Old 04-18-2009, 05:28 PM   #1
jays05
Member#: 78165
05 STI 35r + e85
Default 11.0 @ 124 on straight 93oct and another blown header gasket
I went to my local track Lebanon Valley Dragway today for opening day test/tune. Just running the 93oct map trying to see if I can run 10s on pump gas.
First pass was 11.0 @ 124 with a 1.59 60', launching off the rev limiter
When I checked the logs I realized that I'd left the knock sensitivity up high (low numerically in the UTEC) and it was pulling timing on the FFS shifts. I made an adjustment and made another pass. That pass felt great but pulling off the track it became apparent that the header gasket blew out again. In the logs boost dropped to ~19psi from halfway thru 3rd onward.
Sucks, that second pass looks like it could have been a 10.9 if the gasket didn't blow out again.
Next time around I am going to try using copper header gaskets, and I'm going to have my local shop fabricate a bracket to hold the uppipe to the block, and maybe put a flex pipe in the downpipe right after the cutout.
Mods (the important ones anyways):
cp 100mm pistons, pauter rods
stock crank, ati super damper balancer, cosworth 10mm pump
cosworth 278/274 avcs cams, supertech +0.5mm valves, dual springs, retainers
gruppe-s UEL header v-banded to a custom 2.5" uppipe
custom fmic with 3" charge piping and a garrett 24x12x3.5" core
txs utec on top of openecu with an AWESOME Junior tune
dw1100s, perrin rails, aeromotive fpr, dual walbros
gt35r .82ar t31 2.5" outlet, tial 44mm ewg dumped
3" downpipe, QTP cutout, Borla Hush
act xtreme 6-puck (sprung) + oem flywheel
dss driveshaft and level2 rear axle bars
BFG DRs 225/45/17 on 17x8 Enkei RPF1s
No meth injection, e85, or race gas. Plain old 93 octane. It weighed 3055lbs with a half tank of gas and no driver.
I should have video of both passes "soon".
jays05 is offline   Reply With Quote
Old 04-18-2009, 05:58 PM   #2
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Congrats! DR's or not, a 1.59 60ft is fantastic!
Steve.804 is offline   Reply With Quote
Old 04-18-2009, 05:59 PM   #3
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
man, i dont even know what to say anymore. youll def get there bro. good luck
godforbid67 is offline   Reply With Quote
Old 04-18-2009, 06:04 PM   #4
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
nice, for some reason when I read the title I read as "blow head gasket" , great man congrats
juanmedina is online now   Reply With Quote
Old 04-18-2009, 06:06 PM   #5
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Is that a 2.5inch outside diameter uppipe or inside diameter? I fabbed my own up pipe and I made it 2.20 inner Diameter to increase spool ect...How does the 2.5incher work for you? Congrats you will be running 10's on pump in no time...
TDagen is offline   Reply With Quote
Old 04-18-2009, 06:19 PM   #6
jays05
Member#: 78165
05 STI 35r + e85
Thanks! The car is easy to launch now. The 60-ft times on my last four passes were 1.57, 1.57, 1.59, 1.58 !!!
The uppipe is 2.5" ID and my gruppe-s UEL header (which is huge already) had the collector ported to open it up to 2.5" ID. It's hard to say what effect it had on lag since it was installed along with the header and gigantic fmic. But I guess it's working out well
Old 04-18-2009, 06:24 PM   #7
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
^Nice I wish mine was Vbanded to the header... Go get that 10 sec slip....
Old 04-18-2009, 07:14 PM   #8
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
At first I read that as "another blown head gasket". A blown header gasket is a much better problem to have. Good work for now and you'll get it figured out.
Generally those gaskets blow from the hardware loosening up and/or the flanges not mating well with each other. If you're sure the hardware didn't loosen up, see if the flanges are warped or not lining up nicely. You definitely don't need a special gasket if the pipes fit well.
Innovative Tuning is offline   Reply With Quote
Old 04-18-2009, 07:29 PM   #9
jays05
Member#: 78165
05 STI 35r + e85
Haha everybody at the track thought I said blown headgasket too.
I never used to have problems with header gaskets, it was always the uppipe gasket. We v-banded that and now it blows header gaskets instead. They were remflex gaskets and maybe that is some of the problem. I will check the torque on the bolts but they had already been retorqued after a couple hot/cold cycles.
