Old 04-20-2009, 01:56 PM   #1
billionaire7
Member#: 122428
Default 586 Awhp @ 22 Psi, E85
586 AWHP @ 22 PSI E85 ONLY!
5300 ft. Elevation
Ambient Temp = 62
2006 Subaru STi
Garrett - T4 Twin Scroll GT4088-R, 1.08A/R Ex.
Full-Race - Twin Scroll Exhaust Manifold + TS Up-Pipe
RAW Performance - Stage 5, 2.5 Liter STi semi-closed deck case, Darton Ductile Iron Sleeve Liners,
Modified forged EJ257 crankshaft ,High Performance Main & Rod Bearings, Custom Pauter Machine Forged Rods,
Custom & Coated CP Forged Pistons, High Performance Piston Rings, Fully Balanced & Blueprinted, 9,500 Rev Limit Recommended*
Cosworth- Head Specifications:
* CNC Ported/Machined finish port
* New Castings
* Hand blended finish work
* Intake 14.63% (average) 22% (max) increased flow
* Exhaust 30.56%(average) 41% (max) increased flow
* 4-angle Inlet Valve job
* 3-angle & radius Exhaust Valve job
* Valves are lapped
* Back-Cut Inlet Valves
* Heads are Ultra Sonic cleaned prior to assembly
* Heads are Serialized and sport a machined Cosworth logo
* +1mm Stainless Steel Intake Valves (1800 degrees max.)
* +1mm Inconel Exhaust Valves (2400 degrees max.)
* Performance Valve Springs
* Titanium Retainers
* Hardened Steel Spring Platforms
* Knife edged ports
Cosworth- Cams 278 Intake, 274 Exhaust
The graph says 24.88 PSI but my Defi gauge read 22 and the Hydra read the same. We could have cracked 600 on 22psi. But because we were losing fuel pressure up top we never tried. The twin in-tank fuel system I am using works great! But the Buschur Modified Walbro's are failing.
billionaire7 is offline   Reply With Quote
Old 04-20-2009, 02:00 PM   #2
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Oh yeas , man great job, get a log into the official road dyno list, awesome, welcome to the corn army!
Kastley85891 is offline   Reply With Quote
Old 04-20-2009, 02:04 PM   #3
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
Hot mama!
godforbid67 is offline   Reply With Quote
Old 04-20-2009, 02:34 PM   #4
billionaire7
Member#: 122428
Thanks for the kudos guys!
This project has been a pain in the behind. But all great things come in good time.
Old 04-20-2009, 02:35 PM   #5
RealStreet
Member#: 205916
2003 Subaru WRX
in the 10's and the bends
Cool stuff. Can you post the Standard CF
RealStreet is offline   Reply With Quote
Old 04-20-2009, 02:36 PM   #6
jordanretro1223
Member#: 143039
2007 STI
Satin White Pearl
Holy ****!! This car is nuts. Congrats man, you've got some car here.
Oh, and we NEED videos now!!
jordanretro1223 is offline   Reply With Quote
Old 04-20-2009, 02:43 PM   #7
billionaire7
Member#: 122428
Soon. I've got to swap fuel pump first. We are not done.
Soon, I want her to run safely first!
Old 04-20-2009, 02:48 PM   #8
don_radeon
Member#: 202583
2004 Legacy GT
Black w/Domo on back
That's absolutely impressive.
don_radeon is offline   Reply With Quote
Old 04-20-2009, 02:52 PM   #9
godforbid67
Member#: 137168
06 Built SGM WRX
yeah definetly get some vids up!
Old 04-20-2009, 03:03 PM   #10
cpturbo
Member#: 49175
2004 STI
Do you happen to have an rpm graph? How about a torque with hp graph. It helps us see the spool characteristics of your kit! I wonder how your oil pressure is behaving at high rpm.
Thanks
cpturbo is offline   Reply With Quote
Old 04-20-2009, 03:08 PM   #11
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
Can't wait to see track times! Also, who did the tune- Cam???
blkscooby is offline   Reply With Quote
Old 04-20-2009, 03:20 PM   #12
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Holy **** you must be a billionaire or something
Old 04-20-2009, 03:25 PM   #13
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
This car is perfect. And at that power level, with that motor, will last forever. That motor is probably still sleeping at that boost level. Ever gonna wake it up
****PERFECTION****
STi Mikey is offline   Reply With Quote
Old 04-20-2009, 03:28 PM   #14
nxttruck2002
Member#: 90879
What does a graph with the x-axis having mph show?
Post up RPM graph
nxttruck2002 is offline   Reply With Quote
Old 04-20-2009, 03:35 PM   #15
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Wow! one hell of a machine. Black on gold FTW!!! And do you rev that thing all the way out to 9500 rpm? I'd love to hear that... Congrats on that beast.
Steve.804 is offline   Reply With Quote
Old 04-20-2009, 03:37 PM   #16
DFv2
Member#: 173774
2008 STi
Lightning Red
Post up RPM graph
Give the people what they want to see!! HP/TQ vs RPM, uncorrected!
But that is a LOT of power for such little boost is it not?! What kind of timing are you running in the, ahem, 87 mph region ?
DFv2 is offline   Reply With Quote
Old 04-20-2009, 04:05 PM   #17
GeneralTJI
Member#: 152680
WOW that thing is nasty... what RPM roughly did you make peak HP at?
GeneralTJI is offline   Reply With Quote
Old 04-21-2009, 01:56 AM   #18
billionaire7
Member#: 122428
Thanks
The DynoJet was having problems picking up the RPM. So we calculated it the old fashioned way. And the oil pressure is fine for no. I'm only spinning to 7k.
Thank you!
****PERFECTION****
Thanks! Kudos to you buddy!
The motor is doing what I expected but I'm looking for reliability. So 15 psi is just fine for me!
Thank you also! I'm only spinning to 7k. No dry-sump yet.
I'm thinking that peak torque spiked between 4500 and 5500.
Old 04-21-2009, 02:17 AM   #19
k04sti
Member#: 171773
04 wrx sti
jbp dom 3 xtr w meth!
All I gotta say is...Wanna trade?
k04sti is offline   Reply With Quote
Old 04-21-2009, 03:11 AM   #20
vik_wrx
Member#: 194804
2004 VF43 WRX - sold
Wow man that is business in a black suit! great numbers
vik_wrx is offline   Reply With Quote
Old 04-21-2009, 08:22 AM   #21
bertune
Member#: 107290
This is the most impressive 40R subaru i've seen up to date! Let's see what it will do when the turbo hits it's sweet spot 28+ psi. Was that a 4th gear pull?
bertune is offline   Reply With Quote
Old 04-21-2009, 09:53 AM   #22
TopEndPull
Member#: 126112
93.5 Toyota Supra
Red
nice numbers! what size injectors do you have?
TopEndPull is offline   Reply With Quote
Old 04-21-2009, 09:54 AM   #23
xchristensen
Member#: 116562
2005 STi (PSM)
mmmhm impressive
I wan'ta one!
xchristensen is offline   Reply With Quote
Old 04-21-2009, 09:56 AM   #24
Badazzcr
Member#: 67693
4 Making them
faster then anyone else.
So what kind of numbers did it make uncorrected? I am sure with the elevation it was near an SAE 1.2 correction.
Badazzcr is offline   Reply With Quote
Old 04-21-2009, 11:49 AM   #25
06njsti
Member#: 150986
06 #001 LSB STi
wow this car is just a monster, i could never imagine having that much power
06njsti is offline   Reply With Quote
