Old 04-17-2002, 07:41 PM   #1
jazzman
Member#: 9186
00 Legacy GT
red
Unhappy Need help with rear O2 sensor wirting diagram for 2000 Legacy GT
All,
I'm trying to troubleshoot a CE light due to an Brullen exhaust
installation. The code is P0420, and I need to find out what the
rear O2 sensor wiring corresponds to.
I spoke to a mechanic regarding the wiring diagrams for
the rear O2 sensor. I had a look at them myself.
The wiring codes indicate colours of the HARNESS (i.e. the wires from
the ECU) not the rear O2. It seems the colours of the sensor wiring
can
change, but the harness colours are consistent.
Trouble is the while the diagrams give the colour code, they do not
readily indicate the PURPOSE of each wire. Was wondering if anyone
way could help. The purpose is so I can get the right connections so
I
can install Brullen's fix. (This is a circuit that is placed between
the
rear O2 ands ECU, it is supposed to clear the CE light. We tried it
on my car but the CE light came back. My guess is that it was
connected
incorrectly, and this is why the light went back on. It has since
been
removed.)
Here is what I got for the harness wiring:
- White (Pretty sure this is ground)
- Black / White (Goes to the Shield and Sensor ground joint connector
under the dash: Pretty sure it is ground)
- Yellow / red (tied to the front A/F sensor, we believe this is the
12V wire for the heater.
- White / Blue (goes direct to ECU)
Can anyone confirm?
Thanks all.
Dean Hummel
Ottawa Canada
jazzman is offline   Reply With Quote
Old 04-17-2002, 10:36 PM   #2
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
jazzman - the wiring loom should fit right in. If you have the CEL fix in, more likely than not, you're front O2 sensor has a problem. IIRC there was a recall by Subaru done on front O2 sensors.
GTBGUY is offline   Reply With Quote
Help With "Universal" O2 Sensor Wiring. BrysImpreza Normally Aspirated Powertrain 6 05-31-2009 10:41 AM
Wiring Diagrams for 1990 Legacy GT Turbo Legacy_H6TT Electrical & Lighting 2 11-19-2007 11:17 PM
Rear o2 sensor wire on a 2000 2.5rs LB2.5rs Electrical & Lighting 2 08-15-2003 10:42 PM
need help fast: lengthening O2 sensor wires speedracer47 Normally Aspirated Powertrain 9 01-17-2003 02:05 AM
New O2 Sensor & ECM for MY00 Legacy GT! Jason Technical Forum Archive 16 09-08-2000 10:14 PM
