Welcome to the North American Subaru Impreza Owners Club Tuesday October 25, 2016
Closed Thread
Old 04-17-2002, 10:15 PM   #1
Member#: 5297
1994 Impreza
Brighton - Glacier White
Default Help!!!!
I have tried everything!!! I have a 94 FWD Impreza 5spd. At partial throttle, I get a rocking/hesitation feeling, it usually only happens when I'm lower in an RPM. Things I have already checked are, spark plugs wires - replaced, PCV Valve - replaced, Fuel Filter - replaced. These were all things that were suggested might be the problems, I've also since changed the air filters, had the mass air flow sensor as well as throttle positioning sensor looked at and those both seem to be in good working order. The time I noticed this first happening was after I had my half axles re-packed with grease, and a new caliper put on. The car has about 127k on it, and had a new clutch put in at 110. I'm stuck, anyone have any ideas?!
Nesta722 is offline
Old 04-17-2002, 10:21 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
North Ursalia is offline
Closed Thread
