Old 04-21-2009, 01:00 PM   #1
treemandan
Member#: 207774
Default The Dan's 2.5
Come one, come all. Drop what you are doing at once.
Just a quick overview:
I worked in repair shops and compiled about 8 years experiance working of pretty much anything as a professional. I have always been a tree climber as well. If you think cars are fun...
My outback, which I just adore, needs some work so firgured I would do the head gaskets at my shop. I usually do more tree stuff than car stuff but have usually done my own work. I have an f350 and an f150 along with other tree related equipment. I will say this though: whenever one of my saws isn't running right ( or I drop it out of the tree) I don't mess with it, it goes right to Bill Neff at Main Line Mower where its taken care of real well. Thing is I use Stihl so I don't take them in very often.
Sorry to get off track, one more thing; I do invite you all to visit Arborsite.com. There are tons of pics off all the crazy stuff I do there as well as some amazing pictures of others, video too. If you go and want to find me, I am The Dan, Treemandan, though my name is Ben.
So that part is done. I guess I need a new tensioner?
treemandan is offline   Reply With Quote
Old 04-21-2009, 01:01 PM   #2
treemandan
Member#: 207774
Also I found this.
I am hoping that it is just from the upper hose seeping into the t-belt cover. Has anyone seen this before?
Old 04-21-2009, 01:03 PM   #3
treemandan
Member#: 207774
I was wondering if I had to really pull the cams before I pulled the head? I took the one side rocker arms off, cause the manual told me to but is that necessary? Kinda thinking flat-rate would be just unbolt the head. I am in no hurry though myself.
Old 04-21-2009, 01:03 PM   #4
Un0RiGiNaL
Member#: 189748
You are crazy
Un0RiGiNaL is offline   Reply With Quote
Old 04-21-2009, 01:09 PM   #5
funky monk
Member#: 143094
08 LGT
DBM
I like how the thread is progressing in a stream-of-consciousness sort of way. What's going on?
funky monk is offline   Reply With Quote
Old 04-21-2009, 01:11 PM   #6
Jerry Xu
Member#: 36629
07 2.5i
Regularly Being Modified
Not necessary i see you have SOHC. You can even do the HG in the car.
Setup your profile so we know which car you're working on.
Jerry Xu is offline   Reply With Quote
Old 04-21-2009, 01:12 PM   #7
treemandan
Member#: 207774
Originally Posted by Un0RiGiNaL View Post
You are crazy
Did you have to go to Arborsite to figure that out or was my post enough?
Now can you help me with my car?
Old 04-21-2009, 01:16 PM   #8
treemandan
Member#: 207774
Great, then its working! " stream- of- consciousness" ? Yes,that's why I bought the subaru.
Old 04-21-2009, 01:26 PM   #9
treemandan
Member#: 207774
Yes sohc motor. 02 outback wagon. I posted the pics think it was enough. I don't know enough about all the different motors subaru has out there. I remember one motor if you took the oil fill cap off the engine would stumble bad.
EJ25 is cast on the block, in the front by the oil pressure sending unit. The hood sticker: 2.5 sfi.
I pulled the motor to seal the back of it as well. Also, I am getting kinda old and don't have a lift, I would rather go through the torque sequences with it on the stand.
I am useing a Haynes manual, so everytime something important comes up I double check it.
Old 04-21-2009, 01:34 PM   #10
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
get a factory manual, I've heard that the torque values of the other ones may be suspect. Yes, you'll need a new tensioner, that one is toast.
Old 04-21-2009, 05:19 PM   #11
2.5i
Member#: 112986
N/A Cam'd & Cornfed
DOM TUNED 06 Impreza
The 2.5s in the RS you can pull the heads off with out pulling the cams.
2.5i is offline   Reply With Quote
Difference between the '06 WRX 2.5 and the RS 2.5? EcksJay General Community 3 09-12-2005 07:57 AM
Anyone remember the 190E 2.5 Evo 2? Lightsped Off-Topic 9 09-08-2003 02:05 PM
what springs drops the WRX 2.5 in front and 2 in back? Wrx0R Brakes, Steering & Suspension 9 01-27-2002 03:19 AM
Does the WRX use the same oil filter as the 2000 2.5 RS? SuperFreq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-19-2001 01:58 PM