Old 04-18-2009, 08:47 PM   #10
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Way to go Jay.. Funny after we got off the phone I took my friends car that runs similar to yours and blew the header gaskets on the street. All before tonight's festivities..
Junior2JZ is offline   Reply With Quote
Old 04-18-2009, 09:19 PM   #11
Irishman
Member#: 29933
2004 STI
Silver/Silver
Great job. Thats awesome, you definitely have 10's on pump with a clean run with no leaks.
Irishman is offline   Reply With Quote
Old 04-18-2009, 10:11 PM   #12
godforbid67
Member#: 137168
06 Built SGM WRX
Now the only question is, where do you go from here (after 10 sec pass on pump)???
Old 04-18-2009, 10:26 PM   #13
OVeRBOOSTn
Member#: 192514
04 STi PTE6765
[email protected] / JR Tuned
lol was this be4 or after our adventure lmfaooo..
and nice run jay cant wait to see that car run in person!
OVeRBOOSTn is offline   Reply With Quote
Old 04-18-2009, 10:56 PM   #14
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
you can do it I know you can if I did it on 93/94 no meth weighing 3360 with me in it you can do it too.
john 1badSTI is offline   Reply With Quote
Old 04-18-2009, 10:57 PM   #15
jays05
Member#: 78165
05 STI 35r + e85
Priority now besides fixing the leak is a rollbar so I can have fun at the dragstrip and not get kicked out. I want 10s on 93oct and really ****in fast on c16, and I want to have fun with the car all summer. That's about it.
Old 05-14-2009, 09:59 PM   #16
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
The copper ones from crucial are perfect. But make sure to re tq them and use copper gasket sealer. I never ever had another blown up pipe gasket after that. But I do see the imperfection in the ultimate racing up pipe flange I have.
Congrats on the times man.
spoolinsti05 is offline   Reply With Quote
Old 05-14-2009, 10:02 PM   #17
scOOtNsOOby
Member#: 211094
03 WRX Wagon
rotated holset Hx35!!!
i read the same then i i read the post and it was header gasket lol
scOOtNsOOby is offline   Reply With Quote
Old 05-14-2009, 10:11 PM   #18
moorebl
Member#: 59238
i kept blowing that gasket when i had my perrin set up. just make sure you mate that uppipe to the header before you tighten anything else
moorebl is offline   Reply With Quote
Old 05-15-2009, 11:31 AM   #19
AlxSti
Member#: 94615
|'06 STi 341/356|
Delaware REALTORŪ
very nice.. awesome 60ft.
AlxSti is offline   Reply With Quote
Old 05-15-2009, 01:15 PM   #20
BuggeyEYED
Member#: 101691
97 Supra TT
SOLD - 35r bug/hawkeye
nice runs....i guess its better to blow the header gasket then to blow the header apart like i did a few weeks ago..lol (not really apart but cracked it straight through)
BuggeyEYED is offline   Reply With Quote
Old 05-15-2009, 01:52 PM   #21
madmax718
Member#: 172501
Fast and the Furious! NOS!! NOS!!!!
madmax718 is offline   Reply With Quote
Old 05-15-2009, 02:39 PM   #22
GeneralTJI
Member#: 152680
Any update on the videos? Watching your footage is always a good time...
GeneralTJI is offline   Reply With Quote
Old 05-15-2009, 02:58 PM   #23
saab-on-the-cobb
Member#: 116330
2005 Saabaru 9-2x
desert sand metallic
Originally Posted by jays05 View Post
Haha everybody at the track thought I said blown headgasket too...They were remflex gaskets and maybe that is some of the problem...
YEP.
They make great exhaust gaskets, but the pressure from your headers is FAR too much for the RemFlex-style gaskets. There are threads on this elsewhere.
Remflex is good for fising a leaky TBE, but I would never trust one on my headers.
GREAT RUNS, by the way!
SOTC
saab-on-the-cobb is offline   Reply With Quote
Old 05-15-2009, 03:01 PM   #24
GeneralTJI
Member#: 152680
Yep.. great for NA or low pressure applications.
I blew a huge chunk of one out by using ignition cut FFS
Old 05-15-2009, 05:06 PM   #25
STimo
Member#: 110273
450 whp 30R STI
[email protected]
impressive driving! Both those runs were basically perfect! Too bad that gasket let go, you would have had a 10 sec pass on pump for sure.. Very impressive!
STimo is offline   Reply With Quote
