Old 04-22-2009, 04:17 PM   #1
Mr_Snips
Member#: 152117
2012 Ford F150 ECO
Default Finally
Just ordered my Borla Rep headers off of Ebay. MY question is though, is it worth wrapping them? It seems like it would be but idk if i really want to go through the hassle.
Well i got it installed today and wrapped. It fit okay but needed to be widened if that makes sense. I drove it around for a bit before i took it back off and wrapped it. The wrap made a noticeable change in exhaust tone and in performance. The high end seemed much better wrapped then unwrapped.
Mr_Snips is offline   Reply With Quote
Old 04-22-2009, 05:03 PM   #2
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
Without the wrap, I've heard the headers sound really hollow and amplify any valve train noise you have, which you probably don't want. I also recall something about the wrap amplifying the weakness of the welds and possibly causing them to crack faster. I can't recall exactly about this last detail with cracking, so someone else should chime in.
chazly413 is offline   Reply With Quote
Old 04-22-2009, 06:52 PM   #3
sc00ter
Member#: 117767
2015 WRX (CWP)
3" TBE | DT Flex Fuel
DEFINITELY!! I have had mine on, unwrapped, for 2 years now and the valvetrain noise is just annoying. it sounds like A LOT of air moving through very hollow pipes. Anytime you drive next to a cement wall of some sort you'll know what I'm talking about.
I plan on wrapping mine when I put new gaskets in this summer.
sc00ter is offline   Reply With Quote
Old 04-22-2009, 06:58 PM   #4
smithrcing17
Member#: 193195
2005 Ty Tuned 2.5RS
ive heard many say yes wrap them! and many say nooo dont! i live in PA and we get snow, rain, and sun alot so we have alittle bit of it all, all year round and what ive heard is that with the wrapping on it can cause moisture to stay in the pipe and rust/crack.. idk if this is true so try to get some more input on that. but i know if you have the money the best option is to get them coated, but if your like me i dont have the money, i did see these cans of DIY heat coat spray at like advance auto or autozone and it seams like it would be better than nothing so i might end up doing it to mine but i dont wanna wrap them cause it lookslike a pain in the ass and yeahh id rather just use the rattle can stuff=]
smithrcing17 is offline   Reply With Quote
Old 04-22-2009, 07:05 PM   #5
rougeben83
Member#: 115154
2005 Outback XT
White on grey
fwiw, I had my old repo uel's wrapped for 2 years and they were fine when I resold them, just light surface rust under the wrap. This included a couple of healthy salt-laden midwest winters.
I'm not sure if it's still the same but the knockoffs I had were made of pretty thick steel tubing. I painted the header before wrapping, then sprayed them again.
More worrisome is keeping oil off of the wrap when you do an oil change. I usually wrapped area closest to the filter with plastic bag and very carefully pulled it off when I was done.
rougeben83 is offline   Reply With Quote
Old 04-22-2009, 07:44 PM   #6
Reebis
Member#: 126157
'01 2.5RS Coupe
BRP
Skip the wrap and just get them jet-hot coated or something similar.
Reebis is offline   Reply With Quote
Old 04-28-2009, 11:46 PM   #7
Mr_Snips
Member#: 152117
2012 Ford F150 ECO
Well, i'm going to wrap them. i got some wrap and i must say its very thick and very heavy. i'll post pics when i'm done.
Old 04-28-2009, 11:49 PM   #8
chazly413
Member#: 151079
2005 2.5RS RBP
I think I've seen a few people apply some kind of water-proofing spray to the wrap. You may want to look into that.
Old 04-28-2009, 11:52 PM   #9
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
+1 to the wrap . otherwise the valve train noise is really annoying .
watchunglava is offline   Reply With Quote
Old 04-28-2009, 11:56 PM   #10
Mr_Snips
Member#: 152117
2012 Ford F150 ECO
The sealent is a must. it was like 10 bucks at autozone.
Old 04-29-2009, 08:29 PM   #11
wirolla
Member#: 109725
2001 GM6
SRP
use this stuff after you wrap your header.
wirolla is offline   Reply With Quote
Old 04-29-2009, 08:36 PM   #12
rhino6303
Member#: 181314
2005 Impreza OBS SRR
05 Legacy GT RBP
First, I used VHT Flameproof high heat ceramic coating and then baked it in order for it to cure. Next, I used the Thermotec Gen-II copper wrap. Finally, I sprayed another can of VHT over top of the wrap, installed and cured the paint again. No valve-train noise and no CELs.
rhino6303 is offline   Reply With Quote
Old 04-29-2009, 08:44 PM   #13
Mr_Snips
Member#: 152117
2012 Ford F150 ECO
Thats what i have...the DEI stuff. so we'll see how it goes tomorrow. Anyone know what size bandclamps i'll need?
Old 04-29-2009, 09:13 PM   #14
Blase
Member#: 54702
2000 impreza 2.5rs
brp
When you're wrapping, wear gloves, long sleeves, goggles etc because the wrap is itchy as hell.
Blase is offline   Reply With Quote
Old 04-29-2009, 09:15 PM   #15
Mr_Snips
Member#: 152117
2012 Ford F150 ECO
will do...how long does it normally take for the wrap to dry before i should spray it?
also what size hose clamps do i need to buy?
Old 04-29-2009, 09:31 PM   #16
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Depends, are you going to wet wrap or just dry? With the wet, I let the thing sit for a couple of days and sprayed it - even then I had a lot of smoke seep out of the wrap when I ran it on the car for the first time. Really looked like I blew a radiator or something when I drove around for the first 30 minutes. In hindsight I shouldve driven on the highway so the smoke would clear out faster.
When I did dry on my turbo manifold, I didn't get as much smoke.
Hose clamps, depends on how you're wrapping it. I ended up using only two hoses clamps, one for the collector (3" IIRC, but snipped off the excess) and another on the crosspipe (2") when 2 of the runners merged. This is because I started at the head flanges and wrapped each runner individually then tapered to the collector. Much harder to do, but it looked much cleaner.
I know people using clamps on each runner or at each merge depending on how they started wrapping it.
Old 04-29-2009, 09:59 PM   #17
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
valvetrain noise?
I got my borlas and haven't heard anything like that, unless I'm just used to the loudness of my exhaust.
Smoke is offline   Reply With Quote
Old 04-30-2009, 01:41 AM   #18
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
i kinda like the valvetrain noise, it sounds more beastly
olsen726 is offline   Reply With Quote
Old 04-30-2009, 04:48 AM   #19
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Originally Posted by Da-Risin-Smoke View Post
valvetrain noise?
like a ticking sound...I didn't really hear it when I was EL and non-wrapped. Dunno maybe I'm going deaf.
Old 04-30-2009, 10:29 AM   #20
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Old 04-30-2009, 10:46 PM   #21
Mr_Snips
Member#: 152117
2012 Ford F150 ECO
sounds yummy
Final Multiple-choice Final as an undergrad... all C's? crowbar Off-Topic 12 03-26-2004 04:33 PM
Nearly final order- any final opinions? mike270 Car Audio, Video & Security 6 05-28-2002 11:57 PM
('93-'01) Bad WRX—The Final, Final Chapter Spa2K Impreza Forum 19 10-16-2001 07:21 PM
Finally finally, MY pics from Cherokee Trails grimlock Motorsports 4 03-26-2001 08:23 PM
Finally gettting my AWD done- Which final drive would you choose? beachbum Normally Aspirated Powertrain 7 03-09-2001 08:40 PM
