#1 |
Member#: 101199
NWIC
Vehicle:2013 BRZ Black |
You're kidding, right?
http://www.scca.com/documents/Fastra...k-may-solo.pdf The following rule change proposal is published here for member feedback: Add to 14.10.F.1 as follows: “Alternate software maps which violate these restrictions may not be present during competition, regardless of activation.” ![]() I already wrote my letter - and I almost NEVER write letters. I'm totally not comfortable daily driving my STU map for reliability reasons. If this goes through, I'll have one expensive STU car that won't see another national event.
#2 |
Member#: 30907
SWIC
Vehicle:SWP GDB-G |
What does that rule even MEAN? How is software that is not in use, still 'present'?
This is absurd. |
#3 |
Member#: 71634
Vehicle:In hibernation... |
Annie,
If I reading this correctly, only ST* illegal maps would be deemed illegal. So you could run a "stock map" and "STU legal" map on your STU STi. However, it would mean that you couldn't have a high boost "Cobb Stage 2" map on the car. That's how I'm reading it. So you wouldn't have to daily drive on your STU map. -Chike P.S. KC/ScoobySouth/etc what's your take on it??? |
#4 |
Member#: 101199
NWIC
I'm not going to run a stock map and risk overboosting (anyone that's seen me drive knows I've got no issue with aggression - I like to play a little on the street!)
Max made a good point to me - I could argue that I only have the base (stock) map and the STU map flashed on my ECU when competing, the "other" maps are on a toy in my toolbox (AccessPort). But that's clearly not their intent... |
#5 |
ForumWars Winner!
Member#: 196948
TXIC
Vehicle:2012 WRX SWP TexasRallysport |
Uhhhhh who else saw the new Hyundai Genesis Turbo coupe in G-Stock?????????
#6 |
Member#: 71634
#7 | |
Member#: 31821
SCIC
Vehicle:2006 STR MX5 WRB BRZ Limited |
#8 |
Member#: 71634
#9 | |
Member#: 16
BAIC
Vehicle:1964 Autodynamics Formula Vee |
My second, third, fourth and fifth thoughts, however, were: -weighing 3250-3300 pounds in stock class form (3380 for 2.0T Track) -having skinny 18 or 19" wheels (track model) -typically short 2nd gear on the 6spd -pretty damn wide car for transistion heavy courses Chris H. |
#10 |
Member#: 60566
SCIC
Vehicle:2002 WRX Unicorn 2001 Legacy L 2005 XT 5sp |
Doesn't matter. How is it policed?
Besides being caught with your hand on the cruise control and your finger in your bottom. Very high brow Max. ![]() <--- also very interested in how the genesis does. I have a thing for pudgy cars. Edit: I should have prefaced with "As annoying as it is," |
#11 | |
Member#: 62386
Vehicle:2008 Honda S2000 Chicane Silver |
-Colin |
#12 |
Member#: 31821
SCIC
Colin, since 08+ STI's can switch maps from the factory using the I-Drive controller, one could make the arguement that they are all illegal in STU in stock form. Nice
![]() Paul Magyar - are you listening?!! |
#13 |
Member#: 5218
Vehicle:96L Most Over- Developed Beater |
It looks to me, like known flashing programs will be referenced upon request, and then disclosed as to the number of maps present in the ECU memory. If more than one is present, it would be disallowed, or subject to protest.
There is no way to disallow an ECU containing a single map, but then again, they're going to need to define a "map" and what constitutes the "presence" of a map. Would it be in the ECU memory? In memory capable of being connected to the ECU reasonably easily? On the site? Written and available to use by anyone? What a sad-sad way to kill off a category that started with the best intentions. Jay |
#14 | |
Member#: 192173
Vehicle:2006 STU prepped STi Sponsored by Agile Auto |
On sccaforums.com
That makes more sense. Two maps on the car at the same time that can be switched on the fly. Otherwise there would be a whole lot of illegal cars. ![]() |
#15 | |
Subtly Outspoken
Moderator Member#: 238
Vehicle:99 Ver6 Recreation JDM Speedwagon 3 LSDs..:) |
#16 | |||
Subtly Outspoken
Existing Rule
#17 |
Subtly Outspoken
I read it as something that can be done on the Fly....so an 08 that has that factory...would be illegal???? for STU.
Annie...don't think you have anything to worry about...you should be fine.. ![]() |
#18 | |
Subtly Outspoken
Now the whole Section With the rule proposal :
#19 |
Member#: 31821
SCIC
This means that 08+ STI's must have the same map on the three IDrive knob positions to be STU legal.
Accessports are still fully legal. |
#20 |
Subtly Outspoken
exactly....^^^^^ thats exactly how I read it...
#21 |
Member#: 101199
NWIC
Wish they'd simply written it clearer so that people like me (who really really get concerned over having a legal car) don't misinterpret the darn thing
#22 | |
Member#: 37359
Vehicle:2003 WRX |
1) This means that 08+ STI's must have STU legal maps on the three IDrive knob positions to be STU legal. 2) Accessports are still fully legal if the base map and realtime map are both STU legal. |
#23 |
Member#: 31821
SCIC
#24 | |
Member#: 45464
Vehicle:91 E30 325i 95 E36 325is |
At least I'm only doing local events so I don't think it really will be a big deal for me. This also gets into the 'which map is stock' argument on the 08 STi. Ugh I wish they would stop messing with the ST* rules. They should go pick on the stock classes or *SP for a while. |
#25 |
Street's closed, pizza boy
Member#: 17301
Vehicle:is the "dark side" 06 Evo #7 STU, 05 Saabaru |
Eh. How are you going to know? Run around pushing everyone's cruise control button, seeing what happens and then datalogging it before and after? It's not like a bunch of balloons pop out of the hood scoop saying "super boost enabled!"
I dunno. The Accessport lets you have a base map and a realtime map. One could argue that using a realtime map would violate this rule because all you have to do is reset the battery to get the basemap back. That is not too far away from what they are trying to prevent. And how does someone know if you're using a legal realtime map? At least on the APv1, the "show current map" only tells you what basemap is loaded, not what realtime map is loaded. How about the APv2? I don't have one of those and have no idea if it is smart enough to tell you your realtime map or not, or whether it has any of those cruise control button features. How about ECUTek - is there some sort of way of knowing how many maps are loaded into it? Or are all those cars instantly illegal? How about the open source stuff? Is it possible for people to create their own map-switching sequences (entering the Konami code with your shifter, or something)? I don't know yet how I feel about it other than thinking a) Terry Fair is probably ecstatic and b) the people that would violate it are the scumbags that are going to cheat anyway and probably have a way around it, i.e. it has good intentions but will do little to help prevent cheaters and will probably cost people money who have spent $$ trying to be legal. "If you outlaw multiple ECU maps, only outlaws will have multiple ECU maps" :shrug: Last edited by ButtDyno; 04-21-2009 at 11:06 PM. Reason: clarity |
| Thread Tools | |
| Display Modes | |
| May FASTRACk 2010 | JamesWilson2 | Autocross | 6 | 04-22-2010 10:08 AM |
| May Fastrack | Patrick L | Motorsports | 8 | 04-23-2007 01:32 PM |
| May 2006 Fastrack is out | rankink | Motorsports | 9 | 04-21-2006 08:09 PM |
| May FasTrack | PhilC | Motorsports | 4 | 03-31-2005 11:08 AM |
| EVO 8 class set in May FasTrack | MNbiker | Motorsports | 15 | 05-03-2003 07:25 AM |
