#1 |
Member#: 119458
'02 Legacy, pure stock, 2.5L.
Hooked up an Innova 3130 to the ODB port. Should the front O2 sesnor ever be as high as 1.60 volts?? Rear fluctuates between .005 and .800 volts. Front is between 0.9 and 1.6. Mostly around 1.5 volts.
#2 |
Member#: 119458
?? Anybody?
#3 |
Member#: 206785
TXIC
Vehicle:1999 legacy outback silver |
is it an O2 or an AF?
If you look on the catalyst sticker on the hood it will tell you the emissions equipment it has, including the sensors. HO2S should not hit above 1v. Even 1v is too high. It sounds to me like you have AF sensors. If so, thats about normal. |
#4 |
Member#: 171149
International
Vehicle:MY00 GC8 CS4 |
The front sensor on the headers are an AF sensor - those readings are normal.
#5 |
Member#: 119458
Thanks guys. It is a Bosch sensor. O2, AF...I don't know. If you go to Autozone and ask for a front O2 sensor for an '02 Subaru Legacy, it is whatever they hand you. 5 wire unit. On their site is says "Sensor type, wideband A/F".
This thing....Link to sensor details |
#6 | |
Member#: 237228
Hate to bring back a dead post but i have an AF sensor in an 02 Legacy and it hits up to 3.8 volts often, My stft is -29 til ltft learns then its -27ish ltft and stft hits around -2ish area. Last edited by 2ez4me; 07-28-2010 at 09:44 PM. |
| Thread Tools | |
| Display Modes | |
| Anyone know O2 sensor voltage -> A/F ratio? | Drews_WRX | Factory 2.0L Turbo Powertrain | 3 | 09-19-2002 11:07 PM |
| O2 sensor voltage | reza01 | Normally Aspirated Powertrain | 4 | 07-23-2001 01:12 PM |
| Front and rear O2 sensor voltages? Anybody get a reading yet? | delectron | Factory 2.0L Turbo Powertrain | 2 | 07-12-2001 04:09 AM |
| ('93-'01) Wide band O2 sensor voltage range | jeffg | Impreza Forum | 5 | 06-05-2001 02:26 PM |
| O2 Sensor Voltage | Spectre23 | Normally Aspirated Powertrain | 6 | 02-22-2001 06:21 AM |
