Old 04-17-2002, 03:52 PM   #1
SGOSWRX
Member#: 10921
04 04 STi
12.8 @ 105 mph
Default What psi/boost -w- stock ecu = CEL
I took off my Stage 2 Unichip to send it in to TurboXS in preparation for my VF30. I set my HPMBC at close to 16psi
(I thought) in the mean time intil I get my Unichip back and my Turbo installed.
I was driving home last night and I gave the car gas in 3rd or 4th gear, can't remember and the car bucked/hesitated. It felt just like hitting the fuel cut off when you hit the rev limiter 7200 rmps. I instantely got a CEL. I then drove the rest of the way home and the car drove fine. I did happen to notice my boost was spiking close to 17+psi or so. I forgot I wasn't driving around with the unichip. I often hit 17 - 17.5 psi in 4th gear with the unichip.
I reset my ECU and turned the boost down to 15-16psi and I have been driving all day with no problems. I didn't have the car scanned but I know thats what did it. I was definately running with the boost to high. I may have hit close to 18 psi. It had just rained and really cooled down the air.
What psi is the usual /cut off for the stock ECU?
SGOSWRX is offline   Reply With Quote
Old 04-17-2002, 03:54 PM   #2
chuglobal
Member#: 10041
2015 WRX Limited CVT
ISM
Default Humm ...
17.5psi ... I think that's what I've read but definitely by 18psi.
chuglobal is offline   Reply With Quote
Old 04-17-2002, 08:25 PM   #3
SleeperWRX
Member#: 8179
some ppl are claiming driving around at 19-20 psi w/out fuel cut...however if they're running that much w/out engine management to adjust the timing they're probably morons whose comments should be ignored.
SleeperWRX is offline   Reply With Quote
Old 04-17-2002, 08:39 PM   #4
gazoline
Member#: 10595
'98 BMW M3
Boost cut off is right around 1.2 bar or 17.5 psi so you are correct in your hunch.
gazoline is offline   Reply With Quote
At what PSI does the Stock STI blow off leak boost? hauvis Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 10-28-2005 08:57 AM
Only 7 PSI boost with STi Tanman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 12-03-2004 11:26 AM
Cobb Stage 2 ECU for trade with stock ECU + $200 chohakai Private 'For Sale' Classifieds 1 11-13-2004 02:40 AM
adding a downpipe to a car can cause boost spiking with stock ecu?? showcasewrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 10-27-2003 12:01 AM
What if: aftermarket uppipe/dp/midpipe/muffler/air filter with stock ECU? tiltrite Engine Management & Tuning 21 06-10-2003 09:42 AM
