Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 04-22-2009, 12:42 AM   #1
canuck37
Member#: 87491
03 Sport
Blk/Slvr
Default ATTN: ARE Cap Owners
For a number of reasons, I find that I am either going to have to sell my 03 Baja or buy an ARE cap for the back. I built my own OzzBros style cover some time ago, which is very nice but doesn't provide enough covered storage.
I have a few questions for any ARE owners out there who might care to comment.
1) When installed, is the 3rd brake light permanently disabled or can it be re-connected when running without the cap on?
2) Any noticeable difference in vehicle handling and/or mileage when cap is installed?
3) Did you have it installed professionally and if so, any problems encountered when taking it off and reinstalling yourself?
4) Are water leaks a concern?
5) Just out of curiosity, my 03 is the black/silver version. I am tossing around either a silver cap or a black one. Maybe one of you PhotoShop wizzs could show me what that might look like??
6) When the cap is locked, is the back totally secure or can someone still get the tailgate down and gain access easily (yes, I realize if someone really wants in they will get in)?
7) Are the any interior lights already installed?
8) Are the side windows screened or able to open? (not clear on their website)
Any other issues that you have encountered with the cap that might make my decision easier?
I really don't want to part with my Baja, but need the additional covered storage for long and frequent trips I am having to make now. I would appreciate any constructive feedback. Thanks,
canuck37 is offline   Reply With Quote
Old 04-22-2009, 11:04 AM   #2
weiVA
Member#: 72942
2005 Baja T
Atl Blue Pearl
I bought mine used, but it should come with a wiring harness. IIRC, the harness does disable the Baja's 3rd brake light. Since the receiving end consists of female spade connectors, I'm going to splice a solution myself which allows both the cap and Baja light to operate. There is about 6" of wiring coming from the cap.
No change whatsoever. I was hoping for a gain of 1-2mpg highway, but nope. It feels like it weighs about the same as our factory hard cover too (just distributed differently) so handling really isn't affected. No noticeable change with cross winds either.
Bought used. Installed myself. It definitely requires two people as it's bulky and watch your fingers! Having a third person push up from the inside or have a lift hold it up slightly during removal goes a long way as pinched finger insurance.
Haven't had any problems except a bit of rubbing on the paint since we didn't have truck cap mounting tape.
Dry just like the factory hard top even in hurricane force rain.
I'd go black to match the Baja body, but that's just me. I'm not imaging saavy.
6) When the cap is locked, is the back totally secure or can someone still get the tailgate down and gain access easily?
The lock and handle are pretty durable feeling. If you were to not open the liftgate and unlatch the tailgate, it will hold up the tailgate. Of course, you could pull hard on the tailgate and break the cap's liftgate. They can also just break the glass as you alluded to.
The tint on the cap is dark. With ambient sunlight or parking lot lilghting, someone would have to put their face directly onto the glass to peep in. Unfortunately, the tint and added obstructions increase your blind spots dramatically. It's doable, but I've considered blind spot mirrors as an added precaution.
Also, if you have the Subaru security system, the jounce sensor will go off if you close the liftgate without disarming the alarm. The liftgate closes with that satisfying of a slam.
There are no additional lights. I make use of the Baja's built-in cargo light. I haven't had a need for additional lighting than that.
The side windows are not sliders. They open via turn knobs, folding outwards. The screens are mounted on the inside. When driving, enough air circulates to make towels flap lightly which is nice for airing out wet gear.
The ARE cap complements the Baja perfectly. Just do it! It has made the Baja infinitely more useful. It provides easy access, lockable, dry storage for your cargo. Additionally, the extra height allowed me to finally put in spreader bars to compartmentalize groceries, bungie cords, etc. Many daily objects fit now without folding open a hard top halfway. We now either have the cap on full time or off, there hasn't been a desire to put the hardtop back on really.
Even people who hate the looks of the Baja comment on how it looks 1000% times better with the cap on. Me, I always thought the Baja looked just fine.
The *only* negative I've come across is that the bed extender can not be used with the cap. The cap gets in the way since the extender needs to be vertical for installation. I suppose I can dremel the mount a bit to make it just pop in, but there haven't been enough occasions where I need the cap and extender. And such a mod would allow the bed extender to pop right off unless I put a latch on it.
weiVA is offline   Reply With Quote
Old 04-23-2009, 07:13 PM   #3
canuck37
Member#: 87491
03 Sport
Blk/Slvr
Thanks a bunch for your thoughts, it really helps to have someone else's perspective who has been there/done that! I actually went into the local ARE dealer today and got a quote ($2300 installed! - whew!) and am almost ready to jump. I am going to call around to some other ARE dealers within a few hundred miles of here and see if they are any cheaper. The fellow said he had done 2 others and they are by far the hardest install they do. Said it took 4 guys about 3 hours to get it all done. I have read it is a pretty challenging install, but didn't realize it was that bad. Guess that's why they are charging $150 to install it... He also said it was probably best to leave it on, once installed, due to the difficulty factor and to avoid leaks, etc..
