Old 04-19-2009, 01:17 PM   #1
smithrcing17
Member#: 193195
2005 Ty Tuned 2.5RS
Default lw flywheel on 05 rs?
couple questions about it..
1. who makes them for the 05 rs?
2. what kinda gains will i see?
3. what does it cost to buy one and have it mounted?
smithrcing17 is offline   Reply With Quote
Old 04-19-2009, 03:50 PM   #2
bandit_2017
Member#: 131188
05 2.5 rst
1. ive got an exedy but im pretty sure all flys for 2.5 n/a apps will fit
2. maybe 3 or 4 hp but acceleration is quicker have not been to the track since so i cant say how much
3. got mine off here for 75 but new is like 380 to 500 if you cant do it then im just going to say alot to me mounted and you might as well do a new clutch and pressure plate i did my own so it cost me 75 because i alreddy had a new clutch but if you dont your gonig to get raped sorry
bandit_2017 is offline   Reply With Quote
Old 04-19-2009, 04:42 PM   #3
Jerry Xu
Member#: 36629
07 2.5i
Regularly Being Modified
ACT streetlite is what i am looking at. It is less money new and i pc construction, 13.4 lbs. many say no cel.
Jerry Xu is offline   Reply With Quote
Old 04-19-2009, 06:17 PM   #4
smithrcing17
Member#: 193195
2005 Ty Tuned 2.5RS
hmm ill have to look into it.. we race dirtbikes and i know that they had to be put on by our mech cause it needed balanced or something i dont remember but idk if im gunna sink that money into an n/a i might just save for the sti
Old 04-19-2009, 11:11 PM   #5
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
I have a F1 racing 12lb. FW in my car. I would suggest getting at least a 15lb fw. I am using the stock pulley and not getting any misfire CEL's.
~Josh~
Old 04-19-2009, 11:32 PM   #6
Jerry Xu
Member#: 36629
07 2.5i
josh,
I just asked them about the F1 racing flywheel (12.55 lbs). What do you think of the quality and performance? It looks nice with a little bearing pre-installed...
They are not sure about 05/06/07 fitment though. Please give some feedback. Thanks.
Old 04-20-2009, 06:02 PM   #7
smithrcing17
Member#: 193195
2005 Ty Tuned 2.5RS
it seems like its gunna be more money than its worth=/
Old 04-21-2009, 01:51 AM   #8
ballitch
Member#: 74907
98 cam'd EJ251
I cant remember what I paid for the kit. Came with 12lb fw and heavy duty clutch kit. IIRC, it was about $350 or so shipped.
I was going to have to buy a clutch kit for my wrx trans. anyway, I figured an extra $180 or so would be well spent then instead of later on when I "wanted" a lw flywheel.
If your situation is similar, then go for it. But I reccommend a 15lb flywheel instead of the 12 lb. As far as the quality, I cant complain. It bolted right in, looked great, came with everything I needed/wanted and hasnt given my any trouble at all.
We shall see how the "heavy duty clutch" holds up to forced induction, when I get around to it.
~Josh~
Old 04-21-2009, 11:04 AM   #9
sa4baru
Member#: 195354
i've been holding off on the lw flywheel cause i don't want CELs flashing all the time. i think there's a good chance it will set off misfire codes.
sa4baru is offline   Reply With Quote
FS/WTT: MA LW Flywheel 2.5 RS, and stuff SickAW02 NESIC Private Classifieds 29 09-03-2008 08:57 PM
05 WRX springs on 05 RS Storz Brakes, Steering & Suspension 5 02-11-2007 10:13 AM
LW Flywheel on STi??? S808 Transmission (AT/MT) & Driveline 6 10-06-2006 10:56 PM
A mechanic told me there are issues with flywheels on '00 RS models dingo dave Transmission (AT/MT) & Driveline 9 07-06-2005 01:54 AM
lightened flywheel on a rs stikboy Transmission (AT/MT) & Driveline 4 06-16-2002 03:35 PM
