Old 04-20-2009, 12:21 PM   #1
ridexstraight
Member#: 177384
2002 impreza wrx
hella flush wrb yall
Default calling anyone thats done a 04-05 to 06-07 front end conv
hey im just about done with my conversion and im a lil stumbed with the headlight wiring just wondering if any of the guys that did they f.e.c. have any opinions,, im thinkihng either cut all the wires and hard wire them,,, or does anyone make a conversion harness? i had light werks retro fit my hids but he didnt has a harness for me
ridexstraight
ridexstraight is offline   Reply With Quote
Old 04-20-2009, 07:55 PM   #2
mikebdubsuby
Member#: 209195
2004 Impreza
SRR
Subaru Stars
Is there a company that makes a kit for this conversion?
mikebdubsuby is offline   Reply With Quote
Old 04-21-2009, 01:25 PM   #3
girodisc
Member#: 177674
Yes chargespeed make a fiberglass front core support to convert to 06 front end with both the 02-03 and 04-05 body styles. Theirs only requires cutting and bolting the pieces on. If you want to do it with OE Subaru parts and weld them you'll need the piece that runs along the top, the center support, and the 2 headlights pieaces. You will then need to cut your side aprons back a little so the headlights will fit. From there its a complete bolt in.
Here is the link to the Chargespeed stuff:
02 to 06 Face Lift Kit:
Johann @ Girodisc
girodisc is offline   Reply With Quote
Old 04-21-2009, 01:43 PM   #4
evoklr101
Member#: 139159
0207 did i hurt your
feelings? grow a pair
as for the wiring goes, i did a swap from 02 to 06. went to walmart and got some male and female quick releases. or whatever there called. cut all the wires and put those on them. took several tries to get all the wires in the right spots but it worked out great. hope this made sence.
evoklr101 is offline   Reply With Quote
Old 04-21-2009, 02:04 PM   #5
girodisc
Member#: 177674
You can also get waterproof automotive make and female plugs from 1-6 wires and they works really well. I bought a kit that had a bunch and I use them a lot.
Johann @ Girodisc
Old 04-21-2009, 09:11 PM   #6
20BlueWRX02
Member#: 156673
2007 Impreza 2.5i
CGM
I would really suggest soldering all your connections, especially headlights. Then heat shrink everything.
If you have access to a multimeter you can use this to check which wire is which.
20BlueWRX02 is offline   Reply With Quote
Old 04-22-2009, 11:18 AM   #7
wrx03.4wz
Member#: 122375
03.7 I own 2 of them
White & Black
all of you are right , i did my swap after drifting into a the front of a Semi Truck, not nice but it went from this http://viewmorepics.myspace.com/inde...mageID=4445439
to this
http://viewmorepics.myspace.com/inde...ageID=21619589
full front end break down
http://viewmorepics.myspace.com/inde...ageID=25263488
the test fit "very important btw"
http://viewmorepics.myspace.com/inde...ageID=31507282
to this and im waiting on the side vents, side grills, tow hook cover and STi rear fender flares I had the front and rear done, Im all about togetherness.
headlight wires where cut and to mate with 06/07 headlight harness very easy.
http://viewmorepics.myspace.com/inde...ageID=52830919
Rear end Swap
http://viewmorepics.myspace.com/inde...ageID=52830841
wrx03.4wz is offline   Reply With Quote
Old 04-22-2009, 12:00 PM   #8
ridexstraight
Member#: 177384
2002 impreza wrx
yea i work ata stereo shop so wireing isnt a problem i just wish there was a easy conv. harness i had 06 wrx headlights also not the sti hid ones is the plug any differnt or anything?
Old 04-22-2009, 12:44 PM   #9
wrx03.4wz
Member#: 122375
White & Black
hmm good question, I can't tell you that and the conversion is easy with the right tools. dont sweat it
Old 04-22-2009, 01:05 PM   #10
ridexstraight
Member#: 177384
2002 impreza wrx
alrighty im just worryed cuase i dont know what plugs went where cuase my lights were smashed and body shop removed with out lableing so ill just have to test them,,, and the hid harness and auto lights and all the goodnesssss
Old 04-22-2009, 03:40 PM   #11
wrx03.4wz
Member#: 122375
White & Black
true but it shouldn't be that nerve recking I hope
02 bugeye to 06-07 front end install plus pics alex_s817 Subaru Conversions 93 10-29-2012 08:47 PM
WTT: my 2002 wrb front end for either 04-05 or 06-07 front end F ur PONY Exterior/Styling 3 06-07-2010 04:09 PM
SubyDude.com | 04/05 and 06/07 Front Lips IN STOCK AND READY TO SHIP!! **New Prices** suby_dude Exterior/Styling 24 07-30-2008 03:46 PM
05 STi to 06/07 Front End Conversion mug23 Interior & Exterior Modification 5 10-22-2007 01:26 PM
Wanted 04-05 or 06+ complete Front end for conv. RedScooby02 Private 'Wanted' Classifieds 2 12-02-2006 06:22 PM
