Old 04-19-2009, 07:24 PM   #1
jbayless10
Member#: 141536
2006 20G'd WRX
Grey
Default 2006 Wrx Tr-20g
Here are the major mods:
Engine:
Semi-closed EJ257 block
STI Rods
STI Crank
CP Pistons
Supertech Valve Spring Kit
.5mm over intake and exhaust valves
FP TD06 20g 7cm2
IAG 38mm External Wastegate
Perrin Front Mount Intercooler
Perrin Catless Downpipe
Perrin Cat-Back
P&P Exhaust Manifold
Grimmspeed Crosspipe
DW 750cc injectors
Walbro 255 fuel pump
Drivetrain:
STI RA gears
Exedy 3-puck Cerametalic Clutch
AEM Light Weight Flywheel
All three of these pulls were done on 18lbs of boost. For some reason power dips at 65mph then picks back up at 70. Could not tune it out either. Then at 80mph boost drops 4psi and power drops off until redline. There are no boost leak, no exhaust leaks, and no reason the boost should drop according to the tune. This is why we left boost at 18lbs and did not push it any more. If anyone else has seen power loss like this please let me know what it could be.
The car Drives great and pulls very hard in the mid range. After fixing whatever the issue is I plan on trying to get 370 whp or so out of it. Now onto the Graph!
jbayless10 is offline   Reply With Quote
Old 04-20-2009, 02:18 PM   #2
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
any way to get it RPM instead of Speed!
renosubby is offline   Reply With Quote
Old 04-20-2009, 02:23 PM   #3
jbayless10
Member#: 141536
2006 20G'd WRX
Grey
haha. no I do not have a way to change it.
Old 04-21-2009, 11:51 AM   #4
06njsti
Member#: 150986
06 #001 LSB STi
20g's are all you need for the streel on the 2.5l block. i cant wait to finally get mine on this summer
06njsti is offline   Reply With Quote
Old 04-21-2009, 02:12 PM   #5
Ntercooled
Member#: 120100
2004 WRX stage 2
Soon to be vf43'd
Any pics?
Ntercooled is offline   Reply With Quote
Old 04-21-2009, 06:21 PM   #6
jbayless10
Member#: 141536
2006 20G'd WRX
Grey
sure!
Old 04-22-2009, 12:06 AM   #7
jconaty07
Member#: 139124
badass lookin car
jconaty07 is offline   Reply With Quote
Old 04-22-2009, 12:43 AM   #8
jbayless10
Member#: 141536
2006 20G'd WRX
Grey
thank you. I have decided to completely weld the internal wastegate flapper valve shut. I am thinking that even though the bracket that keeps it closed and it does not move at high rpm, exhaust gas could still be leaking from the flapper at high rpm. I am going insane over loosing 4 lbs boost at 6,500 rpm!
Thoughts?
Old 04-22-2009, 01:32 PM   #9
boostdog
Member#: 149752
2017 wrx
ICE ICE BABY SILVER!
who tuned it?
boostdog is offline   Reply With Quote
Old 04-22-2009, 04:21 PM   #10
jbayless10
Member#: 141536
2006 20G'd WRX
Grey
Chad at Modified by KC did the tune. He has alerady checked the files and there is nothing that explains why boost drops at high rpm. It has to be something mechanical.
Old 04-22-2009, 10:39 PM   #11
rico_q808
Member#: 155896
Chapter/Region: HIIC
2006 WrX
bLuE
Thoughts?
Why not going with a larger wastegat or even a electronic boost controller to try and make it hold better?
rico_q808 is offline   Reply With Quote
Old 04-22-2009, 10:54 PM   #12
goldshuscooby
Member#: 177641
2011 STi
SWP and Stage 1
^^ yea maybe getting the Perrin ebcs would help...?! I'll let yah know how my tune goes in a couple weeks (18g on 2.0)
goldshuscooby is offline   Reply With Quote
Old 04-22-2009, 10:55 PM   #13
pacer07
Member#: 207068
06 Doesn't matter
its not a Subie!
I like car! I like wheels! Rota DPT? Gunmetal?
pacer07 is offline   Reply With Quote
Old 04-23-2009, 03:08 AM   #14
Airboy
Member#: 72829
2006 WRX
2015 WRX
Thoughts?
The stock DBW throttle map closes the throttle to ~50% at 6500rpm. That is likely why you are losing boost. Have your tuner check that map.
[edit] Closer to 40%. Wastegate Duty Cycle is tied to throttle opening as well so it would have shown up in data logs.
Airboy is online now   Reply With Quote
Old 04-23-2009, 03:40 AM   #15
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
this. damn DBW.
KP is offline   Reply With Quote
2006 Subaru Wrx Tr 20g Turbo Install With Pictures ! xfactor23 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 102 09-20-2011 10:02 AM
WTB: 20G for my 2006 WRX TR 06WRXMIKE Private 'Wanted' Classifieds 0 10-16-2007 10:31 PM
2006 wrx tr fmic 20g cobb protuned for sale hector Private Vehicle 'For Sale' Classifieds 13 07-21-2007 07:26 PM
2006 wrx tr fmic 20g cobb protuned for sale hector Private Vehicle 'For Sale' Classifieds 0 12-26-2006 01:14 AM
2006 wrx tr or 2006 civic si dlroto Newbies & FAQs 201 07-25-2006 03:57 PM
