Old 04-18-2009, 10:03 PM   #1
cabz
Member#: 195806
96 impreza outback
Red
Default misfire /o2 code issue
Can anyone give ma a little help? my daughters 96 Impreza outback has develpoed an issue. the check engine light cam on the other day, after reading the codes I got 1. missfire detected on cyl #3 and 2. left bank O2 senor malfunction.
I pulled the plugs and everthing seems fine with them . the injectors also seem to be working correctly.
so what would cause this? I am thinkint the coil pack is going out and causeing the missfire which is then causeing the 02 issue .
sound about right?
how common is this issue?
TIA
cabz is offline   Reply With Quote
Misfire, no codes. How to find bad cyl? fragment Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-11-2015 10:03 PM
#4 Cylinder misfire P03040 code and possibly more Departed Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 12-16-2009 04:43 AM
#2 Misfire CEL Code P0302 SkunkBug02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 09-15-2009 12:47 PM
4 misfire CEL codes at once? help justboosted02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-19-2006 05:03 PM
2.5L bottom end misfire P-code swift2fly Subaru Conversions 3 08-12-2005 10:52 AM
