Old 04-21-2009, 10:34 AM   #1
Sir-Knight
Member#: 73636
2007 Impreza 2.5i SE
newport blue pearl
Default small oil leak
Hey folks, I was at my mechanic's the other day for my 48k km service/inspections, turns out I've developed an oil leak recently... 2 in fact.
One I'm not so concerned with, it's the passenger side solenoid for the AVLS. It's not near anything and if it drips or seeps, it's on the backside and will drip away from anything hot.
The other leak, well it's actively weeping when the car runs. It's on the driver's side, right under the oil filler neck, apparently it's the switch/sensor for the driverside AVLS. I definitely didn't notice oil burning smell the week before the inspection, so it developed recently and periodically smells like burning oil for a few seconds.
My car is scheduled to go in for inspection at a trusted dealer to confirm these 2 leaks and see if they are covered under warranty, if not it's back to my mechanic to git r done.
My question is, with the amount of oil that's weeping from this switch/sensor, am I safe to drive the car for 800-ish kms this weekend, and possibly 1 or 2 high rpm runs? How much oil pressure goes through this switch, if running into the range ALVS activates creates enough pressure, will this switch leak more?
Sir-Knight is offline   Reply With Quote
Old 04-21-2009, 12:27 PM   #2
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
I'd say your fine driving the 800km if you keep an eye on the oil level, but I would not push it.
chazly413 is offline   Reply With Quote
help. small oil leak methinkadoo General Community 3 08-04-2005 12:54 AM
Small oil leak with 2.2 liter Legacy...Help anyone 98LegacyAWD Subaru Conversions 8 09-10-2004 12:48 PM
Small Oil Leak Under Engine? KnightWRXRider_ Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 32 06-20-2004 10:48 PM
Small Oil Leak/ 60k tune up Questions Ahzlon Normally Aspirated Powertrain 1 11-19-2003 08:38 PM
Small Oil Leak mynew02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-10-2002 08:58 AM
