidyne all make very good stacked plate type coolers. They're all prety expensive. There are other brands (B&M, for example) that make less expensive stacked plate type or tube-and-fin tyep coolers. Take a look at Summit or Jegs or any of the various circle track racing suppliers (Coleman, Pegasus Racing, etc etc). Keep in mind that the cooler is only part of the equation. The sandwich adapter, hose, and hose fittings add up to a pretty good chunk of money.
Pat Olsen
Old 04-18-2009, 08:46 PM   #4
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
yup, just make your own, its cheaper and much better.
scby rex is offline   Reply With Quote
Old 04-18-2009, 11:04 PM   #5
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
I used the Tru Cool oil coolers from www.Racerpartswholesale.com, cheaper than Mocal, mounting tabs make it easier to install, and Nascar teams use them: https://www.racerpartswholesale.com/...ol_Oil_Coolers
New anti-clog design keeps maximum air flow through cooler at all times. Lightweight aluminum alloy is vibration proof. All coolers come with a built-in bracket and a 1/2" NPT fitting. High-tech coolers are so efficient and durable, major NASCAR® teams use them.
methaddict is offline   Reply With Quote
Old 04-19-2009, 10:06 AM   #6
scby rex
Member#: 104878
02 wrxbastardchild
I just dont like the 1/2 npt fitting on those, the others use a -an fitting.^
Old 04-19-2009, 01:34 PM   #7
methaddict
Member#: 159738
2004 WRB STi
That was no problem, I just used an npt fitting to AN adapter.
Flame Guard Sleeving for Oil Cooler/Differential Cooler Hoses vpwseah Engine/Power/Exhaust 0 09-10-2007 07:19 PM
Top mount Oil cooler/tran cooler ColesSTi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 08-31-2006 08:10 AM
Leaking Oil from oil filter/oil cooler AustinSTi Normally Aspirated Powertrain 3 01-08-2004 12:42 AM
Where are my oil cooler and trans cooler located at? Hit Man X Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-28-2002 09:40 AM
spark plugs, oil coolers, transmission coolers, upgraded radiator, who has them? ChristophWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-04-2002 12:48 AM
