Old 04-19-2009, 05:33 PM   #1
binkman88
Member#: 134093
Default 05 RS pcv valve?
anyone have any pics or input on where I can find this damn thing. Thanks!
binkman88 is offline   Reply With Quote
Old 04-19-2009, 06:05 PM   #2
bandit_2017
Member#: 131188
05 2.5 rst
follow the vacume hose that goes behind the coil pack and there you go cant remember the size socket i used
bandit_2017 is offline   Reply With Quote
Old 04-19-2009, 08:02 PM   #3
binkman88
Member#: 134093
I think I know which it is im just trying to get a pic of it before I go ripping hoses off lol, thanks for your help !
Old 04-19-2009, 09:08 PM   #4
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
I'll try and help you out.
I don't have pics but lets try.
On top of the intake manifold there are two small metal pipes. Track one to the left. There will be a hose stuck to this metal pipe that goes across the manifold.
Follow the hose down to the bottom passenger side of the engine block. It is right there.
An alternative way is to look at the throttle body and go to the left and down until you see a gold thing attached to a hose.
formula91 is offline   Reply With Quote
Old 04-20-2009, 12:08 AM   #5
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
watchunglava is offline   Reply With Quote
Old 04-20-2009, 12:12 AM   #6
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
The lines on that picture aren't very clear.
Plus he has an 05 which is slightly different. It's just a straight hose from the PCV to the intake steel pipe.
Old 04-20-2009, 12:15 AM   #7
watchunglava
Member#: 168862
to hell with him then ! its a pcv valve .
get your own pic if you think mine sucks .
Old 04-20-2009, 01:15 AM   #8
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Place your hand on the red covering on top of the alternator. Move your hand about 1-2" towards the rear of the car. You'll now be touching some small metal tubes. Move your hand to your left along the tubes until one of them turns towards the back of the car and joins to a rubber hose. Follow the rubber hose towards the back of the car until it turns and heads straight down into the engine. The PCV valve is at the bottom of that rubber hose, screwed directly into the block.
Old 04-20-2009, 01:23 AM   #9
binkman88
Member#: 134093
thanks so much guys and the pics just fine!
Old 04-20-2009, 10:03 AM   #10
Jerry Xu
Member#: 36629
07 2.5i
Regularly Being Modified
Love this instruction. It almost works with my eyes covered . Oh wait, where is the red covering?
Jerry Xu is offline   Reply With Quote
Old 04-21-2009, 05:26 PM   #11
binkman88
Member#: 134093
correct me if im wrong but the pcv valve on the end of that rubber hose on the 05 has nothing holding it on? Just the pcv valve into the rubber hose. Nothing attached on the rubber hose to hold it in place?
Where is the PCV Valve for 05 wrx? strictlyJDM Newbies & FAQs 7 05-01-2009 03:45 PM
PCV Valve Location Richard L. Newbies & FAQs 0 09-10-2001 04:46 PM
want to change PCV Valve and fuel filter, how and where are they, and steps? joostin420 General Forum Archive 6 12-13-2000 11:35 AM
PCV Valve Replacement Interval? Silver2000RS Technical Forum Archive 1 10-12-2000 09:26 AM
PCV Valve Replacement richeich SVX Forum Archive 2 06-26-2000 06:53 AM
