Old 04-20-2009, 05:22 PM   #1
whatishe
Member#: 65711
2004 WRB WRX Wagon
2.5 Hybrid STI Conversion
Default About to do swap; any problems with this parts list
I am about to begin my EJ207 and 04 6MT swap into my 04 WRX Wagon. Does anyone see any outstanding items missing or any problems that jump out at you? Assume that I will reuse stock parts of my EJ205 Block when possible.
Engine Build List:
EJ207 Block
CP Pistons
Paulter Rods
Race bearings
All new belts and gaskets
Machined EJ205 Heads
JDM STI valves
Double Springs
Crower 272 cams
Modified 550 injectors
Modified Headers
Modified Intake manifold
Perrin Fuel Rails
550cc Injectors
Large TMIC
UTEC
Blitz MBC
FP 18G IWG
Full UP/DP/Exhaust
Group N or better motor mounts
Transmission Swap:
04 6mt
short shifter
04 Automatic Wagon Drive shaft
3.9 legacy rear diff
lightened flywheel
Cluthmasters FX300 clutch kit
Spiider DCCD dual mode controller
Anyone see anything I should worry about?
whatishe is offline   Reply With Quote
Old 04-20-2009, 07:38 PM   #2
mannac
Member#: 161038
2005 LGT
'72 Datsun 240Z
Add a new fuel pump to that list.
mannac is offline   Reply With Quote
Old 04-20-2009, 07:57 PM   #3
whatishe
Member#: 65711
2004 WRB WRX Wagon
Forgot, I have a walbro 255 in the car already.
Old 04-20-2009, 07:58 PM   #4
whatishe
Member#: 65711
2004 WRB WRX Wagon
turbo, intake, injectors, exhaust, dp, up, tmic, mbc, and utec are all from my last build on the stock motor
Old 04-21-2009, 03:18 AM   #5
whatishe
Member#: 65711
2004 WRB WRX Wagon
any other suggestions? Car goes to the garage tomorrow and I start tear down.
Old 04-21-2009, 10:00 AM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
access to a open source cable to set your injector base .. then use the utec for adjustments and tuning
Is anyone using this jack/jack stands? Any problems with these? nkkilla Newbies & FAQs 8 07-27-2005 06:33 PM
Exhaust-less STi? Any problems with doing this? Z06-KILLR Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 03-17-2004 01:26 PM
Do our cars have any problems with cross fire? SubaruImpreza_power Newbies & FAQs 4 09-30-2003 07:32 PM
Any problems with your Fibreglass body kit parts? HOK Canada Region Forum 9 06-24-2003 11:48 PM
anyone get a chance to do some muddy drivin with this rain? Dynobyte Southern California Impreza Club Forum -- SCIC 0 11-01-2000 03:12 AM
