South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 04-22-2009, 01:26 PM   #1
tobylazur
Member#: 150289
2006 05 CTSV, SV650
1972 Travelall
Default need help tracking down low boost problem...
My car is currently only hitting around 12-13 psi when (according to Cobb) it should be hitting about 16psi then tapering down to 13. Something is off that you can hear while driving the car. I can't tell if it's a boost leak, or an exhaust leak though.
anyone got some time to help me track the problem down? I'll bring some beer?
tobylazur is offline   Reply With Quote
Old 04-22-2009, 02:00 PM   #2
racingfish
Member#: 60976
1969 LGT
FATURBO
what does it sound like??? wheres the sound coming from and what kinda boost gauge r u using.. please dont say your using the cobb ap as your source
racingfish is offline   Reply With Quote
Old 04-22-2009, 02:20 PM   #3
tobylazur
Member#: 150289
2006 05 CTSV, SV650
1972 Travelall
ha, it sounds a little like an exhaust leak at idle, and a boost leak under boost. I'm using an autometer guage, and comparing it to the gauge on my blitz turbo timer
Old 04-22-2009, 03:02 PM   #4
cronic
Member#: 9749
Do you have an aftermarket uppipe?
cronic is offline   Reply With Quote
Old 04-22-2009, 03:50 PM   #5
szeny
Member#: 81383
07 335i e90
TiAG/Dakota Black
. dot dot dot
szeny is offline   Reply With Quote
Old 04-22-2009, 04:04 PM   #6
tobylazur
Member#: 150289
2006 05 CTSV, SV650
1972 Travelall
I do. Between the uppipe and turbo is the only gasket I haven't replaced yet.
Old 04-22-2009, 07:27 PM   #7
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
That would be the first thing to check.
Another common place is the BPV to TMIC gasket but usually only if you have recently removed the TMIC. The turbo outlet pipe sometimes will not seat correctly when the TMIC is replaced also. BOth of these leaks sound like a screaming cat under boost though.
blkscooby is offline   Reply With Quote
Old 04-22-2009, 10:43 PM   #8
tobylazur
Member#: 150289
2006 05 CTSV, SV650
1972 Travelall
Is there anyway to check these other than visually?
Old 04-23-2009, 01:58 AM   #9
racingfish
Member#: 60976
1969 LGT
FATURBO
if you have an exhaust leak stick your hand were teh seals are... if u feel air beating on your hand then u have a leak. if your scared to stick your hand down near your dp then use a piece of WHITE paper.
Old 04-23-2009, 03:46 AM   #10
szeny
Member#: 81383
07 335i e90
TiAG/Dakota Black
you cna put soapy water on the BOV and see if it bubbles..
Old 04-23-2009, 11:52 AM   #11
tobylazur
Member#: 150289
2006 05 CTSV, SV650
1972 Travelall
isn't the bov under vaccum at idle?
Old 04-23-2009, 12:23 PM   #12
racingfish
Member#: 60976
1969 LGT
FATURBO
rev the engine.
Old 04-23-2009, 12:43 PM   #13
szeny
Member#: 81383
07 335i e90
TiAG/Dakota Black
thought the leak was under low boost? like fish said rev the engine and watch for bubbles on the bov... probably that uppipe leak like chronic said tho
Originally Posted by racingfish View Post
rev the engine.
i had a bov leak and it would sound like a turkey when i boosted low
Old 04-23-2009, 12:53 PM   #14
racingfish
Member#: 60976
1969 LGT
FATURBO
gobblegobblebietches
Old 04-23-2009, 01:30 PM   #15
tobylazur
Member#: 150289
2006 05 CTSV, SV650
1972 Travelall
Ok, I'm gonna try these tomorrow afternoon. I'll post back with some results.
Old 04-23-2009, 06:52 PM   #16
MrMcCrackin
Member#: 89202
I'm # 1 when it
comes to # 2
post reported scumbag!!!
enjoy ur 9 points!
MrMcCrackin is offline   Reply With Quote
Old 04-23-2009, 07:56 PM   #17
racingfish
Member#: 60976
1969 LGT
FATURBO
lol....
hopefully he doesnt find any CRACKor leaks.
NoVA: Need help tracking down nozzles for IC spray + Install in the next 2 days? AcquaCow Mid Atlantic Impreza Club -- MAIC 11 09-26-2007 09:50 AM
boost leak need help tracking it down. hybrid gti 2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 04-16-2007 07:24 AM
Need help tracking down a scammer (fellow suby owner) in E-Town Canadian 2.5RS Canada Region Forum 28 06-04-2006 05:43 PM
Urgent: Need help tracking down why shifting into reverse is blowing a fuse. Geoff Electrical & Lighting 5 06-02-2005 10:42 PM
Need help tracking down small class T (75w) and class D (2x 200w, or 1x 400w) amps. AcquaCow Car Audio, Video & Security 13 12-10-2004 05:33 PM