Dealer advised that the 3rd brake light is wired directly to the rear brakes, not the center light on the roof and that they just remove the bulb from the existing light. Also, he said there is an interior light above the rear door. Wonder if that is a change from the one you got or he is mistaken? No big deal either way really.
Anyone else have any comments that might help me decide?? Thanks again!
Old 04-24-2009, 08:56 AM   #4
weiVA
Member#: 72942
2005 Baja T
Atl Blue Pearl
Sounds like ARE may have finally used an inline tap like the one for a hitch receiver.... hmm... gives me idea. But why remove the bulb? The 'glare' won't impact your visibility.
3 hours sounds like a long time. I have mine on and off in 15 minutes, granted the center light isn't hooked up but you'd think that'd be a one time thing. I will agree that once you have it on, you won't want to take it off. But for that matter, you won't need to take it off. It will change the way you think of the Baja.
Edit: Wiring harness for me as a mod = too expensive to justify the time savings. Splicing is back in my schedule tomorrow.
Old 07-16-2011, 03:19 PM   #5
Kev5n24
Member#: 105711
2005 Subaru Baja
Black on Black
just pried one, got the same quote. totally more then i expected, but im thinking about it. finding a used one probably very needle in hay stack-ish eh?
Kev5n24 is offline   Reply With Quote
Old 07-17-2011, 01:46 PM   #6
Traffcon21
Member#: 280491
Canuck37, what are you going to do with the bed cover you have now? I need one, let me know
Traffcon21 is offline   Reply With Quote
Old 07-18-2011, 12:43 AM   #7
canuck37
Member#: 87491
03 Sport
Blk/Slvr
I've had it for over 2 years now and am very happy with it. Not planning on selling the Baja yet, but when I do, I may decided to sell the ARE seperately, since it seems to be in demand and might be worth more than on a trade......
Old 07-18-2011, 02:23 PM   #8
Traffcon21
Member#: 280491
I was talking about the flat cover, not the ARE.
Old 07-21-2011, 05:18 PM   #9
canuck37
Member#: 87491
03 Sport
Blk/Slvr
Sold it - sorry......wasn't much use.
Old 08-15-2011, 12:09 PM   #10
PenguinSub
Member#: 271739
There is one for sale on scoobytruck.com right now. I was just looking at it today. Check it out:
http://scoobytruck.com/bb/viewtopic....p=10641#p10641
PenguinSub is offline   Reply With Quote
Old 08-15-2011, 01:52 PM   #11
Kev5n24
Member#: 105711
2005 Subaru Baja
Black on Black
thanks for the heads up, id totally outbid anyone interested in it (probably) if it was only black. be a tough get too, im in vegas :-P
Old 08-15-2011, 02:12 PM   #12
PenguinSub
Member#: 271739
Hey man, just tryin to help out a fellow Bajaha-er.
Old 08-15-2011, 02:21 PM   #13
Kev5n24
Member#: 105711
2005 Subaru Baja
Black on Black
much appreciated too, and if you see a black on let me know, and i get it, ill smoke you out like theres no tomorrow! I'd give ya rep here too if this site was into that sorta thing :-P
Check out this sick pick i found snooping around that site, black baja, just like mine, but with an ARE cap, so sweet looking.
http://www.wgz.org/bmeyer/pic/Subaru/baja/cap/Cap1.jpg
Why are Subaru owners are better than other car owners... Silver_AWD General Community 68 09-25-2009 02:52 PM
ARE Cap in Worcester Mass area corgimas Baja Forum 4 10-15-2008 10:19 PM
ARE caps still around? canuck37 Baja Forum 5 07-28-2008 02:13 PM
Attn: 05 LGT owners & FHI 4pot owners Gator GT Legacy Forum 16 03-10-2005 01:15 PM
AttN: Tein Coilover Owners / any coilover owners teck7droid Southern California Impreza Club Forum -- SCIC 0 11-22-2004 01:33 PM
Message Board Statistics All times are GMT -4. The time now is 03:08 PM.
